Old 08-16-2017, 12:54 PM   #99
ThisGuyIKnow
Perpetual Noob
ThisGuyIKnow's Avatar
Originally Posted by johan View Post
Get the velcro made for attaching to vinyl. It's actually made for automotive: https://www.amazon.com/VELCRO-Brand-...utomotive&th=1
Be sure to buy the 2' tape one, it's a MUCH better value than the 3 1/2" strips (it's a freaking rip off!). Then you just cut the pieces you need with scissors.
One box should be all you need - and you should be able to Prime it in time for the weekend.
Awesome. Ordered. Prime ONE day even. Thanks johan.
"People are the worst drivers in the world."
ThisGuyIKnow
ThisGuyIKnow is offline   Reply With Quote
The Following User Says Thank You to ThisGuyIKnow For This Useful Post:
johan (08-16-2017)
Old 08-21-2017, 05:18 PM   #100
ThisGuyIKnow
Perpetual Noob
I got the passenger door done Saturday with CLD, MLV and a Rockford Fosgate woofer. I'm a *little* bit proud of myself. Never taken apart anything on any vehicle. Not so scary now.
ThisGuyIKnow
Old 08-22-2017, 05:25 PM   #101
ThisGuyIKnow
Perpetual Noob
CCF Sources
I'm finding closed cell foam slightly difficult to find, let alone at a good price, but I found this schtuff at walmart.com:
1/8" closed cell foam for $43.20. That should work... right? Of course I don't need 300ft² though, but it's cheaper than any other place I've found, especially with the free shipping.
ThisGuyIKnow
Old 01-04-2018, 08:36 AM   #102
nalc
Drives: 13 BRZ Limited 6MT GBS
Thanks for all of the great feedback everyone. I'm not on here often any more, so if you've got a question, you are probably better off posting in the thread in addition to PMing. If you PM me, I will get back to you, but it could be weeks or months.
Good luck out there, guys!
nalc is offline   Reply With Quote
The Following 2 Users Say Thank You to nalc For This Useful Post:
Bonburner (09-25-2018), Lav (04-16-2022)
Old 03-18-2018, 06:07 AM   #103
Joveen
Joveen's Avatar
Drives: Bone stock
This is some good info for when I start my project. Thanks.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Joveen is offline   Reply With Quote
Old 06-15-2018, 04:11 PM   #104
T0rt0r0
Drives: European gt86
Thanks for all theses pictures and the great walk-through !
I'm currently doing something similar to my gt86 and was wondering if anyone knows which component is the aluminium box near the rear speaker ?
Is it safe to have some closed cell foam close to it (touching it ?)
Thanks !
T0rt0r0 is offline   Reply With Quote
Old 06-15-2018, 04:17 PM   #105
MarvinC93
Drives: 2016 Subaru BRZ Limited MT
Originally Posted by T0rt0r0 View Post
I'm currently doing something similar to my gt86 and was wondering if anyone knows which component is the aluminium box near the rear speaker?
Is it safe to have some closed cell foam close to it (touching it?)
I’m not sure what it is exactly off the top of my head but it kinda looks like something that might generate/conduct heat since it looks similar to amps/DSPs so I would personally stay away from putting any CCF on it.
MarvinC93 is offline   Reply With Quote
The Following User Says Thank You to MarvinC93 For This Useful Post:
T0rt0r0 (06-16-2018)
Old 06-16-2018, 04:03 AM   #106
T0rt0r0
I agree but still can't find which function it has
The Following User Says Thank You to T0rt0r0 For This Useful Post:
jkamelo (12-06-2022)
Old 06-18-2018, 01:06 PM   #107
T0rt0r0
After some searches, the part is 22648aa200 and it's the fuel pump control module
The Following 2 Users Say Thank You to T0rt0r0 For This Useful Post:
DreamSpeedBRZ (02-12-2020), vintagemxer (10-04-2020)
Old 10-03-2020, 03:04 PM   #108
zippee
Guest
Posts: n/a
I know this is an old thread but could someone refer me to:
1)where to get these large sheets of MVL (or make and model)
2)thinsulate thickness (or make and model) used?
I see offerings on ebay and amazon but there's so many brands and dimensions etc.
Many thanks
Old 09-29-2021, 11:00 AM   #109
alphasaur
friendly
Drives: 17' 86
This thread was immensely helpful!
Thank you!
For anyone that is sort of interested in this undertaking, I ended up doing it and it took me about two full days between installing front speakers, sub, amp (including wiring etc). I didn't want to gain too much weight so I used 1/2lb MLV from amazon https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Noico CCF (this stuff is really light)
Amazon basics deadener
I also used these behind the front 6.5" speakers. I placed the amazon CLC under it and created a little platform for it to sit on. I used black silicone gasket maker to paste it on, worked great.
Getting a little roller for the CCF and CLC was also pretty useful, but not NEEDED.
I did not deaden as thoroughly as op. I used CLC in the trunk. Both doors I used CLC, CCF and MLV. Passenger side & tranny tunnel some CLC, full MLV and CCF. Rear bench some clc, a sheet of ccf on each seat. Used ccf and MLV on tunnel on rear bench. Driver side I just used some ccf.
Sound has been totally transformed and the cabin is actually a different place right now. Gained about ~40-45lbs from deadening materials.
Would recommend 10/10.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
The Following 3 Users Say Thank You to alphasaur For This Useful Post:
BRZedsDeadBaby (12-13-2021), GPhilly (03-28-2022), Lav (04-16-2022)
Old 09-29-2021, 12:15 PM   #110
Joveen
Joveen's Avatar
Drives: Bone stock
Just need to get some weight reduction mods done and the 45lbs will even out.
Sent from my SM-G998U using Tapatalk
The Following User Says Thank You to Joveen For This Useful Post:
alphasaur (12-13-2021)
Old 03-28-2022, 10:53 AM   #111
GPhilly
GPhilly's Avatar
Drives: 2020 Subaru BRZ (Edelbrock SC)
What I did was take out all the tools + spare tire in the trunk. It might be 20-30 lbs but it helps offset the weight added from the material.
Did you put CCL or MLV on the rear quarter panels? I am not sure if I should fit material to the plastic panel or fill the tire well.
GPhilly is offline   Reply With Quote
FRS/BRZ Full Interior LED Kit! Choose your brightness! See Installed Comparison Pics! Diode Dynamics Interior Parts (Incl. Lighting) 243 08-29-2018 12:01 PM
What are you using for sound deadening ? mashal Electronics | Audio | NAV | Infotainment 108 11-06-2015 12:51 PM
SOUND DEADENING White64Goat BRZ First-Gen (2012+) — General Topics 7 04-22-2013 01:36 AM
Quarter Panel Deadening - factory deadening? l0aded Electronics | Audio | NAV | Infotainment 4 03-19-2013 07:19 PM
Sound deadening yomchi1989 Electronics | Audio | NAV | Infotainment 16 01-02-2013 02:08 PM
