Old 08-03-2017, 10:19 PM   #17221
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Found out the Subaru expert shop that did my JDM shifter install forgot to re-attach the wires to the 12 v plug in the well behind the shifter. Luckily I was able to just pull up the ebrake boot and reach in and fix.
Old 08-03-2017, 11:01 PM   #17222
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
installed Shorai Battery today
install thread here
http://www.ft86club.com/forums/showthread.php?t=120937
SuperTom is offline   Reply With Quote
The Following 2 Users Say Thank You to SuperTom For This Useful Post:
MJones_RB (08-04-2017), zeal86 (08-03-2017)
Old 08-03-2017, 11:50 PM   #17223
zeal86
zeal86's Avatar
Drives:
Today I finished polishing and installed my custom '17 Red Intake Manifold Cover prototype! It is (for) now complete!
I'm pretty happy with the results... looks so good polished! Adds another layer of detail to my engine bay.
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is offline   Reply With Quote
The Following 7 Users Say Thank You to zeal86 For This Useful Post:
Clipdat (08-04-2017), Kiibiiin (08-04-2017), MJones_RB (08-04-2017), mpross (08-03-2017), new2subaru (08-04-2017), SuperTom (08-04-2017), trvth (08-07-2017)
Old 08-04-2017, 12:38 PM   #17224
Ron B Avery
Ron B Avery's Avatar
Drives: 2017 86 Coupe
Wow , that looks very cool. Good job.
Ron
2017 Toyota 860 Halo White, TRD springs, TRD air filter, Center consul arm rest lid, Magnaflow cat back exhaust, Pioneer SPH-DA120 head unit with Apple CarPlay,
TRD sway bars , 17" 949 Wheels Beryllium finish, Michelin Pilot Super Sport tires, 225/45 ZR 17, Garage Vary Kouki splitter
Ron B Avery is offline   Reply With Quote
The Following User Says Thank You to Ron B Avery For This Useful Post:
zeal86 (08-04-2017)
Old 08-04-2017, 01:39 PM   #17225
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
The fit & finish of the cover appear to be factory/OEM quality. Nice job!
Originally Posted by humfrz
I'm old and lazy
Old 08-04-2017, 02:20 PM   #17226
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Looks fantastic! Did you have to fabricate a mount for it?
btw, how did you get your throttle body so shiny?
MJones_RB is offline   Reply With Quote
The Following User Says Thank You to MJones_RB For This Useful Post:
zeal86 (08-04-2017)
Old 08-04-2017, 02:35 PM   #17227
zeal86
zeal86's Avatar
Drives:
Thanks for the comp! The rear mounts are built into my design... the front of the cover shares the same mounting point as the MAP sensor.
I buffed out the throttle body as it lay...I didn't bother to remove it. I just taped off around it and used towels elsewhere to protect against the sling. Used small buffing wheels on a high speed drill and a Dremel with buffing wheels for the tight areas. Used rouge and Blue Magic to cut and buff... I didn't use sandpaper...I just kept at it until the texture wore down.
The Following User Says Thank You to zeal86 For This Useful Post:
Old 08-04-2017, 03:46 PM   #17228
Kerber23
Kerber23's Avatar
Drives: Turbo FRS
Day three of turbo install... it should be finished today! I might even get to drive it on the base map! I am so excited ^_^
Kerber23 is offline   Reply With Quote
The Following User Says Thank You to Kerber23 For This Useful Post:
zeal86 (08-04-2017)
Old 08-04-2017, 03:48 PM   #17229
Ashikabi
Ashikabi's Avatar
@zeal86 did you have your engine bay painted or did it look nice from the factory? Mine is a shitty brown color
Old 08-04-2017, 03:51 PM   #17230
zeal86
zeal86's Avatar
Drives:
It has looked nice since I bought it...
Old 08-04-2017, 03:54 PM   #17231
Sapphireho
Famous Potatoes
Sapphireho's Avatar
What color is the car? My car is ultramarine and engine bay is black.
Old 08-04-2017, 03:54 PM   #17232
Ashikabi
Ashikabi's Avatar
I got jipped... It's like they shot it with primer then closed the hood and never looked at it again. I'd have to strip it if I wanted it to look anything like yours. RIP
Old 08-04-2017, 03:54 PM   #17233
Ashikabi
Ashikabi's Avatar
Lava
Old 08-04-2017, 03:58 PM   #17234
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Lava
That's strange
