Old 08-10-2017, 12:59 AM   #197
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Why do you think they chose to not go with full 2.5" piping?
Originally Posted by weederr33 View Post
Let me rephrase that. I meant could the exhaust support the flow from a supercharger. I ask since it's only 60mm vs 63.5mm. Though I am very tempted to get it considering the ACE header is super expensive.
Originally Posted by humfrz
I'm old and lazy
Old 08-10-2017, 02:56 AM   #198
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Japanese noise requirements? Iono...
MS, CSCS, TSAC-F, CPT
Old 08-10-2017, 04:12 AM   #199
swarb
My guess is because metric.
Usually piping sold in 5mm increments, but marketed/manufactured in 10mm increments, 60/65/70/75/80, In merica' we use .25" increments- 2.25"2.5", 2.75", 3" Off by a mm or three, but close enough.
Usually 2mm(1/16") wall thickness.
The Following User Says Thank You to swarb For This Useful Post:
Clipdat (08-10-2017)
Old 08-10-2017, 07:19 AM   #200
Ashikabi
Ashikabi's Avatar
Beat me to it. It's a metric pipe. Also, 3.5mm is pretty close to an 1/8 inch. Not something I would spend money to upgrade to. If you need more diameter then you'll likely need a larger jump in diameter than that.
If HKS thinks it's good enough for their super charger I don't see why it wouldn't be good enough for a similar output turbo. Ace headers are supposed to be some of the best you can get though
The Following User Says Thank You to Ashikabi For This Useful Post:
Old 08-10-2017, 08:58 AM   #201
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Well my setup is 60mm(2.35") all the way front to back to keep the velocity speed constant. I think this is best if you are staying NA
If you are going forced induction I would jump up to 63mm(2.5") as you want to push out more volume, velocity is less of a concern.
Most exhausts coming from Japan (HKS ect.) are going to be 60mm, American exhaust companies will be 2.5"
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
Old 08-10-2017, 12:01 PM   #202
weederr33
weederr33's Avatar
Thanks for the info. I agree for more power I might as well go for a 2.5" exhaust. But that sound haha! I'll give it more thought. I found a local coater to get the header ceramic coated too (to give that mad velocity). Here's a clip of the exhaust if anyone is interested:
[ame="https://www.youtube.com/watch?v=FqiM2cz9v1g"]TOYOTA 86/SUBARU BRZ HKS SUPER EXHAUST SYSTEM LMS - YouTube[/ame]
Old 08-12-2017, 01:34 PM   #203
djezlee
Drives: 2017 BRZ Limited
I am a noob... just picked up my '17 BRZ last monday. I am thinking about picking up a HKS exhaust (Hi Power Spec L Cat Back Exhaust), but after doing a little research it looks like the pipes are 2-2.5 inches. Can I continue to use this cat back if I buy a turbo in the future? Is this wide enough to support hp gains?
-Lee
djezlee is offline   Reply With Quote
Old 08-12-2017, 01:53 PM   #204
SuperTom
SuperTom's Avatar
-Lee
They are 60mm which comes to 2.35". Im sure it will be fine with a turbo although a true 2.5" will be better. Read my post right above again.
I didn't go with the Hi Power Spec L even though it was light because you have to add some kind of diffuser or tray to take the place of the hole changing the stock muffler will leave behind. Its the case with any type of F1 or cannon style exhaust not covering the hole will be a big parachute area behind the bumper catching air. That's if you care about the aerodynamics built into the car.
Old 08-12-2017, 01:53 PM   #205
weederr33
weederr33's Avatar
-Lee
It depends on your goals and such. Obviously everyone will suggest 3" but it still should be OK.
Old 08-12-2017, 06:21 PM   #206
Ashikabi
Ashikabi's Avatar
-Lee
Since HKS offers a supercharger I wouldn't be concerned if you plan on a small turbo kit. If you are planning on making 400hp, then you'll want to go bigger
Old 08-12-2017, 06:25 PM   #207
djezlee
thanks great info!
Old 08-12-2017, 06:26 PM   #208
djezlee
Perfect! you rock!
Old 10-18-2017, 06:43 AM   #209
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
Does the Legamax Sports Cat-Back (Dual Tip) fit with the TRD rear bumper that is already set up for quad exhaust tips?
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 10-18-2017, 09:24 AM   #210
weederr33
weederr33's Avatar
It most likely will
exhaust, header, hi-power, hks, legamax
exhaust choices FloridaBRZ Engine, Exhaust, Transmission 4 01-26-2015 08:32 AM
UPGRADE-what are my exhaust choices cbennybrz Engine, Exhaust, Transmission 6 01-01-2015 07:45 PM
Exhaust Choices for FI rixter145 Engine, Exhaust, Transmission 4 09-11-2014 01:15 PM
Exhaust choices KonTheory Engine, Exhaust, Transmission 6 01-30-2014 03:28 AM
Help with Lug choices. feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 05-24-2012 08:19 PM
