#71 | |
Drives: Black 17 BRZ LT MT PP
The 3D print will include a thread to screw into so there will be a mechanical lock and not just a hole with epoxy. |
#72 |
Drives: 2019 Mazda Miata RF
Can you use threaded inserts, and bolt in from the bottom?
Also, with your rapid prototype system, can you grow the inserts into the part? |
| The Following User Says Thank You to Gunman For This Useful Post: | Drambeenie (08-14-2017) |
#73 | |
I believe there are 3D printers that can print multiple materials, but we wanted to make sure we could use bolts/nuts/washers that are easily sourced that are produced with a certain quality of metal that has a measured performance. I think the overarching theme of these questions might be it's strength. The 3D part is going to be printed with a high quality machine using the SLS process. (More common 3D printing is like a hot glue gun building layers - we're only going to use that for the prototype for test fitting) The material we're going to use is Glass Reinforced Nylon, which is commonly used in Automotive Applications. The epoxy strength is going to be extremely strong. Some say that the epoxy we're planning on using is so strong, the entire part would fail before the epoxy does. So we'll prototype with the cheap 3D printing process everyone is familiar with, then for production part we'll use Glass Nylon. The shape of the part, plus the 2 mil thickness for the walls, plus an inner structure, plus the material is going to make an extremely strong shape. Probably overkill if you ask me, but I'd rather overkill than it flying off and actually killing
| The Following User Says Thank You to Drambeenie For This Useful Post: | tehShirt (08-15-2017) |
#74 |
Inner structure added - Ready to print Prototype.
#75 |
Drives: 2014 Subaru Forester
| The Following User Says Thank You to tehShirt For This Useful Post: | Drambeenie (08-15-2017) |
#76 |
There are, but I know our Fortus FDM machine can be paused during the build cycle, to have inserts installed, and then continue on. We have not done it yet, but have discussed parts that we may try this.
| The Following 2 Users Say Thank You to Gunman For This Useful Post: | Drambeenie (08-15-2017), wparsons (07-12-2019) |
#77 |
That would be insanely cool. You could try it with a simple bolt inside of a ball.
#78 | |
| The Following User Says Thank You to Gunman For This Useful Post: | Drambeenie (08-16-2017) |
#79 |
Looks like we're almost at the finish line! Wanted to add a little flair to the bottom before sending it to the 3D printer - Nice and polished.
I'm sending it to the 3D printer today, and may be able to get the parts back tomorrow for test fitting! ![]() And some cool X-ray photos! ![]()
#80 |
Prototypes almost there! Will be ready tomorrow morning.
![]() ![]() [img] [/img]
#81 |
Prototype has finished printing! On their way to me now. I hope it fits
| The Following 5 Users Say Thank You to Drambeenie For This Useful Post: | Andrew025 (08-18-2017), derekbrz24 (08-18-2017), OND (08-18-2017), tehShirt (08-18-2017), VIP BRZ (08-18-2017) |
#82 |
Drives: 2014 Subaru BRZ
Those do look really good, if its fits on par a little sanding and paint and those'ull look OEM
I'm impressed with this project! |
| The Following User Says Thank You to VIP BRZ For This Useful Post: | Drambeenie (08-18-2017) |
#83 | |
#84 |
Drives: between cars...
This is awesome! I'm Beyond impressed. I love people who have an idea, go out and execute it. I can't wait to see the finished product.
| The Following User Says Thank You to imnotsureaboutbrz For This Useful Post: | Drambeenie (08-18-2017) |
| Tags |
| removal, spoiler, trunk, wing |
| Remove trunk spoiler clips? | Drambeenie | Member's Car Journals | 0 | 05-09-2017 11:31 PM |
| 2017 BRZ Limited Spoiler | Chayce808 | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 01-04-2017 12:49 AM |
| 2017 BRZ without spoiler? | vroomvroom1 | BRZ First-Gen (2012+) — General Topics | 9 | 07-18-2016 10:46 AM |
| Remove spoiler for Rocket Bunny one? | xrinnenganx | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 10-21-2014 10:28 AM |
| Is there a way to remove the spoiler? | rapier7 | BRZ First-Gen (2012+) — General Topics | 15 | 08-21-2013 10:58 PM |
