Old 03-15-2017, 01:22 PM   #99
iLaw
iLaw's Avatar
Drives: 2015 BRZ, Aozora Edition
Hey guys, super sorry it took this long. Life happened.
I was going to do a DIY video on it, but that will have to wait until spring, as the car is in storage.
The basic premise is that you have to use the relays to determine where the power is coming from. You use the relays to establish the following logic:
If Headlights are off and not signalling, power comes from signal (which will also be off)
If Headlights are off and signalling, power comes from signal
If Headlights are ON and not signalling, power comes from boomerang
If Headlights are ON and Signalling, Power comes from signal, for as long as signal is sending power.
The relays basically say if power isn't coming from X, than take it from Y. but you need two because you have two power sources, and two different states (headlights on or off).
I'll get my electrician friend to draw up a wiring diagram.
iLaw
2020 Subaru Crosstrek Sport
2015 Subaru BRZ Aozora Edition (Sold)
iLaw is offline   Reply With Quote
The Following 2 Users Say Thank You to iLaw For This Useful Post:
codesplice (03-15-2017), Deathalo (06-07-2017)
Old 03-28-2017, 07:19 AM   #100
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
Hey guys, just a thought.
If you want the rear parking lights (the ones on the side of the tail lamps) to do the same thing, you can just wire them into the rear signal wires. I haven't done it, the idea came to mind when I was swapping out my OEM tails for JDM tails. If anyone tries it out, post a video!
thatfilipinoguy is offline   Reply With Quote
Old 06-07-2017, 03:03 AM   #101
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
I'm looking forward to this right up as well if you're still going to do it, I wired my side markers up as turn signals but since I have the Always-On Module for the boomerangs from Diode Dynamics the Boomerangs now come on with the turn signals and the DRLs light up the side markers!
Deathalo is offline   Reply With Quote
Old 06-09-2017, 01:53 AM   #102
BaatLuk
Drives: Evo X
Originally Posted by treminaor View Post
I tapped the white turn signal harness wire on the passenger side and the red turn signal harness wire on the driver's side. I also un-crossed the wires within the driver's side turn signal so that power went to power and ground went to ground.
Thank you for making the video! I think this is how the side markers work outside of North America. They are purely turn signals, not parking lights (don't light up when low beams are on). Can anyone with an overseas/JDM BRZ/86 confirm? Here is a video of a BRZ in Hong Kong:
Personally I like how they blink in sync with the turn signals in the head/tail lights. Alternating just looks tacky to me.
Where are you guys buying your OEM JDM side markers? Do you have to get amber bulbs (I assume the stock USDM bulbs are clear?)?
BaatLuk is offline   Reply With Quote
The Following User Says Thank You to BaatLuk For This Useful Post:
treminaor (06-21-2017)
Old 07-06-2017, 03:07 AM   #103
BaatLuk
Drives: Evo X
Found my answer here: http://www.ft86club.com/forums/showthread.php?t=119784. treminaor's method will make your side markers function like the real deal (JDM).
treminaor (07-06-2017)
Old 08-03-2017, 02:46 AM   #104
BaatLuk
Drives: Evo X
Can anyone recommend a pair of amber LEDs (plug & play, no hyper flash)?
Old 08-03-2017, 05:19 PM   #105
thatfilipinoguy
there is no PnP LEDs that won't hyper flash, you need to either modify the stock module, or purchase one. but DD has great LEDs and the also have a cheaper (price) version of the tapturn module.
Old 08-05-2017, 01:43 AM   #106
BaatLuk
Drives: Evo X
Excuse my ignorance, when you say "stock module" what exactly are you referring to? How do I modify or purchase that?
Old 08-05-2017, 12:34 PM   #107
thatfilipinoguy
Stock flasher relay. There is a write up about how someone desoldered, and resoldered in a thicker gauge wire into the relay.
Old 08-06-2017, 02:28 AM   #108
BaatLuk
Drives: Evo X
hmmm that sounds like a lot of work just to be able run some LEDs as blinkers. I should be OK with some amber 194 bulbs like these: https://www.walmart.com/ip/Sylvania-...wl13=&veh=sem?
Old 09-18-2017, 04:15 PM   #109
BaatLuk
Drives: Evo X
A couple follow-up questions (please excuse my ignorance, no electrical expert here):
  1. To tab into the turn signal in the headlight and into the side marker, can I use a t tab connector like this one?
  2. What kind of wires should be used? Length? Where to buy them?
  3. The white/red wires should be cut and disconnected from the original source and tapped into the turn signal in headlight, correct?
  4. The black wire (ground?) should be left alone, correct?
Old 09-19-2017, 12:25 PM   #110
thatfilipinoguy
It's better to solder and heat shrink them than T-tapping, you might run into shorting issues if water gets introduced to the wiring. 18AWG is fine too, just make sure you get the multiple stranded wire, there is also a single wire but you don't want that one. And I am going to assume you have a BRZ, so that is as far as I can go with my advice! I hope I helped a little bit!
The Following User Says Thank You to thatfilipinoguy For This Useful Post:
BaatLuk (09-19-2017)
Old 12-02-2018, 07:34 PM   #111
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
No. You can't short + to +. That's not a thing. The problem with the taps is corrosion and loss of conductivity.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
thatfilipinoguy (12-04-2018)
Old 12-16-2018, 04:57 AM   #112
Mr_Eyo
Drives: 2017 Toyota 86
My circuit in action:
I wanted the sidemarkers to function like normal and to function as turn signals, so that meant:
1. Headlights OFF + turn signal OFF = sidemarker OFF
2. Headlights OFF + turn signal ON = sidemarker ON
3. Headlights ON + turn signal OFF = sidemarker ON
4. Headlights ON + turn signal ON = sidemarker OFF
In summary, I have the sidemarkers turn on XOR'd by the headlight power and turn signal power.
Logic schematic:
https://drive.google.com/open?id=16l...dG6AKch7wRs0pJ
I abandoned the OEM harness in place and ran my custom one through the driver side firewall grommet expansion. The logic modules are housed and potted in plastic enclosures I stashed in the driver side footwell cowl by the hood release latch.
Mr_Eyo is offline   Reply With Quote
The Following User Says Thank You to Mr_Eyo For This Useful Post:
Rican_D (12-20-2018)
clear side marker part number NOBROWS Cosmetic Modification (Interior/Exterior/Lighting) 34 09-11-2017 10:12 PM
**Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 nigel-jdmparts Exterior Parts - The Rest 524 02-28-2016 11:24 AM
Converting side marker to turn signals ayau Cosmetic Modification (Interior/Exterior/Lighting) 30 12-13-2015 04:41 PM
does your car come with side door marker light? excited86 CANADA 12 08-02-2012 07:07 PM
Raven blacked out side marker before and after Roadstercycle FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-24-2012 11:52 PM
