Old 12-24-2013, 01:13 PM   #57
OrbitalEllipses
Drives: Attitude
Originally Posted by Manic View Post
Good god another clutch?! I'm still getting used to the first one! What, will there be 4 pedals now? Double heel-toe?!
Clutch...? Are you talking about the second brake pedal?
Old 12-24-2013, 01:27 PM   #58
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
Obvious troll wasn't obvious enough
Manic is offline   Reply With Quote
Old 08-19-2017, 01:06 PM   #59
EddieZ2
Drives: 2013 FRS
Real great discussion on differentials. What I want to know is what does everybody use to keep the rear wheels on the ground to help keep from spinning. I'm finding every time I'm pushing it my inside rear wheel is breaking free and spinning. I have great tires and a stock suspension. The front end is tight. Just the rear wants to lift. Not thinking sway bars. Maybe stunt tower brace? Suggestions?
EddieZ2 is offline   Reply With Quote
Old 08-19-2017, 03:59 PM   #60
jonboy99
jonboy99's Avatar
Drives: Black Panda BRZ
Hooker in the trunk?
jonboy99 is offline   Reply With Quote
Old 08-19-2017, 04:14 PM   #61
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by 1086 View Post
Ha, what are you saying 'No' to? bad grammar is no bueno... :/
An is correct.
A isn't.
Old 08-19-2017, 05:29 PM   #62
Somerandom18
Drives: 2017 manual BRZ
Remove or get a thinner rear sway bar. Add spare wheel in the trunk. Dead hookers are definitely an option. Not really sure what else. Cinder blocks? Mine is planted and sticks really well even without a spare. But that doesn't help you at all.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 08-19-2017, 07:52 PM   #63
EddieZ2
Drives: 2013 FRS
Hookers are at a premium these days so I may have to go with cinder blocks. Just kinda strange how ready the rear breaks away.Even tried some super soft tires, still rolling out.
Old 08-19-2017, 08:17 PM   #64
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
This 4 year old thread really just got revived..... lol
The Following 4 Users Say Thank You to TylerLieberman For This Useful Post:
Cole (08-22-2017), Somerandom18 (08-19-2017), Tcoat (08-22-2017), tCsonfrs (08-30-2017)
Old 08-22-2017, 02:24 PM   #65
Kutanks
Drives: 2013 Firestorm 6MT,2005 Saabaru 5MT
I rarely have my backend break loose but I have a subwoofer in the trunk
Kutanks is offline   Reply With Quote
Old 08-22-2017, 04:40 PM   #66
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
the diff in a twin allows for small amounts of slip then locks up when too much slip happens. So it Limits the Slip of the Differential. It's not a mechanical LSD, it is a Torque Sensing diff. Does the same thing. Ours is better for drifting because it locks up pretty quick which is what you want when you get sideways.
guybo is offline   Reply With Quote
Old 08-22-2017, 04:51 PM   #67
fika84
fika84's Avatar
I guess the biggest difference really between them is what happens when one wheel lifts. That's when the Torsen fails.
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
guybo (08-22-2017)
Old 08-25-2017, 08:48 AM   #68
paulca
Drives: Toyota GT86 Coupe Red (UK)
On the "pull the handbrake" thing for 3-wheeling.
I thought the 2012 FRS/GT86/BRZ had the e-diff function with the VSC pinging to stop the wheel spinning causing torque to transfer over to the other wheel on the ground.
However I remember getting stuck as one back wheel was up against a large clump of grass and it alone spun up.
It definitely says in the 2017 (UK spec) car that e-diff is available in FULL and TRACK modes with TC on or OFF, but disabled with VSC/TR fully off (non-pedal dance mode).
This suggests the 2017 has both ATB and ABS diff function combined. Does that make it semantically superior to either Clutch or ATB alone?
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Old 08-25-2017, 01:55 PM   #69
OK I resisted as long as I could.
mrderp (08-25-2017), Sapphireho (08-25-2017), Spuds (08-25-2017)
Old 08-25-2017, 02:32 PM   #70
meadowz06
THE CORVETTE KING!
meadowz06's Avatar
Drives: 2013 FR-S, and 2016 FR-S!
Originally Posted by rice_classic View Post
Don't quote me, I don't need the lesson.
I was simply commenting on the puritan or pedantic viewpoint of some.
You may not have wanted a lesson, but you got one!
2013 Scion FR-S.
2005 Corvette.
meadowz06 is offline   Reply With Quote
Mod that I never thought I'd want: a horn mike_ekim1024 Scion FR-S / Toyota 86 GT86 General Forum 46 02-03-2014 12:18 PM
Not a BRZ or FRS just thought i would share wrohdejr Northwest 6 03-25-2013 01:19 PM
You thought Pizza Hut was bad. Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 50 02-27-2013 10:49 AM
Anybody thought about these? Memphis Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 08-13-2012 03:01 PM
Thought this was cool! so i had to get it! 86design FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 07-17-2012 10:11 PM
