Old 07-16-2017, 09:17 PM   #1065
steve99
Drives: FT86
Originally Posted by PDXsuperfly View Post
I went ahead and tried to do a 3rd gear WOT but ran out of room before I could get to redline. BTW this is on 92oct OFT & OFH using the OFH tune. I just got a K&N drop in filter so after I read up on tuning and logging I will be doing another. I realized how little I know about tuning and the OFT has got me really interested in learning more...
looks ok up to arround 5500 , you just start to get a tiny bit of knock. Be interested to see a run to redline as they do add a bit of timing past 5500 compared to standard tune.
your 92 must be pretty good quality
looks much better than i thought it would :-)
Old 07-27-2017, 08:08 PM   #1066
n0thing
Drives: Subaru BRZ
I have updated my OFT template to allow logging of throttle position, brake pressure, steering angle, gear selection etc, and have exported the csv file. If I use HLT/Racechrono as a laptimer to record the GPS value and export this to another csv file, how can I integrate both datalogs to dashware to compile a video? How do I sync both datalog csv files?
n0thing is offline   Reply With Quote
Old 08-14-2017, 01:19 AM   #1067
PDXsuperfly
Drives: 2013 FRS
So things have gotten a little interesting... I ended up with a drop in K&N filter and a Perrin unresonated 2.5" exhaust. Here is a 1st to 2nd pull at WOT. Still have to get some time to learn about all this data but figured I'd share and hear your thoughts.
PDXsuperfly is offline   Reply With Quote
Old 08-14-2017, 02:09 AM   #1068
steve99
Drives: FT86
looks ok from what you can see
try a 3rd gear pull
also load up the logs to www.datazap.me and just post link, heaps easier to read
Old 08-22-2017, 07:16 PM   #1069
Nobunnyhere.86
Drives: Scion FRS
3rd gear pull , High LTFT aswell as knocks at -5
could someone read this upload and let me know if you see anything that i should be worried about? i am new here and still need some learning
My FLKC shows -5 most of the time and when i opened it on OFM it said -100?
Nobunnyhere.86 is offline   Reply With Quote
Old 08-22-2017, 07:28 PM   #1070
Nobunnyhere.86
Drives: Scion FRS
Old 08-22-2017, 07:38 PM   #1071
jvincent
jvincent's Avatar
Originally Posted by TwistedGray View Post
1. I would like to get rid of the flat torque curve around 4000rpm.
You can minimize the dip if you get a catless header but with just a Stage 1 tune there is not a lot of change.
Old 08-22-2017, 07:41 PM   #1072
TwistedGray
IG thomas50shades
Drives: ISO: BRZ
Really don't want to put a header on it, but it's good to know that it won't really do much for me. Maybe I'll put it back up on here for sale. Thanks!
TwistedGray is offline   Reply With Quote
Old 08-22-2017, 07:43 PM   #1073
jvincent
jvincent's Avatar
Somewhere there is a plot of stock vs stage 1 vs stage 2 on here. Have a look for that.
EDIT: Found it.
http://www.ft86club.com/forums/showp...&postcount=189
Old 08-22-2017, 07:54 PM   #1074
TwistedGray
IG thomas50shades
Drives: ISO: BRZ
EDIT: Found it.
Yeah I saw that which prompted me to buy the OFT
$400 isn't bad for the gains, in my opinion, without having to swap any physical parts. Seemed like a reasonable deal.
Edit: Is my method correct, though? In regards to the launch control settings.
Old 08-22-2017, 07:57 PM   #1075
TwistedGray
IG thomas50shades
Drives: ISO: BRZ
Pardon the very long, thorough post, but I obviously want to make sure I don't brick the unit nor muck something up.
I did make one mistake for sure. I did ALL of this before marrying the device to my car, and after I did that the default files are now "Stg1 A01C.bin" instead of the one I noted before.
So, it would seem that I need to go back and edit the "Stg1 A01C.bin" files instead of using the "Stg 1 D00C.bin" files. Does that sound correct?
Old 08-22-2017, 08:05 PM   #1076
jvincent
jvincent's Avatar
Yes. You need to connect the OFT to the car first to get the correct ROM version.
Old 08-22-2017, 08:05 PM   #1077
TwistedGray
IG thomas50shades
Drives: ISO: BRZ
Got it, well I think I'm good to go then after I edit the new files.
Old 08-22-2017, 08:55 PM   #1078
TwistedGray
IG thomas50shades
Drives: ISO: BRZ
Okay, so I am sure I have done some minor mistake, but I cannot quite figure out what it is. I took a bunch of screenshots of the software as I was going along, so hopefully this helps explain things.
I connected the OFT to the PC and ran it through all the updates. Thereafter, I connected it to the car, read the car's stock ECU, and now I am back on the PC. I want to send a few launch control based files to the OFT, but I need to of course modify the files.
I will only use Stage 1, 91 octane files for my tune(s) with varying launch control RPMs. Otherwise, all other settings will remain as-is.
First step was to connect the OFT to the software, and on the side I would run the RomRaider. I know that I need to add the appropriate Definition file to RomRaider, but this is where I am a little confused as to which of the two files I should use? So, I started with the first one as it matched the naming in the CAL box.
I then navigated to the appropriate Stage 1, 91 octane folder, and proceeded to select the matching file that populated in the OFT software. When doing so, I got this error in RomRaider.
Okay, then I figured I should use the other file (see the first picture), so I first removed the first file and then added the second file.
Back to the Stage 1 folder, selected that file again, and I was hit with some Checksum errors. Per the FAQ this is not a major concern, so onward we go.
I then went in to Launch Control setting and set the parameters to what I want. In this case I want the max RPM set to 2000 thus entered in 5600.
Thereafter, I went to save the file and was again prompted by two errors.
Back to the Openflash Manager software. I clicked the Upload Data button, deleted one of the storage spots.
After that I added in the tune that I just created from RomRaider, but I was immediately hit by this error and could not proceed.
I repeated these steps several times, and I always get hit with that error at the end which prevents me from doing anything.
Any suggestions would be greatly appreciated.
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
