#43 |
Drives: 10 VW GTI
It is here. http://www.ft86club.com/forums/showthread.php?t=8374
It's the BRZ version but I believe the scion version is the same. |
#44 |
Senior Hoonigan
Drives: 2016 Hot Lava 6MT FR-S
Actually, I am wrong. The first item in the "under the hood" section is "check ATM fluid levels". When I glossed over this earlier my mind read "check tranny fluid levels".... So yeah, it stands to reason that the dealer may not check the levels on an MT, given its bolts that need to be undone - unless its in the "on the hoist" section. I can't confirm as I'm away from my PC. Sent from my Galaxy Nexus using Tapatalk 2
2016 Hot Lava 6MT FR-S, Surrey, BC Canada
#45 | ||
Drives: Ducati R Corse
#46 | |
Drives: It's Slow but it Handles.
sounds fishy...
#47 | |
There would be remnants of oil if it drove 600 miles. I had a shotty shop and warranty company change out my trans several times. On one occasion, they put the trans back in with no oil (it was used and had whatever oil was sitting in it that wasn't drained out; new trans still have oil on the internals when assembled). I made it all of 23 miles before it burned up and seized. This was 7 years ago and I still remember it. Pissed me off because I had to buy a New trans for my car since both the selling dealer and warranty went bankrupt.
#48 | |
Drives: 10 VW GTI
(Not-so-related: When my friend got the FRS, the radio was not in yet. I can see there was a stamp on a steel beam inside. The stamp showed a Japanese surname (some like 清水) and a date mark. I think that can be a QC mark) |
#49 |
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
It's clear that there is more going on than a simple "it didn't have oil", it clearly had some, maybe not enough. Maybe some leaked out, maybe there were other issues.
Whoever has the car now will check what is wrong and fix it, and if there is something fishy going on, I hope Toyota will check into it further, or that it has been reported to the correct people. (In Canada this would be done via an FPR, and probably followed up on by Toyota). As for checking the fluid on the PDI sheet, I didn't just assume it wasn't on there, I looked up the PDI sheet and checked before posting. Jeff
![]() 2011 Lexus IS350 F-Sport 6MT with LSD 1986 Toyota Corolla GT-S Supercharged |
#50 |
Drives: 13 HotLava FRS, 93 4Runner, 97 Taco
Update: The new tranny came in and our techs installed it. I was able to grab a pic while they were finishing up. The tech was topping off the tranny with fluid to make sure there was enough in there so this wouldn't happen again.
![]() I did talk to the tech a little and he said there was a little bit of oil in the old tranny but no where near the amount required. He said maybe around a quart of fluid if that. He also said that the transmission is very light for a transmission. He was surprised as to how little it weighed. There were no signs of the fluid leaking out. The undercarriage was very clean where if there was fluid in the transmission and a seal was bad, there would be oil all over the place under the vehicle or at least visible spots where it was leaking. I think the owner should be able to pick his car up and enjoy it like he expected to the first time around. Ruskymx |
| Tow hook specs? | mufasis | BRZ First-Gen (2012+) — General Topics | 15 | 10-21-2012 10:41 PM |
| Tow-hook license-plate template? | TuxedoCartman | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 06-24-2012 12:51 PM |
| Whiteout FR-S At Kenshaw | rL-gT | CANADA | 17 | 05-26-2012 05:06 PM |
| Whiteout FR-S/86 | just86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 15 | 04-01-2012 01:16 AM |
| Delete | driver01 | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 03-28-2012 12:32 PM |
