Old 08-07-2017, 09:36 AM   #1
Tamukas
Drives: Clean
Vogtland springs issue
Hello everyone!
Yesterday I installed lowering springs from vogtland. They claimed that their springs will lower the car 2.5cm (1'). I got the promised drop in the rear, but for some reason the front of the car stayed almost exactly the same as stock. I started to think that i've got something messed up..
Here are some before and after pictures and the front strut.
Before:
http://imgur.com/V4uGksJ
After:
http://imgur.com/diPuzg6
Front strut:
http://imgur.com/tuFAlwy
Did i do something wrong or should I wait for the springs to settle in a bit more?
Btw, there are no weird noises or anything, the car handles beautifly.
Tamukas is offline   Reply With Quote
Old 08-07-2017, 12:51 PM   #2
Darkrune
Darkrune's Avatar
Drives: 2017 86
Looks fine to me. Let them settle.
Sent from my SM-G935V using Tapatalk
Darkrune is offline   Reply With Quote
Old 08-07-2017, 05:07 PM   #3
Tamukas
Drives: Clean
If they are supposed to look like that, I will end up cutting them.. ��
Old 08-07-2017, 05:21 PM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Do it...
Old 08-07-2017, 05:25 PM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
"Looks fine" really dude? The front didn't lower.
Originally Posted by humfrz
I'm old and lazy
Old 08-07-2017, 06:00 PM   #6
Darkrune
Darkrune's Avatar
Drives: 2017 86
Really dude, looks like an inch drop springs when you first put them on. The car clearly has a mild drop 1". Look on a big screen.
Old 08-07-2017, 06:02 PM   #7
Darkrune
Darkrune's Avatar
Drives: 2017 86
It will take a little while for them to settle, just be patient. You don't want to drop the car any lower without accessories.
Old 08-07-2017, 06:09 PM   #8
Clipdat
Proud of BOXER
Clipdat's Avatar
Are you new? Because you seem new.
I'm old and lazy
Old 08-07-2017, 06:26 PM   #9
Darkrune
Darkrune's Avatar
Drives: 2017 86
Are you blind? Because you seem blind. I've lower half a dozen of these cars with RCE yellows. Same results immediately after you put the springs on.
"Yesterday I installed lowering springs from vogtland. They claimed that their springs will lower the car 2.5cm (1')" Oh looks like a one inch spring one day after install. Hm, wonder if they need time to settle.
Should look something similar to this after settling.
http://www.ft86club.com/forums/showp...&postcount=213
Old 08-07-2017, 07:42 PM   #10
Clipdat
Proud of BOXER
Clipdat's Avatar
LOL, I'm blind? Remember, you are the one who just said that I need to "Look on a big screen" - as if MOAR PIXELS will suddenly allow me to see that the wheel gap in the front isn't exactly the same in the before and after photos.
Put both photos into Photoshop and overlay the front wheel section and you can see that the fender/wheel gap is exactly the same.
Also are you implying that the OP didn't take any measurements before and after?
I had RCE Yellows and even though they are only .75" drop versus the 1" drop springs we're discussing, my front was still well lower than his is in the "after" photo. I understand that springs can settle, but not an entire inch.
I'm old and lazy
Old 08-07-2017, 07:49 PM   #11
Clipdat
Proud of BOXER
Clipdat's Avatar
Aren't the springs with the closer/tighter section of wound spring on the top supposed to go in the rears? But these are on the front? Front and rears reversed maybe?
I'm old and lazy
Old 08-07-2017, 07:49 PM   #12
Darkrune
Darkrune's Avatar
Drives: 2017 86
The gap is no where near the same. Overlays only work if you carry the same angle. One photo being taken at 45 degrees and the other taken at 90 degrees. Looks like a 7/8" drop just from eye balling. The car still clearly has been lowered and not settled. I know the OP didn't measure, otherwise I am sure he would have those figures posted.
Old 08-07-2017, 07:51 PM   #13
Darkrune
Darkrune's Avatar
Drives: 2017 86
The should compress the same either way, but the difference would be in unsprung weight. Aesthetically it would likely look the same in the drop.
Edit: Wait those are on the front? The "skinnier" springs should be on the back. The larger springs should be on the front strut.
Edit 2: This is my car's front strut
This is the car after two weeks.
Old 08-07-2017, 08:11 PM   #14
Clipdat
Proud of BOXER
Clipdat's Avatar
This is what I said above. I think you read my post too quickly and thought I meant upside down instead of reversed front and back.
I'm old and lazy
[PA] [NJ] RCE Tarmac 2 coilovers w/ 400lb springs. Optional 11/13k swift springs leunglambs NY / NJ / CT / PA 3 06-09-2017 03:49 PM
FS: stock BRZ springs, Eibach Pro Kit springs + Stock shocks (socal/OC) tracerit Brakes, Suspension, Chassis 7 04-02-2016 01:04 PM
WTB: RCE yellow springs or eibach prokit lower springs fr/brz Gt86-turbo Want-To-Buy Requests 0 03-08-2015 04:18 PM
Swift Sport springs/or any springs.. regrets ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-21-2014 10:10 PM
