| Software Tuning Discuss all software tuning topics. |
#15 |
Drives: 86
#16 |
Drives: 2014 Toyota 86
Thanks for chiming in guys
Well maybe someone on the forum that knows his way through the ECU could chime in. Thanks for the input.
#17 |
Drives: '06 AM V8V Coupe
Idle is not controlled by the AVCS tables you see in Romraider or whatever, like a bunch of people already said.
That said, you CAN introduce lope at low load by adding exhaust cam retard. About 10 degrees should do the trick. I got some pops with 5 degrees at 1600-2000rpm. Basically the overlap will be diluting your charge to the point where it has trouble burning. However your car will be shaking a bit, which may or may not be annoying. |
| The Following User Says Thank You to serialk11r For This Useful Post: | HoustonM (03-17-2016) |
#18 |
Drives: UK GT86
.: Stealth 86 :.
Abbey Motorsport/K47 Tuned Sprintex 210 Supercharger Kodename 47 DJ: Soundcloud / Instagram / Facebook Last edited by Kodename47; 08-03-2017 at 05:58 PM. |
#19 | |
Drives: frs
| The Following User Says Thank You to Teseo For This Useful Post: | Kodename47 (08-03-2017) |
#20 |
#21 |
Drives: UK GT86
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | Teseo (08-03-2017) |
#22 |
So pretty much, possibly raise the target idle speed to 1000 RPM and then retard ignition timing for 1000 RPM in the first couple of low load cells?
My line of thinking is that if you have a higher idle, when it stumbles from the timing retard it won't drop low enough to kill the engine. The reason to change the ignition timing at the target idle speed is that's the only way to have the car hit that at idle, with doing it at 1000 RPM is all the OFT maps I've looked at have an 800 RPM row so as the idle drops, it will interpolate and the timing will pick back up to shoo the idle back up. I think all of this though would just make the car sound like it had the "Honda cough" i.e. bad IAC valve and a hunting idle though. Or I could be way off on all this.
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily 2013 BRZ limited - new toy |
#23 |
Drives: frs
So thats the sound of the new fiesta? Besides cats getting damage, what others parts are involded too?
#24 | |
Drives: UK GT86
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | nocoolname (08-05-2017) |
#25 |
Good point on the timing table not controlling idle. I'm still learning this car.
#26 |
Trying this as we speak.
If my neighbors get mad that I disturbed their Mariachi Karaoke session I'm telling them that Kodename47 made me do it. Sent from my Galaxy S8+ using Tapatalk |
#27 | |
Drives: brz
When vvt is enabled avcs is always active, idle or not. I know that's not popular belief but ecutek shows it operating, watch the duty cycle and solinoid current. When vvt enabled the pin is unlocked and it's running off the oil chambers in the phasers. Last edited by brzlegend; 09-01-2021 at 09:33 PM. |
| Ghost of Akina's 2013 Firestorm FRS | Ghost of Akina | Member's Car Journals | 3 | 08-22-2015 01:51 AM |
| Ghost Car/Dad | vividracing | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 07-23-2014 05:51 PM |
| Ghost Lights | DuroSquad | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 07-04-2014 07:14 AM |
| Ghost's BRZ Build | RurumariGhost | NY / NJ / CT / PA | 5 | 05-23-2013 09:31 PM |
