Old 02-10-2014, 04:43 PM   #1
beaver_scott
beaver_scott's Avatar
Drives: 2013 FRS hot lava
Winjet wobble
I just got a set of winjet headlights today. While I was checking them out I noticed that the right headlight projector seems to have a tiny bit of play. Anyone else with winjets experience a small amount of "looseness/play" with the projectors?
beaver_scott is offline   Reply With Quote
Old 02-10-2014, 07:11 PM   #2
vestal52
vestal52's Avatar
Drives: Whiteout FRS
Yeah, seems to wobble a bit for many other headlights as well, but that's fine.
Aslong as the alignment of the beam doesn't mess up while your driving you should be fine. retrofitted some projectors on mine since I hated the ones that came with it and holds well, wobbles a bit but sits properly in there without play while driving
vestal52 is offline   Reply With Quote
Old 02-10-2014, 08:34 PM   #3
636
636's Avatar
Drives: '23 CWP BRZ
Ziptiez. I ziptied mine down and it stays great!
636 is offline   Reply With Quote
Old 02-10-2014, 08:36 PM   #4
beaver_scott
Ziptied? Howd you ziptie the projector?
The Following User Says Thank You to beaver_scott For This Useful Post:
86-tundra (02-11-2014)
Old 02-10-2014, 10:57 PM   #5
vestal52
vestal52's Avatar
not needed..
Old 02-11-2014, 12:52 AM   #6
636
636's Avatar
Drives: '23 CWP BRZ
Haha, I misunderstood the question.
If you're talking about loose as in "bouncy," they're no bouncier than stock. The cutoff is just a LOT sharper, so it looks like they are looser, but you'll get used to it.
Old 02-11-2014, 02:47 PM   #7
beaver_scott
Bouncy....well its the projector itself that seems to have play. If i grasp the back of the projector and wiggle it or shake the whole light assembly, the projector moves a bit and makes a light clunk noise like something might be loose.
Old 02-11-2014, 04:20 PM   #8
beaver_scott
I played with the driver side light a bit. It does the same thing. Since the movement is so minimal I'm going to assume its normal and I am just too anal. I'll check the stock lights when I pull them out.
Old 02-11-2014, 05:23 PM   #9
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
If you notice shake in the project's cutoff, then that is wrong. IE you're driving on a bumpy road and your cutoff moves up and down independent of your travel.
you can usually prevent shake in the cutoff by tightening the projector. not sure how it works on the winjet, speaking from experience with other retrofits
86-tundra is offline   Reply With Quote
Old 02-11-2014, 08:21 PM   #10
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
This is very common with spyder aftermarket lights on many platforms too, one easy solution is to apply 3m weatherstripping to the bottom of the lights. (The 3m weatherstripping comes in a 8' roll for around $30.00 with tape already applied to one side.) Stick it to either the bottom of the bumper or the bottom of the light, this will stiffen up the lights, and dampen any vibrations. The weatherstripping can be found at any auto parts store. A lot of times it is due to the plastic housing, cheaper/less plastic, ect.
The Following User Says Thank You to Kiske For This Useful Post:
beaver_scott (02-11-2014)
Old 02-11-2014, 10:00 PM   #11
wparsons
wparsons's Avatar
^^ It sounds like it's the actual projector inside the housing that is loose, not the whole housing bouncing around in the car?
flickr
Old 02-11-2014, 10:02 PM   #12
beaver_scott
Bingo! Not very loose but there is slight movement.
Old 02-14-2014, 03:55 PM   #13
sidnacious
sidnacious's Avatar
Drives: Argento FR-S
Just got mine earlier this week and I'm having the same issue on the passenger side headlight. My beam of light bounces up and down everytime I hit a bump or crack on the road. Anyone know if this is covered under Winjet's warranty?
sidnacious is offline   Reply With Quote
Old 02-14-2014, 04:24 PM   #14
beaver_scott
Winjet wobble
Crap. Guess I better hold off on installing mine until I figure out how to tighten the projector. I don't want bouncy lights!
Crank Pully Wobble... With video Norcalmav23 Engine, Exhaust, Transmission 33 09-25-2019 07:26 PM
Wobble, falling apart, loose joints? imravenit Issues | Warranty | Recalls / TSB 25 03-29-2015 10:02 PM
Winjet HID Size? Jeremehh Cosmetic Modification (Interior/Exterior/Lighting) 9 03-10-2014 02:28 AM
FS: Winjet Chrome Headlights civicdrivr Exterior Parts (Aero, Lighting, Etc.) 6 01-16-2014 11:33 PM
Custom Purple Winjet and Black Winjet Headlights xclusive_brett Cosmetic Modification (Interior/Exterior/Lighting) 35 12-17-2013 08:28 AM
