Old 06-14-2017, 11:59 AM   #43
-Phil
Drives: Rb25 neo brz
Hey all,
Been a while sense the last update, a Good amount of work got done, The full exhaust is completed and off to ceramic coat. Once thats back all thats left is finishing up the can-bus and shes off to the races.
Downpipe
-Phil
-Phil is offline   Reply With Quote
The Following 7 Users Say Thank You to -Phil For This Useful Post:
civicdrivr (07-10-2017), CxG (06-19-2017), DustinS (06-14-2017), KnightRyderx2 (06-14-2017), leets4uc3 (06-15-2017), MJones_RB (07-19-2017), R2RO (06-24-2017)
Old 06-23-2017, 07:56 PM   #44
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Took the time to make it as equal as possible, why not go divided?
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 07-07-2017, 07:58 PM   #45
-Phil
Hey All,
the car is pretty much sorted mechanically, all lines are done all that's left mechanically is the throttle and clutch master.
Can-Bus stuff is being sorted out, I wouldn't know what on earth is going on here but my wiring guy swears by it, MRS module to Body harness to Hal-tech.
The Following 8 Users Say Thank You to -Phil For This Useful Post:
Clipdat (08-08-2017), CxG (02-26-2018), Draco_PR23 (02-22-2018), DustinS (07-10-2017), Guff (07-07-2017), KnightRyderx2 (09-05-2017), MJones_RB (07-19-2017), Sportsguy83 (07-07-2017)
Old 07-07-2017, 08:26 PM   #46
-Phil
Future manifolds will be divided, this header was used for the jig, I originally did not plan on doing it hence my collector choice. After talking to Elmer they will make us a divided collector next time upon request.
-Phil
The Following 4 Users Say Thank You to -Phil For This Useful Post:
civicdrivr (07-10-2017), DustinS (07-10-2017), OmarGC (07-09-2017), Sportsguy83 (07-07-2017)
Old 08-08-2017, 02:47 PM   #47
SillySaxon
SillySaxon's Avatar
Drives: Sc10n Series FR-S
Originally Posted by Moto-Phil View Post
Hey All,
The engine looks rotated about 5-10 degrees, is that the case and if so why?
I figure as long as you smile while driving the car, you're doing it right.
SillySaxon is offline   Reply With Quote
Old 08-08-2017, 03:07 PM   #48
-Phil
the motor is tilted 13 degrees, that is simply the way it was designed to be. if you where to make it upright the shifter would be angled incorrectly.
Old 08-08-2017, 03:52 PM   #49
NINE
Drives: 2015 BRZ
Looking forward in seeing the end product!
Daily: 2008 IS250 (Stock)
Toy: 2015 BRZ (KW V3, TE37sl) More to come.
Past: 2008 BMW M3, 1976 Datsun 280z, 1998 240sx, 1990 180sx, 2005 RSX-S, 2003 IS300, 2001 Civic.
NINE is offline   Reply With Quote
Old 08-11-2017, 02:44 PM   #50
SillySaxon
SillySaxon's Avatar
I had no idea it was designed that way, interesting. Just wanted to confirm that I wasnt seeing the photo weird.
This is awesome
Old 09-03-2017, 11:50 PM   #51
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Slanted inline six's are a popular design orientation for sixes.
Chrystler slant six
BMW
Nissan GTR
Nissan SR20 - Even the four cylinders can be tilted
Honda S2000
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
-Phil (11-30-2017), Draco_PR23 (02-22-2018)
Old 10-31-2017, 01:22 PM   #52
SillySaxon
SillySaxon's Avatar
Chrystler slant six
BMW
Nissan GTR
Honda S2000
I never noticed this before O_O Wonder what the reasoning behind that is, package fit?
Old 10-31-2017, 02:04 PM   #53
Irace86.2.0
I think it has to do with packaging, aesthetics, aerodynamics and lowering the center of gravity. Packaging would be to add a manifold or turbo into an area when the engine bay is narrow. Aesthetics or aerodynamics would be to lower the hood height. Similarly, lowering the motor lowers the center of gravity.
Old 11-30-2017, 12:23 PM   #54
-Phil
Update,
Wiring and can bus has seemingly been sorted through by Dunnfab in NJ
The car has a bunch of little things that needs to be done which entails the following,
----Alternator wiring - Easy
----Clutch master - I attempted to work with vorshlag on this however they are not willing to sell their adapter even as a kit without the Hydro ToB and everything else. With that being that case I plan on bringing a plate that fits perfectly and adapts a Wilwood master to market in the upcoming months. Not everyone has a v8 swap after-all. For now I will follow the route of @DustinS with a rywire plate.
----Oil pan Clearance - The oil pan needs to be removed and clearance'd to fit with the motor mounts, this is only a problem because i had extended to oil pan.
----- Intake pipe - simply stated their needs to be a hard pipe coming off the throttle body as opposed to a 90 deg Coupler that will explode when it see's 40LB of boost.
---- Fuel system - As opposed to waiting to make 500-600 WHP on the dyno then stopping everything to put in a fuel system I have decided to just do it early on. I have acquired a radium dual in-tank with 2x Walboro 450's for this purpose.
I will be bringing the car to get work done at my new place of work Prime motoring. To anyone following both this build thread and Prime motoring's rb26 thread you will be happy to hear that the rb26 thread will also be revived soon.
I will add pictures as i get them for now.
Draco_PR23 (02-22-2018), DustinS (11-30-2017), ILLSMOQ (11-30-2017), Soloside (11-30-2017)
Old 11-30-2017, 04:07 PM   #55
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
Can't wait to see the car up and running!
Originally Posted by -Phil View Post
Update,
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
The Following User Says Thank You to Soloside For This Useful Post:
-Phil (11-30-2017)
Old 12-02-2017, 09:44 AM   #56
Zer0
Drives: 2015 frs
Update,
I have my old Vorshlag plate if you want it pm me. It's brand new I made my own to move my master cylinder. Over 3 inches closer to the brake master cylinder so I won't be using it.
Zer0 is offline   Reply With Quote
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 03:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
LED swap Skorov AUSTRALIA 28 09-23-2014 09:46 PM
Ej Swap koyv90 Engine Swaps 50 11-14-2013 07:59 PM
