Old 08-04-2017, 03:18 PM   #15
toyubie
Drives: none
I found my old port injectors (on the left), they look very different from the ones I just pulled from the motor (right).
Although I forgot fuel pressure was a thing and sprayed gasoline directly over the engine disconnect plug so I'm waiting for it to evaporate before I start her up.
You guys have been incredibly helpful, I can't thank you enough for staring at my shitty data logs! Hopefully putting my old port injectors in will solve this. I'll keep you guys updated.
toyubie is offline   Reply With Quote
The Following 2 Users Say Thank You to toyubie For This Useful Post:
steve99 (08-05-2017), x808drifter (08-04-2017)
Old 08-04-2017, 04:20 PM   #16
toyubie
Drives: none
Engine started right up, no pump of the pedal needed. Went right to cold start RPMs, dropped smoothly to idle. No check engine light. No stumble/hesitation at 3k.
http://www.datazap.me/u/toyubie/brz-...ata=2-3-7-9-10
Data looks much more stable although the fuel trims are not what I expected to see. I suppose that could just be the ECU learning. I'll be driving to work in about an hour so we'll see how she does.
EDIT: Also I'm sure there's a lot of gunk built up from running so shitty the past few months. Could take some time to burn off.
Gords_zenith (08-04-2017), Turdinator (08-04-2017)
Old 08-04-2017, 10:45 PM   #17
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Do you know why the injectors were different?
Gords_zenith is offline   Reply With Quote
Old 08-05-2017, 01:51 AM   #18
steve99
Drives: FT86
ok sounds good i suspect you have found the cause.
I think that dude you bought the motor off might have been "spinning a yarn" as my old man used to say.
If that motor had different (larger flow) injectors then it was almost certianly running forced induction . You dont need larger port injectors on Naturally aspirated motors even to run E85.
The fuel trims will be a bit erratic for 100km or so till the ecu gathers and interprets some average fueling data.
Old 08-05-2017, 07:46 AM   #19
toyubie
Drives: none
I was able to find my messages to the seller in a backup and he does actually say he was running E85, but nothing about changed injectors. I bet he was tuned for them, didn't pull them out, and forgot about them.
Already seems to be leveling out during partial throttle pulls! It feels brand new, awesome!! Can't believe I didn't check them sooner.
Old 04-07-2018, 12:11 PM   #20
Dru670
Drives: 2016 Scion FR-S
Did you figure out the problem and is it fixed?
Dru670 is offline   Reply With Quote
Engine Running Rich, P0102 P0108 P0113, and Misfires Votlon Engine, Exhaust, Transmission 12 01-21-2017 03:38 AM
OFT+OFH running rich Dabrown Software Tuning 14 11-28-2016 03:20 PM
Cel gas running to rich anthonyravenfrs Scion FR-S / Toyota 86 GT86 General Forum 3 07-15-2014 01:55 AM
Running rich KslayFRZ Issues | Warranty | Recalls / TSB 15 10-25-2013 11:42 PM
running rich/stumbling Boostedpro Issues | Warranty | Recalls / TSB 1 01-28-2013 02:19 PM
