Drives: '13 BRZ
Do I have brake pad left?
I took off the wheel, and tried to inspect the brake pad.
Never owned a car where the entire pad was so hidden. I couldn't see anything. So, I looked at the peep hole, but can only see one side. I don't know if that is the pad, or the backing metal. Also, I can't even see the other pad on the right. Are we to assume both pads wear at the exact same rate? This is what I saw. Is this pad or metal plate? I can't imagine so much pad left after 30k miles.
#2 |
Drives: '13 FRS - STX
from left to right
brown stuff is pad, orange stuff is rust on the edge of the rotor, then the hollow center vanes of the rotor then you can see the edge of the right half the rotor Yes, OE pads are very much long life pads if you don't beat 'em up, I wouldn't be surprised if most people could get >60k out of OE pads. Removing the caliper to get a good look at the pads is extremely easy if you already have the wheel off, two bolts. (provided the bolts aren't seized to hell) http://www.ft86club.com/forums/showthread.php?t=24614 (you can see photobucket clicks by right clicking and getting the image url and then pasting that into your browser bar to see it) ((hey @PMok update your pictures on your DIY)) Last edited by strat61caster; 08-21-2017 at 09:58 AM. |
| The Following 6 Users Say Thank You to strat61caster For This Useful Post: | humfrz (08-20-2017), Impureclient (08-20-2017), new2subaru (08-20-2017), notout86 (09-09-2017), Teseo (08-20-2017), Ultramaroon (08-21-2017) |
#3 |
Drives: '13 BRZ
That pad is thick as hell, it almost looks new.
I can't believe it. I guess a light car does not use pads. Esp. when driven conservatively. |
#4 |
#5 |
Drives: 2013 FR-S Series 10
Driving style matters too. Manual transmissions tend to engine brake better as well. The OE pads are long life/low dust too..
#6 |
Drives: 2014 BRZ Limited
| The Following 2 Users Say Thank You to extrashaky For This Useful Post: | humfrz (08-21-2017), strat61caster (08-21-2017) |
#7 |
Drives: FR-S,GTI
I just changed my front pads at 110,000 miles and had plenty left too. Probably could have gone another 100,000.
| The Following User Says Thank You to WNDSRFR For This Useful Post: | humfrz (08-21-2017) |
#8 | |
#9 |
Drives: '13 BRZ
Ok, it looks like I won't be needing to replace the pads anytime soon.
Next time I have the car jacked up, I will learn how to remove the pad anyways. |
#10 | |
Drives: Toyota GT86 Coupe Red (UK)
Discs lasted another 10k and where already 5k driven beyond their 22mm limit. So, without the track day I would estimate, 50k on a set of pads and 50k on a set of discs. Do the US models get the same pads? Over here they are high friction Pagid pads (and discs) I believe, which squeal frequently under light braking.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
| Brake rotor temperature right/left and front/rear comparison questions | HappyMonkey | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 79 | 07-07-2017 02:29 PM |
| OEM Brake Pads, 50% Life Left | Keenercarguy | Brakes, Suspension, Chassis | 4 | 02-14-2017 03:11 AM |
| BLACK FRIDAY SPL - StopTech Big Brake Kit 2PC - 1 kit left 328mm, red slotted | Gruppe-s | Brakes, Suspension, Chassis | 35 | 11-04-2015 09:39 PM |
| STOP TECH BRAKE KIT SPECIAL!!!!!!!!! (2 Left) | vividracing | Brakes, Suspension, Chassis | 6 | 10-15-2014 06:43 PM |
| 3rd brake light idea | ravenblackfrs | Electronics | Audio | NAV | Infotainment | 4 | 09-28-2013 01:30 AM |
