Old 08-23-2017, 01:03 AM   #1555
steve99
Drives: FT86
Originally Posted by Nobunnyhere.86 View Post
it is a stage 2 EL E85 tune . and could a leak around the headers cause an issue like this?? I took it to a shop because I heard some hissing when I put my foot down but the guy told me he didn't here anything so he didn't care to lift it . its been a while its been happening its like a small hiss not to noticible but I daily my car so I notice every little thing . and yes stock injectors
open a petrol tune and the e85 tune in romraider
check the injector port injector scaling BRZ parameters
petrol should be 228 I think and e85 should be different by about 30% ie 168 or so im just going of memory
Old 08-23-2017, 01:11 AM   #1556
Nobunnyhere.86
Drives: Scion FRS
okay so I opened EL stage 2 93 and it shows 228.05 , and for the E85 it shows 171.10
Nobunnyhere.86 is offline   Reply With Quote
Old 08-23-2017, 01:17 AM   #1557
Nobunnyhere.86
Drives: Scion FRS
also quick question how bad would it be to check if I have a faulty MAF sensor by unplugging it while the car is on and at idle? would that be a no no?
Old 08-23-2017, 02:12 AM   #1558
steve99
Drives: FT86
don't think it will hurt , but im not sure what it will tell you.
maybe swap in a friends maf sensor
Old 08-23-2017, 09:27 AM   #1559
Nobunnyhere.86
Drives: Scion FRS
I'll try a friend's or get one off a Subaru Forrester it the price is better at a auto shop . Other then the MAF showing zero was there anything you would say is bad? Or could it all be caused by this pottentialy bad sensor?
Old 08-23-2017, 12:07 PM   #1560
Nobunnyhere.86
Drives: Scion FRS
So i unplugged it this morning while the car was running, car did boggle out a little but stayed running. i plugged it back in and it went back to normal. i did get a check engine light so i ran the 3 codes and it read
P0113=IAT Sensor Circuit High Input
P0102= MAF low voltage
P2097=Post Catalyst Fuel Trim too rich (bank 1).
Im guessing if it pulled a code for low voltage then there is voltage? correct me if i am wrong
Old 08-23-2017, 05:00 PM   #1561
bababooey
Drives: BRZ SWP Limited -6MT
any values detrimentally wrong with these logs?
are the most important readings knock correction, flkc, & afr?
SHORT RUN - 3rd gear long uphill, single small knock event-> http://www.datazap.me/u/n8brz/tx-rr-...a=1-2-5-8-9-13
LONG RUN - varying engine loads, uphill & downhill, multiple knock events, http://www.datazap.me/u/n8brz/tx-rr-...=1&data=1-5-13
Thanks,
bababooey is offline   Reply With Quote
Old 08-23-2017, 07:12 PM   #1562
Tor
Tor's Avatar
Drives: Toyota GT86
Thanks,
It's running way too rich. So rich, that it's below the o2 sensor limits despite the fuel trims not being very high. Do you have an aftermarket intake?
http://www.datazap.me/u/n8brz/tx-rr-...4&zoom=327-481
Knockwise, it's fine.
Tor is offline   Reply With Quote
Old 08-23-2017, 10:55 PM   #1563
steve99
Drives: FT86
Maf sensor is probably ok, if it showing zero it likey an oft logging issue
Car would barly run and throw cel codes if maf voltage was zero all the time
Forrester maf will likely be different , you would need to try one from a brz\86 as a test
Old 08-23-2017, 11:05 PM   #1564
Nobunnyhere.86
Drives: Scion FRS
http://www.datazap.me/u/nobunnyhere8...s?log=0&data=1
new logs. I'm not too good at reading them still learning . and thank you for the reply. i called Toyota today and they had told me they can warranty out the MAF sensor so i will have to run my e85 out and flash back to stock tune be for i go in.
Old 08-23-2017, 11:30 PM   #1565
Nobunnyhere.86
Drives: Scion FRS
http://www.datazap.me/u/nobunnyhere8...&data=1-3-8-11
Last one , this is a 1st to 4th gear norm driving
Old 08-23-2017, 11:41 PM   #1566
steve99
Drives: FT86
Everything looks ok except for the high fuel trims and its running rich upper rpm.
A lot of cars run that rich on oft tunes on e85 safe but costs a bit of power
Also the oft tunes are done for about 70% ethanol so if your on e90 you will get high positive fuel trims
So the only thing that concerning is the 16% fuel trims, now you couls have very high ethanol content e85 like 90%, can you test it ?? The test kits are only about $20 you just mix some e85 with water and you can work out the e% . Or google ethabol percent
Your car may be fine. Might just be very high ethanol content
You can test here if you have a 100 ml craduated container
https://www.google.com.au/url?sa=t&r...6im9_2VMYtqppA
I think you ok its just you high ethanol content e85
Were your fuel trims ok on petrol ??
Old 08-23-2017, 11:47 PM   #1567
Nobunnyhere.86
Drives: Scion FRS
I never logged on patrol, I will once I am out of e85 for my switch back. and well I am glad to know everything else looks to be okay . thanks for helping ill keep you posted if I find out anything.
Old 08-24-2017, 09:20 AM   #1568
bababooey
no stock intake with k&n, then perrin inlet tube. other than wasting a little gas, is running a bit rich terrible?
from what ive read it seems running too lean (too little fuel) can be dangerous, while rich (too little air) just leaves a little power on the table. correct me if wrong, i may have those backwards. my car seems to run rich from prior feedback from Steve, Im trying to understand why and if tinkering with the maf scaling could correct it.
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
