#15 | |
The Gunshine State
Drives: '14 BRZ Limited
![]() Current DD: M235i |
#16 |
Drives: '13 BRZ
Great, then it looks like you have zero reason to be in this thread.
Have a nice day. |
#17 | |
The Gunshine State
![]() LOL you snowflakes get so butt-hurt any time someone else has a differing opinion.
| The Following 2 Users Say Thank You to 8RZ For This Useful Post: | gravitylover (08-28-2017), Tcoat (08-23-2017) |
#18 | |
Drives: '87 Buick GN, '16 500 Abarth
My favorite though, that led to me just walking away with it half done, was a *guy* who refused to learn how to do it (I said "I'll teach you how to do it, it only takes about 10 minutes" and he wouldn't even touch the tools), then kept asking "why is it taking so long". Because my arm is in a cast and you are useless as a man.
Past Rides: '87 Mazda 626 with junkyard turbo, '86 Fiero SE v8 swap, '87 Fiero GT v8 swap, '87 Grand National, '96 Nissan Maxima (s/c), '04 Dodge SRT-4, '08 VW Rabbit 5cyl, '10 VW Golf 5cyl.
Current: '87 Grand National '16 Fiat 500 Abarth (dumb, immature fun!!) Shopping for a BRZ/'86 right now as an additional toy. |
| The Following 2 Users Say Thank You to fierostetz For This Useful Post: | 8RZ (08-23-2017), LudwigMiles (08-23-2017) |
#19 |
We all have to decide our own risk vs reward set up. For ages, with (only slightly) larger cars I used to carry a milk crate in the trunk with all manner of stuff, and I can count on one hand the number of times I needed any of it in a road emergency type situation over the course of the last fifteen-twenty years. More importantly, none of it was necessary, just made the job a little easier.
When I got this car, I finally made the decision to cut back. That being said, I carry a torque wrench/breaker bar with the socket on it because my rims don't have the clearance for the OEM lug wrench, but it fits alongside the donut under the trunk liner. I also have a tiny inflater, and a small battery pack with jumper leads also all stowed alongside the donut. My goal was to keep the usable space in the trunk clear, and in five years I haven't "missed" having anything. |
| The Following 3 Users Say Thank You to Dake For This Useful Post: |
#20 |
Drives: '13 BRZ
Dake, with larger cars, you typically have higher profile tires. Since you're in TX, you might not see the gaping potholes of the NE. Around here, you can get a flat tire any time you change lanes. So, for me, a tiny trolley jack and breaker bar were a no-brainer, since they take up almost no room.
At the very least, I would advise everyone here to try breaking a lug with their factory tool. If you can't, then buy a $10 breaker bar, stick on a 19mm and stash it with the donut under the trunk mat, as Dake described. |
#21 |
ಠ_ಠ
Drives: 860 SansOverspray
3 feet breaker bar, torque wrench and impact socket here.
I used to carry a small floor jack like you when I was a VW head. Their 1 sided jack were so unsafe. |
#22 |
Drives: '13 FRS - STX
If you can't get the lugs off with the provided wrench you have likely overtightened them and are damaging your car.
| The Following User Says Thank You to strat61caster For This Useful Post: | 8RZ (08-23-2017) |
#23 |
I have had one flat tire that needed to be changed on the side of the road in the last 20 years. Maybe just lucky but that is the reality. The stock jack (Mitsubishi) and wrench worked just fine.
If you need extra long breaker bars then your nuts are either on too tight or have not been off for maintenance in enough time for them to rust. The scissor jack provided with these cars are more than up to the task of a simple flat change. At least they are not these damned unpredictable things where you had to pick the front end up about 2 feet in order to change a tire:
#24 | |
![]() I can't remember the last time I had to jack up a car along side the road. Now days, I worry more about one of my body parts blowing out ...... rather than a tire blowing out ..... ![]() humfrz |
#25 | |
BRZZZZZ
Drives: 2013 BRZ Whiteout
between..I had car fall off on me once before I bought hydraulic jack, luckily I was in my garage and used other scissor jack to lift the car back up!! |
#26 |
Drives: car
I wouldn't want to carry the extra 25 lbs of steel around. If I get a flat away from home, I'm calling the roadside assist I have on insurance to help me change it (using their tools).
The scissor jack on the BRZ is so shitty, mine is already rusting just sitting in its spot in the trunk. |
| The Following User Says Thank You to radroach For This Useful Post: | Tcoat (08-23-2017) |
#27 | |
Famous Potatoes
Drives: '15 ultramarine
How to change tire on roadside: 1. call number on back of AAA card, 2. watch guy change my tire. |
| The Following User Says Thank You to Sapphireho For This Useful Post: | Tcoat (08-23-2017) |
#28 | ||
REAL REAL men don't even use a jack.
| Tie Breaker! | ichitaka05 | Announcements, Contests, Giveaways | 1 | 07-07-2016 05:42 PM |
| WTB: Low profile floor jack and jack stands! | lupindub | Want-To-Buy Requests | 2 | 11-26-2015 11:03 PM |
| RCE Yellows, WRX Rear Sway bar, trunk jack | Keenercarguy | Want-To-Buy Requests | 2 | 10-31-2015 04:14 PM |
| Osram Night Breaker Plus & Others | Aznek | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 11-18-2012 09:14 AM |
