Old 08-22-2017, 11:32 PM   #1
LudwigMiles
Drives: '13 BRZ
Anyone else carry a tiny trolley jack and breaker bar in their trunk?
Cleaning out my retired daily driver, and transferring stuff into the BRZ.
For many years, I have carried a $30 trolly jack and $10 breaker bar with 19mm socket already attached. This way, a flat tire was a breeze compared to using the OEM widow maker.
Unfortunately, in the BRZ there are no bungee hooks mounted in the trunk, so I still need to figure out a way to secure it down. I may just put it in the rear foot wells, since that space is unused anyway.
LudwigMiles is offline   Reply With Quote
The Following User Says Thank You to LudwigMiles For This Useful Post:
guybo (08-23-2017)
Old 08-22-2017, 11:37 PM   #2
Impureclient
Drives: 2015 FR-S
What about the jack stands?
Impureclient is offline   Reply With Quote
The Following 2 Users Say Thank You to Impureclient For This Useful Post:
funwheeldrive (08-23-2017), G-Man (09-01-2017)
Old 08-22-2017, 11:37 PM   #3
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Lmfao!
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 08-23-2017, 12:23 AM   #4
humfrz
I would suggest a second spare tire, ...... and an air compressor ......
humfrz
Old 08-23-2017, 12:39 AM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
http://www.ft86speedfactory.com/weat...universal.html
Maybe something like this. It's not an OEM part, so that should be a definite perk for you.
Originally Posted by humfrz
I'm old and lazy
Old 08-23-2017, 05:59 AM   #6
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I keep a 2 ton floor jack and some basic tools in the back, strapped down. I have the tools so why not keep them on me just in case? Plus I keep impact sockets the right size for my wife's and kid's cars in case they need help. And a lock out kit if it's not at work.
-Use a ratchet strap. I tried to put it all in the rear footwells but then I had to have the passenger seat all the way forward which sucks. Look under the floor in the trunk, you'll find spots for the strap
The Following User Says Thank You to guybo For This Useful Post:
LudwigMiles (08-23-2017)
Old 08-23-2017, 07:41 AM   #7
Submarinesonce
Drives: Frs
I just use the oem jack, but I do keep a extendable ratchet, sockets, a multitool, flashlight, jumper cables, a tire plug kit, and a 12v air compressor in the trunk...all fits in a 1'x7"x7" bag.
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Submarinesonce is offline   Reply With Quote
Old 08-23-2017, 08:14 AM   #8
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I used to until I started owning more reliable cars lol.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
Old 08-23-2017, 10:54 AM   #9
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
A reliable car doesn't prevent tire punctures!
I have a torque wrench, small multi-tool set (ratchet/sockets, multi-bit screwdriver, allen keys etc), extra quart of oil, and a first aid kit. These are in a small rubbermaid bin along with my steel-toes, hardhat and general work safety gear. Rubber feet on the bin so it doesn't slide around in the trunk when cornering.
99% of the time I am somewhere with cell service so if I did get into trouble help would only be a phone call away, but the odd time I'm out of service it's nice to be a little bit prepared.
wolffbite is offline   Reply With Quote
Old 08-23-2017, 11:01 AM   #10
8RZ
The Gunshine State
8RZ's Avatar
The stock tools in the trunk can handle that so I don't feel a need to bring anything extra for a flat.
Current DD: M235i
Old 08-23-2017, 11:04 AM   #11
LudwigMiles
Drives: '13 BRZ
Exactly. It depends on the size of potholes in your area after ice has cracked the pavement.
We get some massive potholes that can blow out and crack a low profile tire and rim.
I'll check out the ratchet strap under the trunk mat idea. Thanks!
Old 08-23-2017, 11:07 AM   #12
Sideways
BRZZZZZ
Sideways's Avatar
Drives: 2013 BRZ Whiteout
I carry some basic stuff too. I have two breaker bars, one for each of my car along with air compressor, first aid, gloves, old jacket (coz I live in Canada). I carry my old steel hydraulic jack in my other car and my newer aluminum jack in the BRZ. I drilled four slots in the truck hard mat and use velcro to hold by breaker bar. The jack and other stuff is in duffle bag.
Both of my cars are very reliable, but I believe in Murphy's law....if you have it, you will never get to use it and when you have to use it, you will not have it. So, I always keep it in hope of never get to use on side of the road!!!
Also, I hate those stock donut wheels and I learnt it the hard way when a pot hole bent my rim. If I am doing long trip, I take that out and put in one of my winter tire, so that I don't have to crawl at 80kph on highway.
Sideways is offline   Reply With Quote
Old 08-23-2017, 11:08 AM   #13
wolffbite
Just the tip
wolffbite's Avatar
This is true, weight savings for you
The Following User Says Thank You to wolffbite For This Useful Post:
8RZ (08-23-2017)
Old 08-23-2017, 11:23 AM   #14
LudwigMiles
Drives: '13 BRZ
Have you actually changed a tire with your stock tools?
Often, the scissor jack is not stable on the side of a road (passenger side in particular, if the pavement ends, and gravel starts)
Also, some cars come with a short "T" handle that does not give enough torque to bust the lugs.
Some of us prefer a stable trolley jack and a long breaker bar, especially in a car the wife drives.
Tie Breaker! ichitaka05 Announcements, Contests, Giveaways 1 07-07-2016 05:42 PM
WTB: Low profile floor jack and jack stands! lupindub Want-To-Buy Requests 2 11-26-2015 11:03 PM
RCE Yellows, WRX Rear Sway bar, trunk jack Keenercarguy Want-To-Buy Requests 2 10-31-2015 04:14 PM
Osram Night Breaker Plus & Others Aznek Cosmetic Modification (Interior/Exterior/Lighting) 1 11-18-2012 09:14 AM
