Old 08-02-2017, 09:33 PM   #1
Pinkbulate
Drives: 2013 Scion FRS 10 series
Plug and Play Footwell Kit Question
Hey guys, so I just acquired one of those plug and play footwell lighting kit that just plugs into the lighter plug with a remote to control colors, etc.
I was wondering if it's possible to mod it and have the light to only come on when I turn my headlights on. I only want to have it on during the night when I turn my headlights on tbh and I know it's easy enough to control with the remote but just wondering if anyone knows how to somehow tap it into the headlight switch.
Thanks
Pinkbulate is offline   Reply With Quote
Old 08-02-2017, 10:13 PM   #2
Chimera
Drives: FRS
Thanks
You need a relay kit
Old 08-24-2017, 08:48 PM   #3
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
A bit late, yes, but nobody's touched on this, so I'll give you the rundown:
Depending on the draw, you may be able to use the Illumination circuit that powers the dash and radio illumination when the lights turn on.
If the amperage is higher, you'd just want to have that illumination circuit engage a relay that powers the LEDs from the accessory line that runs the lighter plug.
I went all out and included the door triggers on my setup so the LEDs go to 100% when the door is opened, and dim back down with the cabin light until it hits my adjustable dimmer setting of 25%. That required some ingenuity on the wiring, but still possible
sharpsicle is offline   Reply With Quote
Old 08-24-2017, 09:59 PM   #4
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
That sounds cool, I'd like to see a video of it inaction.
DandoX is offline   Reply With Quote
Old 08-26-2017, 10:30 PM   #5
sharpsicle
sharpsicle's Avatar
Here you go! Sequence in the video is:
Everything off > Running lights on > Door open > Door closed (fade to illum)
[ame="https://www.youtube.com/watch?v=jPHvMeAtIRU"]BRZ Footwell Lighting - YouTube[/ame]
Where to get plug and play HID Burrcold CANADA 16 12-21-2016 02:45 PM
Plug and Play Lighting Question godeepwvu Cosmetic Modification (Interior/Exterior/Lighting) 9 07-31-2016 12:01 PM
Can I plug and play this amp? 7thgear Electronics | Audio | NAV | Infotainment 4 04-11-2015 04:26 PM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 10:53 AM
HID Plug 'n Play Kit JW89225 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 07-31-2012 12:17 AM
