Old 08-06-2017, 09:01 PM   #15
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
And on to the suspension mount!
Opie is offline   Reply With Quote
Old 08-06-2017, 09:04 PM   #16
Opie
Opie's Avatar
Old 08-06-2017, 09:07 PM   #17
Opie
Opie's Avatar
And on to replace the damaged radiator and A/C condenser...with a little upgrade!
22 days since I picked it up....
Tomorrow I will order the replacement underbody fuel & brake line assembly, drivers airbag and a few other bits & pieces I need. Hopefully will get the fender & bumper to the body shop for paint this week too!
The Following User Says Thank You to Opie For This Useful Post:
dowroa (08-06-2017)
Old 08-08-2017, 10:31 PM   #18
Opie
Opie's Avatar
Don't have a lot of time on weeknights to do a whole lot to the car...but tonight got the fender bracing final coat of paint on, installed the lower bumper bracket/radiator ducting and the windsheild washer resevoir. Drop the fender, fender garniksh and front bumper cover off at the body shop tomorrow for paint, and the rest of the parts needed for completion and state inspection should arrive. Should make for a really busy weekend. Got to drop the fuel tank to replace the brake/fuel line assembly...might start that tomorrow after work...
The Following 2 Users Say Thank You to Opie For This Useful Post:
dowroa (08-09-2017), JermMX5 (08-08-2017)
Old 08-09-2017, 03:12 PM   #19
Opie
Opie's Avatar
So I've received a few PM's about what type of shop I am using, what training I have, etc. in order to take on a project like this.
As far as the "shop", all the work done on the car has taken place in my garage, at my house.
As far as training, I have fairly extensive Subaru mechanical repair experience, but no previous metal work, body or paint experience.
Metal body work was done using a 5lb sledgehammer, a 16oz ball-pein hammer, a standard drill, a close quarters drill a 4" angle grinder, a dremmel tool, a borrowed welder and many miscellaneous bits & hand tools. All the underbody and fender bracing paintwork has been done using spray primer, sealer & two specially ordered cans to match the factory paint (OEM base gray for under hood and OEM base silver coat).
Labor has all been completed by myself with the help of my wife and some welding help from a co-worker.
Parts are a mix of used as I could find them, and new.
Aphaux (10-26-2019), Dave-ROR (08-11-2017)
Old 08-09-2017, 03:36 PM   #20
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
You've gotten a lot done quickly. This is really the path to go if your building a track car as long as the frame/suspension isn't completely mangled.
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
Aphaux (10-26-2019)
Old 08-09-2017, 04:19 PM   #21
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
Nice work man! When it comes to painting the fender and door, do not try and paint it without having access to a full sized spray gun. Silver is very hard to spray evenly and it is impossible to spray anything larger than a foot wide with a spray can. Don't ask me how I know....
projek_01 is offline   Reply With Quote
Old 08-09-2017, 05:09 PM   #22
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
Gah! Quit using common sense and applied intelligence! We can't buy that!
dowroa is offline   Reply With Quote
The Following User Says Thank You to dowroa For This Useful Post:
Opie (08-09-2017)
Old 08-09-2017, 09:26 PM   #23
Opie
Opie's Avatar
Fender & front bumper cover are being painted by a body shop...wasn't gonna try that myself. I know my limits...lol
Just a little work tonight, paint was dry so I installed the LH fender bracing, reinstalled the hood latch and airbox, got the drivers headlight installed and 90% of the oil cooler done...
Old 08-10-2017, 10:01 PM   #24
Opie
Opie's Avatar
Some backordered parts arrived today so I was able to tidy up some unfinished projects tonight:
  • Finished oil cooler install
  • Changed the oil & filter
  • Installed the big metal under engine tray (Yay Ebay!)
  • Completed install of front sway bar
Big project for this weekend is replacing the brake & fuel pipe assembly under the car that runs from the engine compartment to the rear wheels and fuel tank...hopefully it is not as difficult as I assume it is...LOL
Then the following week I should have a LH tie rod end that will let me finish up the suspension and if the body shop gets the fender & hood finished I might have it on the road the week of Aug 21st!
Old 08-11-2017, 02:59 PM   #25
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Damn, nice work Will.
I have to help Darren with his 240 project, but if I have extra time I'll see if you need help.
I need to drop the trans on graffiti soon to replace some shift forks... and need to drop some wheels/tires off at Mastro next week. Other than that I'm set for the next two track days (Road America and Barber). When are you doing Sebring next? And then when are you stepping it up to Road Atlanta?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Opie (08-11-2017)
Old 08-11-2017, 03:22 PM   #26
This is really nice, especially for a track beast. I'd street the hell out of it but I guess I'm not that picky.
Great resurrection!
Opie (08-11-2017)
Old 08-11-2017, 03:46 PM   #27
Opie
Opie's Avatar
I'll be working on it for much of the day tomorrow, come on over if you get done on the 240! Once I get freed up on this I can help with the graffiti tranny.
I'm signed up for Sebring on Oct 7th, might switch to the 8th or maybe do both days. Once I'm sure it's good to go and road worthy I want to make the trek to RA & AMP.
How many more sets of tires do you need for graffiti? LOL, bring them by whenever.
Old 08-11-2017, 04:03 PM   #28
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
2 sets of r comps and 1 set of street (aka wet) tires.
Even if it's not street legal I can tow it. You can drive my RS over and I can track that pig.
Let me know what day you pick and I'll see if Aaron wants to sign up. I can sign up regardless. Plenty of spots open currently.
The 7th likely works better since we would likely make it to our game. Otherwise, we'd have to roll really late Saturday or early sunday.. or skip hockey.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
NORGP GT86 just for Track Rebuild Panamaniac Member's Car Journals 25 12-06-2019 08:41 AM
History of my GS-R.. and rebuild.. my now-current track car. Dave-ROR Other Vehicles & General Automotive Discussions 35 12-12-2013 08:02 PM
MVP Track Time 2013 Road Atlanta Track Dates Feffman Southeast 7 11-05-2013 11:36 AM
MVP Track Time 2013 Great Lakes/Midwest Track Dates Feffman Great Lakes 5 09-07-2013 01:39 PM
FS: 2013 Totalled BRZ FS (~5,000 miles) eklipz98 Northern California 45 02-03-2013 01:16 AM
