Old 08-12-2017, 08:33 PM   #141
Tuxedo Tony
Drives: Frs
Are the version 3 tunes also updating the older models (13-16) as well as creating model year 17 tunes?
Tuxedo Tony is offline   Reply With Quote
Old 08-12-2017, 08:42 PM   #142
JermMX5
Drives: 2017 Toyota 86
Originally Posted by jvincent View Post
No, that's exactly what a MAF scaling issue looks like.
When you are open loop the MAF value determines how much fuel is delivered in order to hit the commanded AFR. The fact that the measured AFR is lower means that the MAF scaling is off.
Oh wow that would be amazing, then how would I go about scaling it? I just took a look and the MAF voltage was reading 0 all of my logs, is that normal?
2017 Toyota 86 - Whiteline 20mm Front Bar | Crash Bolts | 235/45/17 RE-71R | 17x7.5 OZ Omnia | OFT Stage 1 For Street Driving | Trackpipe for AutoX | Not enough camber.
JermMX5 is offline   Reply With Quote
Old 08-12-2017, 08:49 PM   #143
Darkrune
Darkrune's Avatar
Drives: 2017 86
It probably has more to do with the miata having a stronger install base.
Sent from my SM-G935V using Tapatalk
Darkrune is offline   Reply With Quote
Old 08-12-2017, 08:56 PM   #144
jvincent
jvincent's Avatar
There's a long thread that's worth reading a couple of times that @steve99 started.
http://www.ft86club.com/forums/showt...01#post1842501
One other note, if your MAF voltage is always zero you need to update your OFT.
Old 08-12-2017, 09:03 PM   #145
Somerandom18
Drives: 2017 manual BRZ
But the Miata sucks eggs.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 08-12-2017, 09:45 PM   #146
JermMX5
My OFT updated the first day I got it and plugged it in to my computer, all of my logs have showed 0 on the MAF voltage, is there somewhere I can go for the latest update?
My HW version is 03.35 and FW 01.45
And CD: P9029
Old 08-12-2017, 10:45 PM   #147
nocoolname
Are you logging maf voltage? Go through the mag scaling thread and run it through the vgi mag scaler. What are your fuel trims like?
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily
2013 BRZ limited - new toy
nocoolname is offline   Reply With Quote
Old 08-12-2017, 10:56 PM   #148
JermMX5
Ya I'm logging it, but in all my logs it comes up as zero. So I don't think I can run it through the scaler without that?
And they look like LTFT is almost always 2.34 during WOT pulls with no STFT
Old 08-12-2017, 11:19 PM   #149
JermMX5
*Nevermind I was using the compare tool before and it left the offset one up the actual two tables are here:
Double posting because I found something odd. There are only 9 tables different between the Stage 1 and the Stock tune and here is one of them. Could the Stage 1 values be flipped?
Old 08-13-2017, 03:11 AM   #150
steve99
Drives: FT86
And CD: P9029
If its K00c rom the logging ram address is likely incorrect you will need to contact the oft guys
Old 08-13-2017, 03:15 AM   #151
steve99
Drives: FT86
Attachment 157054
Attachment 157049
AF learning limits ie LTFT are normally +/- 40%
Im not sure what defs you using but it might be a scaling/display issue as the 40% may be represented as 0.4 instead of 40%
or it might be a typo
diff between 40 and 4 is 36, hard to know without seeing roms and defs
Old 08-13-2017, 10:19 AM   #152
Darkrune
Darkrune's Avatar
Drives: 2017 86
Nothing about this 2017 support has been smooth. Looks like they find the cheapest least time consuming method to make this functional. Tunes are ok, better than stock, but not great.
Old 08-13-2017, 04:14 PM   #153
Jasonb
Drives: 17 Series Yellow BRZ
So it seems that maybe for the 2017's we may be better off just Dyno tuning with ecutek? I have a 2017 and want to get the OFH and OFT but the 2017 support seems lacking.
Jasonb is offline   Reply With Quote
Old 08-13-2017, 04:40 PM   #154
invaliduser
Drives: 2017 86
I haven't seen where Dyno tuning with any tuner on a 2017 is very effective.
invaliduser is offline   Reply With Quote
OpenFlash Tablet: Multiple Data Log files! Shiv@Openflash Software Tuning 95 11-09-2017 08:40 AM
OpenFlash Tablet: OTS v2.0 Beta (132 new maps, 12 new XMLs) Available for Download Shiv@Openflash Software Tuning 1062 08-13-2017 04:13 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet v1.55b: BIN files added! Shiv@Openflash Software Tuning 525 04-09-2014 09:42 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
