Old 08-14-2017, 02:49 PM   #71
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
Originally Posted by tehShirt View Post
Looks great, excited to see the printed part! Just curious, but could you possibly use the same setup on the bottom as top, with the threaded inserts and then use a threaded stud?
Thanks man! That's an interesting idea. I suppose we could do technically do that but with only one of the top bolts BC there's room underneath it, but for the back screw there's not much room to insert anything but the threaded insert.
The 3D print will include a thread to screw into so there will be a mechanical lock and not just a hole with epoxy.
Drambeenie is offline   Reply With Quote
Old 08-14-2017, 06:05 PM   #72
Gunman
Drives: 2019 Mazda Miata RF
Can you use threaded inserts, and bolt in from the bottom?
Also, with your rapid prototype system, can you grow the inserts into the part?
The Following User Says Thank You to Gunman For This Useful Post:
Drambeenie (08-14-2017)
Old 08-14-2017, 10:52 PM   #73
Drambeenie
Drambeenie's Avatar
Re: Threads: That would certainly be a possible if this bond isn't strong enough.
I believe there are 3D printers that can print multiple materials, but we wanted to make sure we could use bolts/nuts/washers that are easily sourced that are produced with a certain quality of metal that has a measured performance.
I think the overarching theme of these questions might be it's strength. The 3D part is going to be printed with a high quality machine using the SLS process. (More common 3D printing is like a hot glue gun building layers - we're only going to use that for the prototype for test fitting)
The material we're going to use is Glass Reinforced Nylon, which is commonly used in Automotive Applications. The epoxy strength is going to be extremely strong. Some say that the epoxy we're planning on using is so strong, the entire part would fail before the epoxy does.
So we'll prototype with the cheap 3D printing process everyone is familiar with, then for production part we'll use Glass Nylon.
The shape of the part, plus the 2 mil thickness for the walls, plus an inner structure, plus the material is going to make an extremely strong shape. Probably overkill if you ask me, but I'd rather overkill than it flying off and actually killing
The Following User Says Thank You to Drambeenie For This Useful Post:
tehShirt (08-15-2017)
Old 08-15-2017, 09:54 AM   #74
Drambeenie
Drambeenie's Avatar
Inner structure added - Ready to print Prototype.
The Following 3 Users Say Thank You to Drambeenie For This Useful Post:
spike021 (08-16-2017), tehShirt (08-15-2017), VIP BRZ (08-15-2017)
Old 08-15-2017, 10:02 AM   #75
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
tehShirt is offline   Reply With Quote
The Following User Says Thank You to tehShirt For This Useful Post:
Drambeenie (08-15-2017)
Old 08-15-2017, 11:54 AM   #76
Gunman
There are, but I know our Fortus FDM machine can be paused during the build cycle, to have inserts installed, and then continue on. We have not done it yet, but have discussed parts that we may try this.
The Following 2 Users Say Thank You to Gunman For This Useful Post:
Drambeenie (08-15-2017), wparsons (07-12-2019)
Old 08-15-2017, 12:09 PM   #77
Drambeenie
Drambeenie's Avatar
That would be insanely cool. You could try it with a simple bolt inside of a ball.
Old 08-15-2017, 06:33 PM   #78
Gunman
http://usglobalimages.stratasys.com/...17955260207297
Drambeenie (08-16-2017)
Old 08-16-2017, 10:39 AM   #79
Drambeenie
Drambeenie's Avatar
Looks like we're almost at the finish line! Wanted to add a little flair to the bottom before sending it to the 3D printer - Nice and polished.
I'm sending it to the 3D printer today, and may be able to get the parts back tomorrow for test fitting!
And some cool X-ray photos!
The Following 5 Users Say Thank You to Drambeenie For This Useful Post:
Gunman (08-16-2017), spike021 (08-16-2017), tacos (08-16-2017), tehShirt (08-17-2017), VIP BRZ (08-16-2017)
Old 08-17-2017, 12:28 PM   #80
Drambeenie
Drambeenie's Avatar
Prototypes almost there! Will be ready tomorrow morning.
[img][/img]
2slo4u (08-18-2017), Gunman (08-17-2017), spike021 (08-17-2017), tacos (08-17-2017), tehShirt (08-17-2017)
Old 08-18-2017, 10:43 AM   #81
Drambeenie
Drambeenie's Avatar
Prototype has finished printing! On their way to me now. I hope it fits
Andrew025 (08-18-2017), derekbrz24 (08-18-2017), OND (08-18-2017), tehShirt (08-18-2017), VIP BRZ (08-18-2017)
Old 08-18-2017, 12:12 PM   #82
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
Those do look really good, if its fits on par a little sanding and paint and those'ull look OEM
I'm impressed with this project!
VIP BRZ is offline   Reply With Quote
The Following User Says Thank You to VIP BRZ For This Useful Post:
Drambeenie (08-18-2017)
Old 08-18-2017, 01:12 PM   #83
Drambeenie
Drambeenie's Avatar
Thanks so much man! OEM look is what I was going for! This 3D print was done using the FDM process which is great for prototyping but not so great for final product. Below is an example of FDM vs SLS. We'll use SLS for the final product and used FDM just to test fit the part.
The Following 2 Users Say Thank You to Drambeenie For This Useful Post:
tacos (08-18-2017), tehShirt (08-18-2017)
Old 08-18-2017, 02:30 PM   #84
imnotsureaboutbrz
Drives: between cars...
This is awesome! I'm Beyond impressed. I love people who have an idea, go out and execute it. I can't wait to see the finished product.
imnotsureaboutbrz is offline   Reply With Quote
The Following User Says Thank You to imnotsureaboutbrz For This Useful Post:
removal, spoiler, trunk, wing
Remove trunk spoiler clips? Drambeenie Member's Car Journals 0 05-09-2017 11:31 PM
2017 BRZ Limited Spoiler Chayce808 Cosmetic Modification (Interior/Exterior/Lighting) 6 01-04-2017 12:49 AM
2017 BRZ without spoiler? vroomvroom1 BRZ First-Gen (2012+) — General Topics 9 07-18-2016 10:46 AM
Remove spoiler for Rocket Bunny one? xrinnenganx Cosmetic Modification (Interior/Exterior/Lighting) 7 10-21-2014 10:28 AM
Is there a way to remove the spoiler? rapier7 BRZ First-Gen (2012+) — General Topics 15 08-21-2013 10:58 PM
