Old 08-11-2017, 02:32 PM   #1
Ornelas66
Drives: 2015 Scion FRS
Motor Mount Problem
I have a 2015 FRS (Manual). When I shift into 1st or Reverse, and start to let out the clutch, I hear a clunk. I checked my suspension and all the bushings and other parts look fine. The lifted the front end, and the wheels do not wiggle side to side, or up or downs. However, if I put the hand brake and start to release the clutch, the motor does move, and that clunk sound returns. I suspect that I have a bad motor mount.
Has anybody else had this issue? The car only has 30k miles and HAS NOT been raced or abused.
Dealership does not want to fix this item under warrantee.
Does anybody have any advice and/or has gone through the same thing?
Ornelas66 is offline   Reply With Quote
Old 08-11-2017, 06:11 PM   #2
Nope, I haven't had this issue.
However, I doubt that a busted motor mount would allow the engine to make a "clunk" sound.
Where does it sound like the sound is coming from .... ?? Front or rear of the car ... ??
I would speculate your "clunk" sound is coming from somewhere in the drive train (not the engine).
I hope you get it sorted out.
Old 08-13-2017, 12:35 AM   #3
ryoma
ryoma's Avatar
is it the overpipe hitting the subframe? what mods do you have on the car?
motor mounts, non warrantee issue
FS: STI Motor Mounts + Transmission mount toeout Engine, Exhaust, Bolt-Ons 6 04-25-2017 11:13 PM
Perrin Motor Mount Kit 00vsmcoupe Engine, Exhaust, Bolt-Ons 1 04-03-2016 11:48 AM
Help! Need torque specs for motor mount Pele86 Engine, Exhaust, Transmission 5 08-05-2013 05:24 PM
Trans/Motor Mount question DanoFA20 Engine, Exhaust, Transmission 5 03-02-2013 04:16 PM
new small problem with window motor sweeney208 Issues | Warranty | Recalls / TSB 8 02-27-2013 11:57 AM
