Old 07-15-2014, 08:29 PM   #225
ericvanderwoodsen
ericvanderwoodsen's Avatar
Drives: 2013 SWP Subaru BRZ Premium
Originally Posted by Mathewgzlz View Post
Still running strong 15k miles later. Just make sure if there going to drill your oil pan that they do a good job mine had a small leak
Resistance- Because if we fight we might lose, but if we don't fight we've already lost.
Nice! How many PSI did you have to run to reach 323hp?
ericvanderwoodsen is offline   Reply With Quote
Old 07-15-2014, 09:01 PM   #226
xwd
The EFRs are great turbos and the kit is well priced for what you get in it considering the EFR6258/6758 turbos are like $1600 by themselves. They just have no presence on the forums anymore which is probably why you don't hear much. The 6758 is pretty much equivalent to a GTX2867R. Has just about the same spool but the throttle response is better due to the much lighter wheels on the EFR.
The Following User Says Thank You to xwd For This Useful Post:
connor_lol (07-17-2014)
Old 07-17-2014, 09:03 PM   #227
connor_lol
connor_lol's Avatar
Drives: GT86 / Rebadged Firestorm FRS
Does anybody have any PDF or files on how to install / hook up the oil and coolant lines? in/outs
connor_lol is offline   Reply With Quote
Old 02-23-2015, 10:56 AM   #228
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Long-Term Update!
Ok, I've had the kit running on my car for over 2 years and 25K miles. Here are some impressions:
- Car still runs great, no issues at all
- No mechanical issues, parts are still in great condition
- Fun to drive! I still get a smile on my face every time I go WOT
- Car pulls well, even when not in full boost
- I'm running Treadstone's 3" TBE single-exit exhaust (a little loud, but straight and light-not mass produced)
Overall I'm very satisfied with this kit. Full disclaimer: my car was used for R&D of the kit, so I didn't pay much for it. However, if I was in the market for a turbo kit this one would definitely be at the top of my list! The fact it's modular, so you can swap out the BW turbos is appealing to me, as I may bump up a size in a year. The 6258 is great for daily driving. I'm around 300whp/250wtq, and the reliability and OEM feel to the kit is really great as well!
Highly recommend!
kmbkk is offline   Reply With Quote
The Following User Says Thank You to kmbkk For This Useful Post:
indy (01-01-2016)
Old 11-27-2015, 12:05 AM   #229
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
I'm over 40k miles on this kit and going strong! I still DD it 70 miles and I've yet to have a single problem
The Following 2 Users Say Thank You to kmbkk For This Useful Post:
indy (01-01-2016), Lonewolf (11-27-2015)
Old 08-18-2016, 09:10 AM   #230
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Quick update:
I've hit 50K miles on the kit, still no problems. I upgraded the stock clutch in April to the Stage 3 Comp Clutch kit. Now time to upgrade for flex fuel!
The Following 3 Users Say Thank You to kmbkk For This Useful Post:
arthur93 (05-22-2017), GhostOp86 (08-18-2016), stokeless (09-21-2016)
Old 06-24-2017, 11:53 PM   #231
The2nd_Noel
Drives: Scion FR-S Whiteout
Could you give another update?
Also, did you upgrade the clutch out of preference or was it needed due to the turbo?
I'm starting to look into going FI and this kit was recommended to me by a local tuner.
The2nd_Noel is offline   Reply With Quote
Old 06-25-2017, 11:58 AM   #232
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
Not necessarily
Originally Posted by Synack View Post
It would be very tough... and interesting to say the least... as there are 2 banks of cylinders, but only 2 cylinders per bank. You would have to get an aftermarket manifold for each bank that would run into each turbo. I'm not sure how effective it would be with only 2 cylinders per bank, not a whole lot of exhaust running to each turbo.
For small engines (4 banger in this case) it is of course better to use a single turbo, because it produces sufficient exhaust gas just that one turbo efficiently. For larger engines, it is usually smarter to use a pair of small turbochargers instead of a big one, because small turbines result in less turbo lag. But they are able to produce enough exhaust gas to power both turbos.
Look into the Chrysler ppg m4s. 2.2 litre 4 banger twin turbo made 475hp...
Spool with two smaller turbo is always quicker
Jaden
Jaden is offline   Reply With Quote
The Following User Says Thank You to Jaden For This Useful Post:
DC2R (06-28-2017)
Old 08-22-2017, 01:05 AM   #233
Zee2413
Drives: Scion FR-S 10 Series
Installing this kit with the 6758 turbo in a couple of weeks!
Zee2413 is offline   Reply With Quote
Old 08-23-2017, 06:04 AM   #234
Wyattkb
Drives: 2014 Whiteout FRS
Where did you purchase it from?
Wyattkb is offline   Reply With Quote
Old 08-23-2017, 10:53 AM   #235
Zee2413
The shop installing it for me ordered it directly from Treadstone.
Old 08-23-2017, 08:38 PM   #236
Zee2413
Just found out today that Treadstone is out of stock on the manifold and it will take a month to get this kit.
Very annoying news, specially when they decide to tell us a week after taking payment.
Old 08-23-2017, 10:21 PM   #237
Wyattkb
That sucks.
I emailed them about their kit 3 days ago and haven't heard a response back yet.
I'm not going to hold that against them but it seems terrible communication is a common occurrence with these companies making turbo kits.
How have you been contacting them? I'm thinking about calling them because I want to order the kit without the ecutek stuff since I already have it.
Also is the manifold manufactured by them?
Off topic rant, JDL for instance is laughable, I live 30 minutes away from them and can't even get them to respond to a phone, email, PM you name it.
Sent from my Pixel using Tapatalk
Old 08-24-2017, 10:34 AM   #238
Zee2413
I had the same issue with email. They have bad communication. I ended up calling them and it took a few tries to get a hold of someone.
I am not sure who manufactures the manifold, but they have not noted any other brand so I am assuming they manufacture in-house.
FYI, they are increasing the price of the turbo kit soon so get your order in ASAP. Unless you don't want to wait a month for the manifold, then go with another brand of turbo.
That sucks.
Crawford Performance Turbo BRZ ! Visconti Forced Induction 57 10-12-2012 07:45 AM
Turbo BRZ from Accelerated performance buzznasa BRZ First-Gen (2012+) — General Topics 3 07-20-2012 11:14 AM
need donor for treadstone turbo kit treadstone performance Forced Induction 113 07-19-2012 10:31 AM
