Old 08-04-2017, 08:51 PM   #1
Spence96
Drives: '15 WRB BRZ 6 Speed
Steering issue on long sweepers
I will post the link to a video I have uploaded to Google Drive. Pay close attention to both of the right hand turns I go through. Traction control is off (I did not do the pedal dance), but the traction still kicks in with very little steering input. It required countersteer to avoid going off road. This does not happen during autocross, only on roads like the video or highway on ramps.
What you might like to know about my car:
Tein S-Tech lowering springs with stock struts
XXR 530's 18x8.75 +33 on all 4 corners
245/35/18 Contiental Extremecontact DW on all 4 corners
Open Flash Tablet tune (idk if it affects the steering or not)
Stock everything else as far as chassis/suspension goes
Video link:
https://drive.google.com/drive/folde...zg?usp=sharing
Edit:
My front left ball joint was not completely tightened down, and the front left wheel bearing was replaced under warranty. The car now handles great again.
Spence96 is offline   Reply With Quote
Old 08-04-2017, 10:15 PM   #2
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Has it been aligned? Could possibly be a rear toe issue
tyler_win_photo is offline   Reply With Quote
Old 08-04-2017, 11:35 PM   #3
Spence96
Car has been aligned twice since I put the springs on March 2016. It's been doing it ever since I have had the Teins. Possibly bad springs/struts? Installation was done by a Subaru dealer so i don't think it is due to a poor install.
Old 08-05-2017, 03:35 PM   #4
wparsons
wparsons's Avatar
What are the exact alignment specs, did they give you a printout? Have you verified tire pressures are good all around?
Watching the video, the slip indicator doesn't come on at all on the second right hander, just the first one.
What are your feet doing when it comes on in the first corner? Braking at all? How hard on the gas?
There's a patch of rough looking pavement near the entry of the first one, could just be too fast for the conditions? You were going ~85mph, but I can't get a good sense of what the pavement is like.
flickr
Old 08-05-2017, 04:19 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Your alignment is basically causing the car to think you are losing traction at higher speeds.
I used to have this problem when I had a fairly aggressive alignment for street use and any turns above ~50MPH sharper than an onramp would trigger traction control.
Either you have to readjust your toe or just do pedal dance. Saying "I got it aligned twice in last year" doesn't tell us much about what work was done.
Oh, my problem went away after I put the suspension back to stock.
-alex
Old 08-05-2017, 05:01 PM   #6
Spence96
Alignment specs as of 3/4/2017 F and B are front and back. L and R are left and right
-.7 camber FL / -.8 camber FR
5.6 caster FL / 5.8 caster FR
-.04 toe FL / .05 toe FR
-2.5 camber BL / -2.5 camber BR
.10 toe BL / .13 toe BR
Old 08-05-2017, 11:48 PM   #7
stevesnj
stevesnj's Avatar
Did they reset the Zero Point Calibration?
My 2016 Build thread
Old 08-06-2017, 04:25 AM   #8
tyler_win_photo
Could possibly one of your struts be blown?
Old 08-07-2017, 12:29 PM   #9
wparsons
wparsons's Avatar
That's the after?? Not great at all, but I still think you were simply above the limits of grip based on the video and how the pavement looks.
I'd still want the toe set better... I like it to be bang on 0* up front, and 1/16" total toe in (1/32" per wheel) in the rear. In degrees, that's 0.14 total or 0.07 per wheel. That'll be looser than what you're currently running though. At the very least you want to make sure you don't have toe out one side and toe in on the other like you currently have on the front, and that it's equal side to side.
flickr
Old 08-07-2017, 12:36 PM   #10
wparsons
wparsons's Avatar
Actually, watching in slow motion.. did you drop a tire off the inside of the pavement a little?
flickr
Old 08-07-2017, 12:41 PM   #11
-Willis-86touge
Drives: Stock
What exactly is zero point calibration? I heard it used before but nobody ever goes into detail
-Willis-86touge is offline   Reply With Quote
Old 08-07-2017, 02:10 PM   #12
Spence96
I almost did, because the steering snapped in that direction. Hence why I had to countersteer slightly. I did not apply any steering, throttle or brake input, but my car randomly snaps in the direction I am turning. It happens on smoother on ramps for highways as well so I don't think it is because of the road surface. I am leaning towards it being more of an issue of blown struts, cheap suspension with unbalanced front and rear spring rates, or something might be loose or bent under the car.
Old 08-07-2017, 02:43 PM   #13
stevesnj
stevesnj's Avatar
Yaw rate sensor and acceleration sensor zero point calibration.
Basically it set's to 0 (zero) or re-calibrates the way the car determines when to apply the VSC based on your current wheel, suspension, Alignment setup. The VSC is based on many values , speed, position of car on X,Y Axis and calculates if and when to apply the VSC. The values are affected by the overall tire height, alignment of the suspension changes. If these values are changed from the factory configuration of stock wheels and alignment with taller overall wheel height, camber bolts, etc. the values don't match the factory calibration thus will activate or won't activate the VSC properly and can cause loss of vehicle control or just over react and turn on more often.
Basically when you mod your suspension, wheels, tires, suspension parts, alignment (post). The Zero Point Calibration should be performed.
Old 08-07-2017, 03:49 PM   #14
Spence96
Where would I get this done? The dealership that installed my springs?
Power steering issue with slicks? owenxguo Tracking / Autocross / HPDE / Drifting 59 02-06-2024 11:05 AM
Steering issue under braking ! AJ PwR Tracking / Autocross / HPDE / Drifting 146 04-25-2023 05:47 PM
Strange issue in steering or possibly clutch? Renesis Issues | Warranty | Recalls / TSB 14 05-11-2019 05:10 PM
Possible Steering Issue ? TJB_902 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-24-2015 01:38 AM
Steering wheel issue Khalis Issues | Warranty | Recalls / TSB 1 05-04-2013 01:19 AM
