Old 08-01-2017, 01:48 PM   #15
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
just from online shopping and doing the work myself vs. letting else someone build a shortblock for me, it's roughly about $1000 difference. And that was taking the cheapest parts for me to build myself. In my opinion I think it's a better investment to let MAPerformance or Full Blown build the short block because for the extra 1000, I KNOW everything will be done right, blue printed, balanced, assembled correctly, and have better internal components. In my opinion, I think that's totally worth the cost difference alone.
I would love to do LS swap, but I don't have any access to fabricate anything, ie machine shop, welder, etc. Plus, if I were to do that, I would like to retain all stock functions/gauge clusters. One can only dream; but as far as I've seen the LS swap isn't100% yet in my eyes.
pgranberg11 is offline   Reply With Quote
The Following User Says Thank You to pgranberg11 For This Useful Post:
daftpunk (07-16-2019)
Old 08-01-2017, 01:49 PM   #16
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Originally Posted by solus View Post
im making 435hp on AVO's turbo.
Carrillo rods
CP pistons 12.5:1
Kings Bearings
ARP 1/2" head studs, main
Supertech valves and springs
16psi E85
I have lower boost settings for 91
what made you stick with stock compression ratio just out of curiosity?
solus (08-01-2017)
Old 08-01-2017, 02:21 PM   #17
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
There is no reason to lower compression if you plan on running E85 and under 20 psi. You're just hurting the performance out of boost and while spooling. E85 is incredibly knock resistant (and burn cooler which also helps prevents knock) which is the concern when running pump gas, high boost and high compression.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
ATL BRZ (08-07-2017), pgranberg11 (08-07-2017), solus (08-01-2017)
Old 08-01-2017, 05:13 PM   #18
solus
Drives: 2014 Scion FRS (Ultramarine)
E85 has greater knock protection and additional cooling, to allow better resistance to higher compression. combined that with the exactness of direct injection and there really is no reason to go lower CR. I do run a lower boost setting for 91 though... because sometime E85 isn't available
solus is offline   Reply With Quote
The Following User Says Thank You to solus For This Useful Post:
pgranberg11 (08-07-2017), Sportsguy83 (08-02-2017)
Old 08-07-2017, 09:12 AM   #19
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
I see. I take it when you say spool, it's both applicable to a supercharger and a turbo, correct?
Old 08-08-2017, 08:23 AM   #20
Fred E
Drives: WRB BRZ
Kind of, although superchargers don't technically "spool" as the boost they make is entirely dependent on engine RPM. However lowering the compression of the engine while running a supercharger will considerably reduce the power that the engine is able to produce. The only real reason to lower compression with a supercharger build is to increase safety (i.e. reduce the chance of knock) for when you have to use pump gas. If you're certain that you're going to be using E85 (or technically any mixture greater than about 50%?) you'll be perfectly safe keeping the stock compression since the ethanol in the fuel will greatly reduce the chance of knock like @Sportsguy83 mentioned.
The reason people typically lower the compression ratio is because they're not certain they'd be able to use higher levels of ethanol in their fuel 100% of the time. A lot of turbocharger users still lower the compression a bit because they can simply have their tune adjusted to electronically control boost levels dependent on the percentage of ethanol in their fuel. There's no real way to automatically adjust boost levels on a supercharger aside from swapping to a smaller pulley.
Fred E is offline   Reply With Quote
The Following 2 Users Say Thank You to Fred E For This Useful Post:
pgranberg11 (08-08-2017), Sportsguy83 (08-08-2017)
Old 08-08-2017, 08:26 AM   #21
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Ok that's what I was thinking when he meant something like that. I figured I just didn't want to miss anything. I suppose I will keep the stock compression. The only time the car will ever see 93 is when it's being stored through winter. So I guess the car will probably see 1-2 full tanks of 93 when it's finished.
Motor Blew Last Night John Rambo Forced Induction 142 10-16-2017 12:11 PM
Can we have a built motor/engine thread? TruthfulDeception Engine, Exhaust, Transmission 3 07-23-2016 04:04 PM
Blew my motor Noobthen Forced Induction 27 05-03-2016 12:11 PM
so my motor blew up on dyno today jdl kit gtx3071 kingkai23 Forced Induction 62 07-24-2014 09:09 PM
What would You do if your motor blew? TyperRspec789 Forced Induction 58 07-02-2013 10:54 PM
