#197 | |
Proud of BOXER
Drives: Subaru Boxer
Why do you think they chose to not go with full 2.5" piping?
#198 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Japanese noise requirements? Iono...
#199 |
My guess is because metric.
Usually piping sold in 5mm increments, but marketed/manufactured in 10mm increments, 60/65/70/75/80, In merica' we use .25" increments- 2.25"2.5", 2.75", 3" Off by a mm or three, but close enough. Usually 2mm(1/16") wall thickness. |
| The Following User Says Thank You to swarb For This Useful Post: | Clipdat (08-10-2017) |
#200 | |
If HKS thinks it's good enough for their super charger I don't see why it wouldn't be good enough for a similar output turbo. Ace headers are supposed to be some of the best you can get though |
| The Following User Says Thank You to Ashikabi For This Useful Post: | Clipdat (08-10-2017) |
#201 |
Drives: C5, GT-86, '24 Colorado TrailBoss
Well my setup is 60mm(2.35") all the way front to back to keep the velocity speed constant. I think this is best if you are staying NA
If you are going forced induction I would jump up to 63mm(2.5") as you want to push out more volume, velocity is less of a concern. Most exhausts coming from Japan (HKS ect.) are going to be 60mm, American exhaust companies will be 2.5"
| The Following User Says Thank You to SuperTom For This Useful Post: | Clipdat (08-10-2017) |
#202 |
Thanks for the info. I agree for more power I might as well go for a 2.5" exhaust. But that sound haha! I'll give it more thought. I found a local coater to get the header ceramic coated too (to give that mad velocity). Here's a clip of the exhaust if anyone is interested:
[ame="https://www.youtube.com/watch?v=FqiM2cz9v1g"]TOYOTA 86/SUBARU BRZ HKS SUPER EXHAUST SYSTEM LMS - YouTube[/ame]
#203 |
Drives: 2017 BRZ Limited
I am a noob... just picked up my '17 BRZ last monday. I am thinking about picking up a HKS exhaust (Hi Power Spec L Cat Back Exhaust), but after doing a little research it looks like the pipes are 2-2.5 inches. Can I continue to use this cat back if I buy a turbo in the future? Is this wide enough to support hp gains?
-Lee |
#204 | |
I didn't go with the Hi Power Spec L even though it was light because you have to add some kind of diffuser or tray to take the place of the hole changing the stock muffler will leave behind. Its the case with any type of F1 or cannon style exhaust not covering the hole will be a big parachute area behind the bumper catching air. That's if you care about the aerodynamics built into the car.
#205 | |
#206 | |
#207 |
thanks great info!
#208 | |
#209 |
Human
Drives: 2015 BRZ Black
Does the Legamax Sports Cat-Back (Dual Tip) fit with the TRD rear bumper that is already set up for quad exhaust tips?
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
#210 |
It most likely will
| Tags |
| exhaust, header, hi-power, hks, legamax |
| exhaust choices | FloridaBRZ | Engine, Exhaust, Transmission | 4 | 01-26-2015 08:32 AM |
| UPGRADE-what are my exhaust choices | cbennybrz | Engine, Exhaust, Transmission | 6 | 01-01-2015 07:45 PM |
| Exhaust Choices for FI | rixter145 | Engine, Exhaust, Transmission | 4 | 09-11-2014 01:15 PM |
| Exhaust choices | KonTheory | Engine, Exhaust, Transmission | 6 | 01-30-2014 03:28 AM |
| Help with Lug choices. | feldy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 05-24-2012 08:19 PM |
