Old 07-06-2017, 07:33 PM   #99
Astroboy
Astroboy's Avatar
Drives: None
Anything i can do to eliminate the uneven wear?
Sent from my LG-H820 using Tapatalk
Astroboy is offline   Reply With Quote
Old 07-25-2017, 07:34 PM   #100
BcRuZn
Drives: 2017 Brz Series Yellow
Originally Posted by airindia33 View Post
Just bought a 17 BRZ with performance package. The wheels are 17x7.5 +48 offset vs the 17x7 +48 on the regular wheels.
I am looking to run spacers but am having a hard time deciding between sizes. I don't want any poke at all if possible. I was thinking 10 up front and 20 in the rear???
Since the wheels are .5" wider they will already stick 6.35mm further out. My question is since the tire size has not changed should I really worry about the extra 6.35mm? And what size spacers should I go with?
Did you ever choose a spacer size for your 17 Brz?
I also have pp wheels and would like to see what size spacers work
Best, I was leaning towards 15/20 front 20/25 rear.
BcRuZn is offline   Reply With Quote
Old 08-23-2017, 09:18 PM   #101
airindia33
airindia33's Avatar
Drives: 2020 BRZ PP
I ended up doing the 15F / 20R with the stock 215s and the car looks great IMO. I am going up to 225s soon. I think the 20F and 25R would also work without any poke.
airindia33 is offline   Reply With Quote
Old 08-24-2017, 06:57 PM   #102
BcRuZn
Ok perfect.
I Am thinking about going 20f 25r on eibach pro kit springs. What spacers did you end up getting? I saw some on eBay for like $80 for all 4.
Old 06-04-2018, 01:19 PM   #103
PacManTheRS1.0
PacManTheRS1.0's Avatar
Drives: 2015 Scion FR-S Release Series 1.0
Hey all, wanting to run a 15/25 setup on my RS1.0
Would these work for the front without having to get extended bolts? https://m.ebay.com/itm/2-WHEEL-SPACE...anner=1&_rdt=1
Would these work for the rear without having to get extended bolts?
https://m.ebay.com/itm/25mm-1-Hubcen...anner=1&_rdt=1
"I am not designed to come second or third. I am designed to win." - Ayrton Senna
PacManTheRS1.0 is offline   Reply With Quote
Old 06-04-2018, 05:42 PM   #104
Impureclient
Drives: 2015 FR-S
Just make it easy on yourself, do 20mm front and 25mm rear. Any bolt on ones will work in front or back as long as the bolts on the car don't protrude too far past the spacers and hit the back of the wheel. It seems like it's only in that weird in between area, 15mm, that it might hit the back of the wheel which is why it's just best to go to 20mm. It's only using the slip on ones above 5mm where you need the extended bolts. I struggled with this a lot on the 17x7.5 +45 wheels I had prior. In fact, my 20mm spacer was not enough and my bolts actually touched the wheel, so I had to grind out a little on the wheel to fit. In the end it was just 20mm front/25mm rear and done...perfect adjusting some. Using the stock wheels, it seems like nobody had any issues before with any 20 or 25 spacers so no metal removal needed. Then when you want aftermarket wheels, which is a huge possibility with this car, you just sell the spacers and pop on new wheels with less offset and save $100 plus labor on extended bolts you don't need any more.
Even better than all this spacer business. Sell the OEMwheel/tires and put that towards a wider wheel and tire and better offset to begin with. You will get better grip from a wider/stickier tire, it will look better due to that offset and wheel width pushing it out and you will spend less in the end. All we are doing with the spacers is just buying our time because it's almost inevitable you are going to just get the correct aftermarket size any way if you intend to keep the car.
I see a lambo, ferrari and McLarens here and there but that one RS1.0 FRS that drives around by me with nice correctly fitting black aftermarket wheels always grabs my attention more.
The Following 3 Users Say Thank You to Impureclient For This Useful Post:
Leonardo (06-04-2018), PacManTheRS1.0 (06-05-2018), SkyeHack (07-25-2018)
Old 06-05-2018, 10:09 AM   #105
PacManTheRS1.0
Decided to go with 5mm in the front and 25mm in the rear and will update after I install and take pics. As you can see my RS1.0 just desperately needs to be pushed out in the rear
Old 06-05-2018, 10:37 AM   #106
Zoid
Zoid's Avatar
Drives: 2015 Subaru BRZ Series.Blue CWP
Funny how such a small change can make a world of a difference in how the car looks.
Zoid is offline   Reply With Quote
The Following User Says Thank You to Zoid For This Useful Post:
Old 06-05-2018, 04:40 PM   #107
Leonardo
Country Boy 4 Life
Leonardo's Avatar
The rears will bolt on.
The fronts you will have to remove the stock studs and replace them with longer studs. This is easy. Remove the wheel. Remove the brake rotor. use a ball joint separator to remove and install the studs.
This tool.
via Imgflip Meme Generator
My $0.02
I'd get at least 10mm fronts. IMO, you won't notice the 5mm fronts when compared to the 25mm rears.
Good Luck!
I LIKE TIRES!
PacManTheRS1.0 (06-06-2018)
Old 06-25-2018, 10:55 PM   #108
Aipex8
Drives: 2017 Toyota 86 860 Special Edition
Don't think I've seen any 2017+ wheels in this thread. Here are mine with 20mm front/25mm rear, lowered on TRD springs, no other suspension mods:
Aipex8 is offline   Reply With Quote
The Following 4 Users Say Thank You to Aipex8 For This Useful Post:
carsebuco (08-13-2018), monkeybike (06-25-2018), new2subaru (06-26-2018), steel86gt (06-19-2019)
Old 06-25-2018, 11:31 PM   #109
monkeybike
Drives: 86
[IMG]https://lh3.googleusercontent.com/dUC4bWtVNUZB3IvlYzEKWMAYxIzkGdrhLynMyzUxJkpLsxWyhf KGoUe1-lDMqquB0KDLcyiVTHLpB69YXsvzVuvQN8c-Q18g4q9BBN6oCqGxpxeHWDyKQ_JqTjOrG15mUh9hxmWD4z6X_m zzLsL_nZ0pVaak-T9RrItbRfauOjf0fndRtFfoSGDa8BOFc5lDdkiofRMJPMaSq5-J-S50OcQGtpt6J3wNTDx8X6XWTNp50KnRoi4IMvhaqH5D7ecqAIE 0FshWOVxUxYeOwQrzQX89yDN2n9JD***Bpuxt6Fp8vzKsn6APT cWLr2J549INPfisSTzAzUVvC4VHkRY4icWcAQruaNmVMqEefUk Qy5nT_zprDOQZy1a1bHgYhbAcFLbFDKTXOoCfasrldFH1yWxLq QKT7HicUMu7jK5JoXHrbNpv2RLXcVTRyGcWM28SD4B7cw5qYom btidYHUYDCNvIn5BVKLCvHnANe2SMDIg7P6BIQN1hQyb8Jt98y q6jDM6ArHXI2JsWnyA4vYh67-ZQ8S4qNUNa5y6ojajPvboXp--PkmLojv2yyjKoJFji2GOuXz7MOLctdEBJcfuGMixGdoVDMZBV9 JOGGws=w1350-h1012-no[/IMG]
Unfortunately the pic didn't work but I'd really like to see it.
Are they stock 17 or PP wheels?
monkeybike is offline   Reply With Quote
Old 06-26-2018, 12:15 AM   #110
Aipex8
Sorry. Now as attachments.
Stock but 860 Special Edition paint.
The Following User Says Thank You to Aipex8 For This Useful Post:
monkeybike (06-26-2018)
Old 06-26-2018, 12:25 AM   #111
monkeybike
Drives: 86
Looks great. Congrats.
Old 06-29-2018, 08:59 AM   #112
xenarc
xenarc's Avatar
Drives: 2017 SUBARU BRZ
I am going for the 20mm front / 25mm rear. Here is the back of the 2017-2018 17x7 OEM wheel:
Looks like there is enough space for the bolt on spacers
Thanks for the pictures Aipex8
xenarc is offline   Reply With Quote
The Following User Says Thank You to xenarc For This Useful Post:
Aipex8 (07-04-2018)
Best springs+spacers for stock wheels? retrosmiths Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 09-22-2015 08:52 AM
Spacers on all 4 corners / stock wheels (20mm/25mm) zoltiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-14-2015 11:43 AM
Spacers and stock wheel studs solidONE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-31-2013 08:55 AM
Stock Wheels Need Spacers? theom Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2013 11:49 AM
Spacers with Stock Wheels Starscream15 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-05-2012 01:31 PM
