Old 08-17-2017, 06:38 AM   #1
zypher10
zypher10's Avatar
Drives: GT86
Wheel wobble
Hi guys,
So my front left wheel wobbles.
The lugs are on tight and it's hub centric. I've tried swapping the wheel from the other side but it does the same thing.
Had the aligment done few weeks ago.
Here is a video of the wobble
Any ideas?
zypher10 is offline   Reply With Quote
Old 08-17-2017, 08:22 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Swapping out wheels strikes it itself as culprit. Check suspension / bearings / bushings.
Old 08-17-2017, 09:07 AM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Sounds like a bad hub/wheel bearing.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 08-17-2017, 09:46 PM   #4
zypher10
zypher10's Avatar
Drives: GT86
Thanks guys ill get it looked at.
Old 08-17-2017, 10:19 PM   #5
jvincent
jvincent's Avatar
Originally Posted by zypher10 View Post
Any ideas?
Do you have coilovers?
If yes, check that the locking collars are tight.
Old 08-17-2017, 10:39 PM   #6
Impureclient
Drives: 2015 FR-S
If you have spacers, one stud going through the spacer may be slightly longer and touching the back of the rim. Mine did exactly what your video shows and it was the stud.
Fix was to either shave stud down or grind a little into the wheel backside.
Old 08-18-2017, 04:17 PM   #7
wparsons
wparsons's Avatar
Hold on a second... when you say you tried the other side and it does the same thing, do you mean that putting the wheel on either side shows the same wobble, or putting any wheel on the left front shows the wobble?
If the wobble follows the wheel you either have a bunch of crap on the back of the wheel so it's not seating flat against the hub or you have a bent wheel.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Tcoat (08-18-2017), Ultramaroon (08-18-2017)
Aftermarket pulley wobble with video killconey Engine, Exhaust, Transmission 62 02-15-2017 03:23 PM
Wobble FRSure Issues | Warranty | Recalls / TSB 21 07-03-2016 04:23 AM
Winjet wobble beaver_scott Cosmetic Modification (Interior/Exterior/Lighting) 27 12-16-2015 12:48 PM
Weird wobble on acceleration ReaperX43 Issues | Warranty | Recalls / TSB 19 10-04-2014 02:02 AM
Spacers and wheel wobble. Chen Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 06-30-2014 03:12 PM
