08-03-2017, 06:13 AM | #1 |
Drives: 2015 frs
Long term build
Working on building my 2015 FR-S it's going to be a slow build. I only want to do the work once.
Things I have done so far. 1) bought car new and put 2700 miles on it. 2) installed Ohlins road and track coilovers on it. 3) installed Parts By Max solid subframe and differential riser bushings. 4) Removed and sold engine and transmission. 5) Stripped engine bay. 6) ordered Vorshlag LS swap kit. (Transmission, driveshaft, engine and transmission mounts). Scrapped the idea of using ready made kit. Building this my way! 7) ordered a LT4 engine from GM performance. 8) bought oem exhaust manifolds, and catalytic converters. Modified car to fit them . Last edited by Zer0; 02-18-2019 at 03:07 AM. |
The Following 5 Users Say Thank You to Zer0 For This Useful Post: | Busybee (12-25-2018), Code Monkey (11-08-2018), Fussy08X (03-08-2019), ILLSMOQ (10-26-2017), rixter145 (08-04-2020) |
08-03-2017, 06:38 AM | #2 |
Drives: 2015 frs
Working on routing brakelines and cleaning up firewall.
Moved the clutch master cylinder over 3". Stole that idea from @kurty85 Will be rerouting the HVAC lines and heater core lines as well for engine clearance. Have to make patch panels weld them in and cut new openings where I want them. I bought the vorshlag kit but may push the motor back further anyway. Just making it easier in case I go that route. |
08-08-2017, 01:48 PM | #3 |
Drives: 2015 frs
Getting plates ready to fill firewall. I will be welding in plates I cut. Still need to strip interior, get the primer, and paint off the surrounding metal I will be welding the plates to. Hopefully I will get this done by the time the week is over.
The Following User Says Thank You to Zer0 For This Useful Post: | DustinS (08-01-2018) |
08-09-2017, 04:22 AM | #4 |
Drives: toyota 86
You are a brave man doing this to virtually a new car. But I'll definitely be checking this regularly for updates
The Following User Says Thank You to johl For This Useful Post: | Zer0 (08-09-2017) |
08-09-2017, 05:44 AM | #5 |
Drives: 2015 frs
I bought it to build it. I told my girlfriend before I bought it "if i buy the car I'm not going to drive it. I'm buying it to work on". After I sold the engine and transmission she finally figured out I meant what I said literally. I had to remind her I told her what I was going to do with it before I bought it, and she told me she was fine with it. She then tells me she didn't think I was being literal. She thought it was going to be driven on weekends. Never got shit from her for the car after that. She is pretty cool about it now.
The Following User Says Thank You to Zer0 For This Useful Post: | Drakiv (11-16-2018) |
08-09-2017, 08:19 AM | #6 |
Drives: 2013 LS3 FRS, 3000GT VR4, MKV Supra
This is ballsy for sure. Curious to see it grow!
The Following User Says Thank You to VR4EVER For This Useful Post: | Zer0 (08-09-2017) |
08-09-2017, 09:44 AM | #7 |
Drives: 2015 frs
I will be posting pics up tomorrow of the plates being welded in, and the stripped interior.
08-09-2017, 03:02 PM | #8 |
Driver
Drives: 16 Subaru BRZ
wow, wouldn't have bought it new if i was going to do that, but looking forward to the build man.
BRZ Build Thread
See you space cowboy... |
08-10-2017, 11:17 PM | #9 |
Drives: 2015 frs
I Stripped the interior. Wanted to start welding, and the welder died. Waiting on welder parts now.
08-16-2017, 01:55 PM | #10 |
Drives: 2015 frs
I received my order for the welder. It was a cooling fan that failed, and it wouldn't allow the unit to run. Replaced the fan and did a few test welds. It looks like it's going to run now. I will attempt to weld in the plates again on Friday.
08-18-2017, 07:39 PM | #11 |
Drives: 2015 frs
Patches welded in. Started to clean up the welds.
The Following User Says Thank You to Zer0 For This Useful Post: | johl (08-18-2017) |
08-19-2017, 04:55 PM | #12 |
Drives: 2015 frs
It's finally back out in the sun. It hasn't seen sun in months.
08-19-2017, 09:18 PM | #13 |
Drives: 2015 frs
Bondo to smooth it out.
08-25-2017, 06:37 PM | #14 |
Drives: 2015 frs
On vacation in San Diego will be back to work on the car Sunday. Will post pictures then.
Similar Threads | ||||
Andy0323's Back To Basics Build Thread <Long Term Project> | andy0323 | Member's Car Journals | 15 | 02-02-2018 12:16 AM |
long term and short term | brichard0625 | Engine, Exhaust, Transmission | 7 | 08-26-2013 08:56 AM |
Long term | Bt216 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-06-2013 11:58 PM |
Fuel Trims - Long term and short term | victorb | Engine, Exhaust, Transmission | 6 | 03-27-2013 02:18 PM |
Short Term and Long Term Fuel Trims | naikaidriver | Engine, Exhaust, Transmission | 3 | 03-18-2013 09:55 PM |
