Old 08-22-2017, 08:58 PM   #1079
steve99
Drives: FT86
Originally Posted by TwistedGray View Post
Okay, so I am sure I have done some minor mistake, but I cannot quite figure out what it is. I took a bunch of screenshots of the software as I was going along, so hopefully this helps explain things.
I connected the OFT to the PC and ran it through all the updates. Thereafter, I connected it to the car, read the car's stock ECU, and now I am back on the PC. I want to send a few launch control based files to the OFT, but I need to of course modify the files.
I will only use Stage 1, 91 octane files for my tune(s) with varying launch control RPMs. Otherwise, all other settings will remain as-is.
First step was to connect the OFT to the software, and on the side I would run the RomRaider. I know that I need to add the appropriate Definition file to RomRaider, but this is where I am a little confused as to which of the two files I should use? So, I started with the first one as it matched the naming in the CAL box.
I then navigated to the appropriate Stage 1, 91 octane folder, and proceeded to select the matching file that populated in the OFT software. When doing so, I got this error in RomRaider.
Okay, then I figured I should use the other file (see the first picture), so I first removed the first file and then added the second file.
Back to the Stage 1 folder, selected that file again, and I was hit with some Checksum errors. Per the FAQ this is not a major concern, so onward we go.
I then went in to Launch Control setting and set the parameters to what I want. In this case I want the max RPM set to 2000 thus entered in 5600.
Thereafter, I went to save the file and was again prompted by two errors.
Back to the Openflash Manager software. I clicked the Upload Data button, deleted one of the storage spots.
After that I added in the tune that I just created from RomRaider, but I was immediately hit by this error and could not proceed.
I repeated these steps several times, and I always get hit with that error at the end which prevents me from doing anything.
Any suggestions would be greatly appreciated.
post up your stock rom from the Original slot in oft, just donload it to pc then post it as attachment here. you car may have been tuned previously with a calid altered rom
Old 08-22-2017, 09:05 PM   #1080
TwistedGray
IG thomas50shades
Drives: ISO: BRZ
I cannot attach it here due to the file type (.ori), but I dumped it on my Google drive (click here).
Note: I pulled this from Download data, section 2. Save Data, Original File PRESENT.
TwistedGray is offline   Reply With Quote
Old 08-23-2017, 12:54 AM   #1081
steve99
Drives: FT86
just zip the .ori file and it will attach ok
Old 08-23-2017, 01:06 AM   #1082
TwistedGray
IG thomas50shades
Drives: ISO: BRZ
Headed to bed, but you can get the file from the drive link. Or I'll zip it tomorrow, thanks
Old 08-23-2017, 10:16 AM   #1083
TwistedGray
IG thomas50shades
Drives: ISO: BRZ
Zipped it up and attached.
Old 08-23-2017, 01:11 PM   #1084
Kodename47
Kodename47's Avatar
Drives: UK GT86
The ECU is running an A00C ROM and he's trying to attach a A01C file. I'd imagine that's the issue, OFT won't allow you to flash a different ROM type to what's on there.
.: Stealth 86 :.
Kodename 47 DJ:
TwistedGray (08-23-2017)
Old 08-23-2017, 01:14 PM   #1085
TwistedGray
IG thomas50shades
Drives: ISO: BRZ
Ah, so I just need to edit the A00C file instead? Logically I would use the A00C file definition as well, right?
Old 08-23-2017, 01:26 PM   #1086
TwistedGray
IG thomas50shades
Drives: ISO: BRZ
Thanks @Kodename47, that seems to have solved the issue. I don't quite understand why it would've defaulted to the A01C files on the OFT. That was confusing.
Old 08-23-2017, 01:34 PM   #1087
Kodename47
Kodename47's Avatar
Drives: UK GT86
Correct. The A00C should be a B01C internally, as is the A01C. The definitions should be compatible.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-23-2017, 07:47 PM   #1088
steve99
Drives: FT86
Yeah the original fiel is a genuine A00C rom. Weird how the oft loaded A01C originally in the tune slots, maybe oft guys named them dofferently ages ago
but kode is correct just load and use A00C oft tunes and oft defs and you should be good
Old 08-23-2017, 08:10 PM   #1089
TwistedGray
IG thomas50shades
Drives: ISO: BRZ
Yeah, everything appears to be good now.
Old 09-16-2017, 10:41 PM   #1090
sandy s
Drives: 86 gt
Sorry to ask a very stupid question but I cant where it would plug in a RHD car.I cant see the plug. Sandy In Nelson NZ
sandy s is offline   Reply With Quote
Old 09-16-2017, 10:49 PM   #1091
sandy s
Drives: 86 gt
Help I cant find the plug on my RHD car.Can anyone help? Sandy in Nelson NZnz
Old 09-16-2017, 10:50 PM   #1092
steve99
Drives: FT86
It always near the steering column under dash
[ame="https://www.youtube.com/watch?v=5M0ICB6GkKo"]Toyota 86 OBD2 port - YouTube[/ame]
BuffDriver (09-17-2017)
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
