#57 |
Drives: Attitude
#58 |
Is not fast.
Drives: 2014 Whiteout M/T
Obvious troll wasn't obvious enough
#59 |
Drives: 2013 FRS
Real great discussion on differentials. What I want to know is what does everybody use to keep the rear wheels on the ground to help keep from spinning. I'm finding every time I'm pushing it my inside rear wheel is breaking free and spinning. I have great tires and a stock suspension. The front end is tight. Just the rear wants to lift. Not thinking sway bars. Maybe stunt tower brace? Suggestions?
#60 |
Drives: Black Panda BRZ
Hooker in the trunk?
#61 |
Drives: Neptune GR86
An is correct.
A isn't.
#62 | |
Drives: 2017 manual BRZ
![]() Sent from my Pixel XL using Tapatalk |
#63 | |
Drives: 2013 FRS
#64 |
Drives: '24 GR86
This 4 year old thread really just got revived..... lol
| The Following 4 Users Say Thank You to TylerLieberman For This Useful Post: |
#65 |
Drives: 2013 Firestorm 6MT,2005 Saabaru 5MT
#66 |
Huge E85 fan!
Drives: 2016 Scion FRS
the diff in a twin allows for small amounts of slip then locks up when too much slip happens. So it Limits the Slip of the Differential. It's not a mechanical LSD, it is a Torque Sensing diff. Does the same thing. Ours is better for drifting because it locks up pretty quick which is what you want when you get sideways.
#67 | |
| The Following User Says Thank You to fika84 For This Useful Post: | guybo (08-22-2017) |
#68 |
Drives: Toyota GT86 Coupe Red (UK)
On the "pull the handbrake" thing for 3-wheeling.
I thought the 2012 FRS/GT86/BRZ had the e-diff function with the VSC pinging to stop the wheel spinning causing torque to transfer over to the other wheel on the ground. However I remember getting stuck as one back wheel was up against a large clump of grass and it alone spun up. It definitely says in the 2017 (UK spec) car that e-diff is available in FULL and TRACK modes with TC on or OFF, but disabled with VSC/TR fully off (non-pedal dance mode). This suggests the 2017 has both ATB and ABS diff function combined. Does that make it semantically superior to either Clutch or ATB alone?
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
#69 |
OK I resisted as long as I could.
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#70 |
THE CORVETTE KING!
Drives: 2013 FR-S, and 2016 FR-S!
You may not have wanted a lesson, but you got one!
2013 Scion FR-S.
2005 Corvette. |
| Mod that I never thought I'd want: a horn | mike_ekim1024 | Scion FR-S / Toyota 86 GT86 General Forum | 46 | 02-03-2014 12:18 PM |
| Not a BRZ or FRS just thought i would share | wrohdejr | Northwest | 6 | 03-25-2013 01:19 PM |
| You thought Pizza Hut was bad. | Carbon420 | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 02-27-2013 10:49 AM |
| Anybody thought about these? | Memphis | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 08-13-2012 03:01 PM |
| Thought this was cool! so i had to get it! | 86design | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 6 | 07-17-2012 10:11 PM |
