| Engine Swaps Discussion of engine swaps. |
#141 | |
Drives: It has 4 wheels
Price Availability Gearbox compatability Probably Width Also I'm loving the CAN Converter and the guy can currently program it for GM or Subaru engines. Last edited by bradsm87; 06-09-2016 at 05:57 PM. |
#142 |
poverty cause racecar
Drives: Subaru BRZ JRSC'd
#143 |
IMS issues are a problem that can be fixed fairly easily with proper parts (LN engineering kit) when the engine is out of the vehicle, the reason it turns off so many potential porsche owners is that you have to pull the engine which is a huge cost, if its already out of the vehicle for the swap you might as well change it |
| The Following User Says Thank You to Canehda For This Useful Post: | Chad_W (06-10-2016) |
#144 |
Dismember
Drives: 2013 Red Scion FR-S
#145 | |
Drives: 2013 BRZ DGM
#146 |
#147 | |
personally other than doing it for the lols i would prefer just getting a 987 cayman, after driving a few it is making a great case for replacing my brz if the 2017 BRZ is unreasonably expensive with performance package |
#148 | |
Drives: 2014 Scion FR-S Monogram Series
The 3.0L Duratec would be a better choice (better intake manifold, cooling and oiling passages and PCV system) but it still has lousy connecting rods so you will have to plunk money into K-1 rods, rebalancing and all the gaskets and torque-to-yield bolts if you want it to last before figuring out how to fit it in the car. I pretty sure you will need a custom oil pick-up and oil pan because neither the 2.5L or 3.0L Duratec was ever put in a rear drive-only car. If you want the powerband behavior of the SVT, you will have to find a good set of cams and chains from the 2.5L to swap-in as the 3.0L factory cams are not as rev happy. Fortunately, those are easy to find used but not necessarily with low mileage on them. Aftermarket support for the Duratec V6s seems to be pretty poor too. There is a lot of potential in these motors but there are much better options for the OPs project.
2014 FR-S Monogram Series, Raven Black, MT
Mods -ARP wheel studs, Bilstein B6, Michelin Pilot Sport 4S, Diode Dynamics "Tail-as-Turn" kit. Fuel Economy - Best was 37.2 mpg, Worst was 28.2 mpg Semi-truck crushed it on 1-1-2023. |
| BUDDY CLUB Lightweight Racing Wheels - JDM, lightweight, low pricetag | 18x8.5" | GuerillaRacing | Wheels and Tires | 116 | 01-20-2015 07:32 PM |
| Looking for a second car, what would you choose? | cdo221 | Other Vehicles & General Automotive Discussions | 31 | 04-26-2014 12:50 AM |
| If you had to choose.... | FRyeS | Off-Topic Lounge [WARNING: NO POLITICS] | 51 | 07-31-2013 09:17 AM |
| Help me [maybe?] choose a new car: | tree fingers | Other Vehicles & General Automotive Discussions | 24 | 04-16-2013 06:27 PM |
| Why did you choose the BRZ? | pinoyplaya | BRZ First-Gen (2012+) — General Topics | 43 | 10-10-2012 04:34 PM |
