Old 07-13-2017, 05:27 PM   #1541
Buffalo_Rob
Drives: 2016 FR-S
My cal is F00C so I can't log IAM or MAFV. I would greatly appreciate it if someone could give me some feedback on my log. I'm trying to get a feel for this tuning thing before I throw on headers and step up to the stage 2.
I have a little over 200 miles on this tune, it's a stage 1 on 93 octane and my car is stock across the board. Thanks for your time.
http://datazap.me/u/buffalorob/log-1...g=0&data=1-2-7
Buffalo_Rob is offline   Reply With Quote
Old 08-15-2017, 09:23 AM   #1542
oppiee
Drives: 2014 Scion FRS (Red)
Hey everyone,
Can someone give me some idea if this map is running well on my car? UEL 93 stage 2 OFT
http://datazap.me/u/oppiee/log-15027...data=1-5-10-12
oppiee is offline   Reply With Quote
Old 08-22-2017, 06:05 PM   #1543
Nobunnyhere.86
Drives: Scion FRS
HELP PLEASE!
Hi everyone , new to this page here. i hope someone can help. i am currently running Catless Skunk2 EL headers , stock over pipe , MXP catless front pipe , nameless axleback and stock intake but i did cut it to collect more air.
This is a 3rd gear pull i will upload, i am running rich as i pulled a code and if i am not mistaken i also have -5 on the FLKC. i might be crazy but on one of my uploads it also shows a -100 on the FLKC. i can up load that aswell if needed. If you have any advice on how to fix this please help and or if an thing looks wrong . i could be crazy .
Nobunnyhere.86 is offline   Reply With Quote
Old 08-22-2017, 07:03 PM   #1544
steve99
Drives: FT86
can you post up those lgs to www.datazap.me
log the parameters below
  • Engine Speed (rpm)
  • Throttle (percent)
  • MAF Voltage (volts)
  • Engine Load (g/rev)
  • Ignition Advance / Total Timing (degrees)
  • AFR
  • Commanded AFR
  • AFR
  • STFT (percent)
  • LTFT (percent)
  • IAT / Intake Air Temp (F)
  • IAM / Ignition Advance Multiplier
  • FLKC / Fine Learning Knock Correction (degrees)
  • Knock correction
Old 08-22-2017, 07:10 PM   #1545
Nobunnyhere.86
Drives: Scion FRS
  • AFR
  • Commanded AFR
  • AFR
  • STFT (percent)
  • LTFT (percent)
  • Knock correction
Will do as soon as i am off work! And ill be sure to Log all those listed. Thxs for the reply
Old 08-22-2017, 08:24 PM   #1546
Nobunnyhere.86
Drives: Scion FRS
  • AFR
  • Commanded AFR
  • AFR
  • STFT (percent)
  • LTFT (percent)
  • Knock correction
http://www.datazap.me/u/nobunnyhere8...l?log=0&data=1
okay if I am not mistaken I got everything. Here should be 3 different pulls all from 3rd gear.
Old 08-22-2017, 08:42 PM   #1547
steve99
Drives: FT86
when you log pull you need 100% throttle from say 2500 to redline 7500
are you on E85 ??
what is your rom clid it look like some parameters are not logging correctly like iam and flkc
but looking at KC leaned it looks like no knock
you running way rich and your long term fuel trim is high positive, do you have stock intake ?
Old 08-22-2017, 08:56 PM   #1548
Nobunnyhere.86
Drives: Scion FRS
are you on E85 ??
so should log again to do a run at 100% throttle for better results? but yes I am running E85 currently with the stage 2 tune for E85 , and also I do have stock intake but I have cut the nose open for more airflow. creds to the youtube guys who said it helps air flow. could that be an issue ??
Old 08-22-2017, 09:00 PM   #1549
steve99
Drives: FT86
ok yeah do some 100% throttle runs can you add Commanded AFR to parameter list
strange the fuel trims are so positive,
log a few minutes of normal driving as well
Old 08-22-2017, 09:03 PM   #1550
Nobunnyhere.86
Drives: Scion FRS
and when you ask about my "Rom clid" what is that? and the flkc always shows at -100 for some reason.
Old 08-22-2017, 09:03 PM   #1551
Nobunnyhere.86
Drives: Scion FRS
no prob will do that now and will be right back
Old 08-22-2017, 09:45 PM   #1552
Nobunnyhere.86
Drives: Scion FRS
http://www.datazap.me/u/nobunnyhere8...s?log=0&data=1
ok so here are 3 more runs , 2 of them being 3rd gear pulls and should be 100% throttle . the other is normal driving .
Old 08-23-2017, 12:53 AM   #1553
steve99
Drives: FT86
ok
the AFR is a little rich but ok
but the long term fuel trims are way high
timing looks correct for E85
something is not correct,
you have stock injectors ?
or injector scaling is wrong
or DI pressure wrong
causing the large fuel trims
or massive exhaust leak, but the AFR is ok so it doesn't make a lot of sense
looks like a tune problem with injectors
what tune is it
Old 08-23-2017, 12:58 AM   #1554
Nobunnyhere.86
Drives: Scion FRS
ok
what tune is it
it is a stage 2 EL E85 tune . and could a leak around the headers cause an issue like this?? I took it to a shop because I heard some hissing when I put my foot down but the guy told me he didn't here anything so he didn't care to lift it . its been a while its been happening its like a small hiss not to noticible but I daily my car so I notice every little thing . and yes stock injectors
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
