Old 08-23-2017, 11:19 PM   #43
CSG Mike
CSG Mike's Avatar
Originally Posted by TylerLieberman View Post
Perfect for a car seeing drift duty. I might have to link up with you to catch a ride along and see how it feels for myself.
$2200 is a lot, but if it's a big difference over what my last car with Tomei EL + OFT was, I'm willing to spend it.
It's actually more Hp/Dollar than a Tomei + OFT!
Old 08-23-2017, 11:21 PM   #44
CSG Mike
CSG Mike's Avatar
Originally Posted by tshrey View Post
Is that dip in the 91 plot at 2500 real? With how sharp it is (both down and back) it seems like it would be annoying from every pull away from a stop in first gear.
Probably not, as I don't feel it. I suspect its where the pull was started.
Old 08-24-2017, 12:00 AM   #45
redlined600
redlined600's Avatar
Drives: Fr-s
Originally Posted by justinco View Post
I totally get what you are saying, which is why I have been thinking of switching to an EL header over the off-season. However, the way I look at it is this; where do these cars suffer the most? It is in the digs and between 3500rpm - 5000rpm. Once we get above 5k rpm or so, the limitation is no longer power, it is grip. Having more power there really doesn't help too much, where as having some more grunt in the mid-range does. And this is speaking strictly STX autocross and my opinion, of course
It's easy to make a histogram in excel with a data log of your rpm. Better yet only include data while you're 100% throttle opening. This would give a clearer picture.
redlined600 is offline   Reply With Quote
The Following User Says Thank You to redlined600 For This Useful Post:
justinco (08-24-2017)
Old 08-24-2017, 02:45 AM   #46
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by weederr33 View Post
But my bank account
Also I was heavily leaning towards the HKS header... but ugh. :/
If your looking for a N/A header that is one of the best bang for the buck I suggest PPE EL header. I had great results with that one. BUT the ACE header will make more hp than the PPE but not much.. Its truly you get what you pay for scenario. Honestly tho, If I need a N/A header I'm going to pony up for the ACE next...
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
weederr33 (08-24-2017)
Old 08-24-2017, 03:23 AM   #47
The A/350 is what you want for sustained 4500-redline use.
Not the Anaconda? Hmmm...
Old 08-24-2017, 07:20 AM   #48
CSG Mike
CSG Mike's Avatar
Unless you have cams and/or a build engine...
Old 08-24-2017, 10:15 AM   #49
cjd
cjd's Avatar
Drives: 2017 BRZ
When I was researching (before Ace was around) the same discussions were had around the Nameless. I did a bunch of work in excel and never found the best UEL to be making more power except over the shortest EL headers, and then over such a brief area as to be negligible. The Nameless was quite a bit better pretty much everywhere... Though repeatability seems to be a challenge for tuners. The problem with the data comparisons was finding examples with baseline pulls, and normalizing on that. Most other comparisons I've seen seem to skip the baseline and try to line up the header pulls...
I'd be happy with an Ace but can't justify the cost to change...relative to the long tube 4-2-1 EL I already have. I may be stuck on the tune side and no choice, eventually...
C
Old 08-24-2017, 12:35 PM   #50
JDM4E
Drives: Honda Accord Euro
I would love to see a sound clip of that setup (ACE 350 with good tune + stock the rest). any chance? Does it drone or rasp in any way? Does it smell?
JDM4E is offline   Reply With Quote
Old 08-24-2017, 12:55 PM   #51
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Well according to your website just about ANYTHING except a catback exhaust is better hp/dollar than the Tomei headers.
ineedyourdiddly
Old 08-24-2017, 01:10 PM   #52
Williampreza
Williampreza's Avatar
Drives: 2017 Ice Silver BRZ Limited
I took a wild shot and typed "ace 350 header" into YouTube.
Williampreza is offline   Reply With Quote
Old 08-24-2017, 01:14 PM   #53
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
No, the first hundred RPM can vary in how they look based on how you're ramping into the pull. That dip does is not something you would feel because it's not really there. :-)
-Zach
Old 08-24-2017, 01:21 PM   #54
jmark
Drives: '97 NSX-T, '18 Type R
I believe this is Mike's setup. Sounds great to me.
https://www.facebook.com/CounterSpac...type=2&theater
jmark is offline   Reply With Quote
Old 08-24-2017, 02:19 PM   #55
gtengr
Drives: 2017 BRZ
In comparisons it's rarely mentioned that the ACE header also replaces the stock overpipe. How does the ACE compare to the top uel and el headers plus aftermarket overpipe?
gtengr is offline   Reply With Quote
Old 08-24-2017, 02:50 PM   #56
JermMX5
Drives: 2017 Toyota 86
Take a look at the second picture here: https://www.delicioustuning.com/Stage_2_BRZ_FRS_86
Looks like the JDL with nameless OP made some really decent numbers.
2017 Toyota 86 - Whiteline 20mm Front Bar | Crash Bolts | 235/45/17 RE-71R | 17x7.5 OZ Omnia | OFT Stage 1 For Street Driving | Trackpipe for AutoX | Not enough camber.
JermMX5 is offline   Reply With Quote
CSG Mike's personal 2017 BRZ build and thoughts. CSG Mike Member's Car Journals 235 09-10-2019 12:03 AM
CSG x MXP Catback + Ace A350 - Review & Video Majic86 Engine, Exhaust, Transmission 14 08-06-2018 02:01 AM
Do dynos lie? nikitopo Engine, Exhaust, Transmission 21 05-10-2017 09:32 AM
CSG Mike's 2017 Baseline dynos CSG Mike Engine, Exhaust, Transmission 40 01-21-2017 10:20 PM
Perrin CAI - Any dynos? griffinnn Engine, Exhaust, Transmission 0 03-14-2014 05:56 AM
