Old 08-07-2017, 09:28 PM   #1
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Verus Engineering Billet Transmission Beta Tester Run
Over the past two years we have been working with a gear manufacturer on a fix to the 3rd and 4th gear stripping/shredding issue. Along the way we have found other issues with the transmission while learning quite a bit about the transmission in the process. We are to the point where we are interested in doing a round of Beta testers, as we have hit a point where the (3) initial units are in cars, running, and everything is pointing in a positive direction.
There are two major issues with the transmission we have fixed:
1) 3rd and/or 4th gear has proven to strip/shred at about 300wtq. This is a result from the engine’s torque overcoming the gear’s ability to handle the forces.
2) 4th gear’s retaining mechanism will break reverse gear’s teeth due to the thrust load placed on 4th
We are able to fix both of these issues with the gearset. By improving the gear profile, producing it from a chomoly steel, and properly heat treating the gears, we’re able to improve the gear’s strength by an estimated 250-300%. With the gear profile being straight-cut, the thrust load from 4th gear is no longer there to break the reverse gear’s teeth.
What the kit Includes:
• Replacement output shaft with 3rd and 4th machined directly onto it
• Replacement 3rd and 4th gear
• Straight cut gears to eliminate thrust load
• Replacement counter-shaft bearing > Tapered Roller Bearings
• Replacement outter race bearing
• Various shims to shim counter-shaft
Everything is produced in the USA by a company in Illinois!
What testing has been done thus far?
1) Car One, Velox Shop Car
a. 3,500 miles
b. ~400whp, 320wtq, Full-Race 7163 Turbo Kit
c. Multiple disassemblies with gearset and bearings looking good
d. Disassembly will happen again shortly for carbon synchro install Thread for these located here
2) Car two, Marin Nelson
a. ~9,000 miles over the past two years
b. ~5,000 miles with the most recent bearings
c. 400+whp, 300+wtq, JDL 3071 Turbo Kit
d. Very hard on his car/gearset
e. Broke 5 transmission by the time he tried ours
3) Car three, Jose Santos
a. ~1,000 miles on his car
b. 400+whp, 300+wtq AVO setup
What we are interested in:
• We are looking for 3-5 beta testers who are interested in trying this gearset out
• We are offering these at $3,000 including labor
o We require a, in good shape, transmission
o If you would like to replace the synchros, we can do that at this time for the cost of the synchros from Toyobaru (~$150 IIRC)
o Even better, install the carbon synchros that are going to be available shortly! Thread for these located here
Why isn’t this going to production?
While we have multiple cars testing these units thus far, we have had a long road to get to this point. The OE bearings are not designed to handle the loads and we went through (3) styles of bearings to get to the most recent setup. We have done away with quite a bit of the OE transmission and before doing a larger run, we want to get some more testing with other vehicles/setups.
Terms:
• 50% payment required up front
• 50% due when the transmission ships
• Shipping a full transmission to and from Velox is on you
Warranty:
We cannot offer a warranty on these parts. Please be prepared for this. We are only the company that has been helping develop this kit and helping implement these into the market. *We are making no money on these at this price point for the beta testing!* We cannot make any longevity, reliability, or durability claims at this time.
Please feel free to ask any questions below.
Those interested, please send an e-mail to sales@velox-motorsports.com regarding your setup, dyno, etc.
Thank you,
Eric
VerusEric is offline   Reply With Quote
The Following 16 Users Say Thank You to VerusEric For This Useful Post:
ATL BRZ (08-08-2017), Bonburner (11-06-2017), Code Monkey (01-08-2018), CxG (01-12-2018), ichitaka05 (08-14-2017), Lonewolf (08-08-2017), R2RO (01-08-2018), Ravenna (08-09-2017), sato (04-26-2020), Sportsguy83 (08-08-2017), ThatAsianBradah (02-12-2018), The Racers Line (08-08-2017), TkTk (08-11-2017), TRACE_on (08-09-2017), weederr33 (08-09-2017), wparsons (08-07-2017)
Old 08-07-2017, 09:37 PM   #2
oSoSlow
Drives: 2014 SWP brz
I would like to be a beta tester. I emailed you earlier today.
Been waiting on this day for a long time. I can probably drive the trans to you
Do you need specs on the car?
oSoSlow is offline   Reply With Quote
Old 08-07-2017, 10:14 PM   #3
wparsons
wparsons's Avatar
You can probably just stop the testing with Marin... if he doesn't break one, I doubt anyone will.
I'm no real help, stock power won't be good testing.
flickr
Old 08-07-2017, 11:00 PM   #4
oSoSlow
Was making 420 ft tq when my trans let go on the dyno.
Old 08-08-2017, 12:06 AM   #5
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
If I didn't already have a PAR set in mine I would definitely test these out. I really hope you guys have positive results with these sets, would be a great alternative to have to get a set shipped from Australia if I have any issues with mine.
@VeloxEric, will you guys offer a torque rating for these when the time comes for production? Are you going to have a full 1-5 set at all? What about shift forks?
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 08-08-2017, 09:24 AM   #6
celek
Resident Gear Head
celek's Avatar
hmmm what to do with my spare trans....
celek is offline   Reply With Quote
Old 08-08-2017, 10:20 AM   #7
VerusEric
VerusEric's Avatar
Yes, please shoot them over to us in e-mail. You being close helps.
He went through 4-5 different bearings, each lasting about 1000-2000 miles. He is incredibly hard on the car. However, he made quick work of sub-par bearings. I had to have torn that transmission apart no less than 5-6 times.
Torque rating is a difficult number to approach. The forces the gears see depends on a lot of factors, including tires, drive shaft, and clutch used. We estimate it at 2-3xs factory torque, which would put it around 600-900wtq capable.
We haven't seen a need for shift forks but I may be missing something?
Thanks,
Eric
The Following User Says Thank You to VerusEric For This Useful Post:
wparsons (08-08-2017)
Old 08-08-2017, 06:30 PM   #8
TRACE_on
TRACE_on's Avatar
Drives: 2023 GR86 - Track BRed Premium 6M
Man I am all about this once it goes into production. I am about to get my FR-S back with a built motor and 59mm turbo so I suspect I will need the upgrade sooner than later lol.
STR also-ran
TRACE_on is offline   Reply With Quote
Old 08-08-2017, 08:34 PM   #9
Drakiv
Project Shadow
Drakiv's Avatar
Thanks,
Eric
I don't think you are missing anything, I'm just looking at factors that may be something that hasn't come up yet. Most of the individuals needing better transmissions are running fairly high horsepower and no one has enough R&D on these transmissions with that amount of horsepower yet to see the full effects. I have heard that if you are hard shifting during a race event with high power running through the gears that the shift forks can see some abuse and the oem piece isn't really designed for that as you know. I believe Jacks Transmissions has developed and sells a shift fork for 3-4. Just something to think about is all as a complete package. You know me, I wouldn't steer you wrong lol.
614whp/421tq on E85
Instagram: Drakiv
The Following User Says Thank You to Drakiv For This Useful Post:
VerusEric (08-10-2017)
Old 08-08-2017, 11:49 PM   #10
Turdinator
Señor Member
Turdinator's Avatar
Interesting that the stock bearings are a week point.
How are the noise levels with the straight cut gears?
1974 TA22 Celica
2013 86 GT
Old 08-09-2017, 04:28 AM   #11
Ravenna
Ravenna's Avatar
Drives: Raven 2013 Scion FR-S
This makes me so happy to hear that you guys are finally developing a solution to the transmission issues I read so much about. I've been going back and forth on whether to turbo this engine (and what my goals are strictly dependent on the weakness of the stock trans) or just LS/2J swapping it. I really didn't want to swap because of the cost, time, and weight balance/CoG differences and didn't want to compromise the great handling. There are so many power solutions for the engine in the forms of amazing FI kits and built blocks, CF driveshafts, high hp axles and diffs, with the glass TRANS being the one thing that seemed to ruin the whole upgraded package. Now I can start looking at larger turbo kits and higher hp and up my whp goals another 100-150whp, where I initially wanted it. Thanks Velox!! I'll be stalking this development like a wild jungle cat.
The car has become a secular sanctuary for the individual, his shrine to the self, his mobile Walden Pond. ~Edward McDonagh
Ravenna is offline   Reply With Quote
The Following User Says Thank You to Ravenna For This Useful Post:
Old 08-09-2017, 01:51 PM   #12
TRACE_on
TRACE_on's Avatar
This!
STR also-ran
Old 08-09-2017, 02:49 PM   #13
fika84
fika84's Avatar
Another outstanding product being developed by @VeloxEric . Way to take the bull by the horns and create these awesome solutions to common problems!
fika84 is offline   Reply With Quote
Old 08-10-2017, 10:35 PM   #14
Dipstik-sportech
Dipstik-sportech's Avatar
What about a car near 400wtq and over 500whp?
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 10:15 AM
Verus' Shop BRZ - Development Thread VerusEric Member's Car Journals 266 12-19-2019 05:12 PM
Verus Engineering Carbon Thermoplastic Splitter Components VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 35 11-26-2017 06:23 AM
Beta Tester needed for E85 tuning in the San Antonio/Austin Area Dynotronics1 Southwest 2 12-31-2012 03:08 PM
