#71 |
Drives: car
I mean to say, while the maintenance costs weren't unexpected, I still get sticker shock if I ever have to visit a dealership's shop.
It's been relatively easy maintaining the car, but dropping ~$1300 for maintenance after the first two years of ownership was a bit unexpected from when I first got the car. This week I'm about to drop another couple hundred to get ARP wheel studs installed, since the oem wheel studs are all breaking on me from just routine work changing brake pads. Not enjoying having to fix parts where subaru skimped on quality. |
#72 | |
Wheel studs breaking.... ? Like how? Ur driving and they break? Sent from my iPhone using Tapatalk |
#74 | |
Drives: '13 FRS - STX
Like, $1,300 I think is more than all my maintenance combined over 60k miles including spark plugs and coil packs and two transmission/diff fluid flushes... ~$500 for the spark plugs and 60k service ~$70 for the 30k transmission/differential fluid All regular intervals are $70 including a cabin air filter = $490 ARP studs on all four corners of my car = ~$120 Yeah unless I'm being a dunce I can only come up with ~$1200 worth of regular maintenance costs over 4.5 years of ownership... I mean, I've put a gallon or two of sweat into DIY'ing the maintenance, ~4 sets of tires, 2 sets of brake pads for track/autox, mods and alignment that I'm not counting because we're just talking about the basics here... Anyway, tl;dr dealerships are expensive as fuck and good luck when you decide to do your own oil and the drain plug is torqued to 200 ft-lbs. |
#75 | |
http://www.ft86club.com/forums/showthread.php?t=106898 http://www.ft86club.com/forums/showthread.php?t=51038 http://www.ft86club.com/forums/showthread.php?t=99843 They're not snapping off, the threads just wear out a lot faster than some of us expect. There's also people with a lot of abuse on their car/studs without problems. |
#76 |
Drives: '13 BRZ
#77 | |
Drives: '13 BRZ
I don't know the culture here, but maybe these complaints are common, and people are tired of them? I was hoping for a tight knit forum of FRS/BRZ brothers that stick together and help each other out. That said, I think you are justified to feel frustrated at having issues on such a new car. One reason I got my BRZ was that I wanted my DD to be a newer car, not a projec/weekendt car. I have read that the 2016+ fuel pump may solve the crickets problem. If it bothers you, you should look into that. I have not heard any in my car, so I can't judge whether you are overreacting. It's discouraging to read about someone having clutch and synchro issues on such a new car. I thought Toyota/Subarus are known to have reliable gearboxes. I know Outbacks can go 200k on an original gear box. Have you gotten someone to look at the issue? I hope you don't give up. It seems like the FRS is a special car, and all cars need some maintenance. Hopefully, if you sort out these early issues, you'll have some trouble free miles ahead. Last edited by LudwigMiles; 07-31-2017 at 10:03 PM. |
#78 | |
My DD is a Toyota Sequoia 03, bought it with 50k miles on it, 135k miles later and still runs perfectly fine, I haven't done anything major to it other than regular maintenance, amazing car. My fuel pump was replaced like 2k miles ago and haven't heard crickets ever since, and I took my car to the dealership today and apparently my transmission is bad so they'll replace it, hopefully that fixes the issues I'm having 🙂 |
| The Following User Says Thank You to Terruko For This Useful Post: | Tcoat (08-01-2017) |
#79 |
Persona Non Grata
Drives: '15 BRZ (WRB)
Good luck.
Slow is smooth, and smooth is fast
#80 | |
Drives: 2015 Scion FR-S
I've snapped one off and had another seize after having the tires rotated at my local dealer...
never. again. Quote:
#81 | |
$80 spark plugs $175 two coil packs $70 oil and filter change $80 transmission and diff fluid $20 brake fluid $10 cabin air filter $15 engine intake filter So I overestimated a bit and phrased it poorly, $450 and a sweaty summer afternoon. |
#82 |
Drives: 2013 FR-S 10 series [755]
#83 |
Drives: Toyota GT86 Coupe Red (UK)
Block shifting is perfectly acceptable on the way down the gears. Not on the way up, but those are for environmental / fuel saving guidelines rather than mechanical sympathy.
I think the most important thing about manual transmission is "Mechanical Sympathy". "Listen" to the gear box, "feel" the gear box. Don't slam, force, jam or otherwise hurt the gear box. Use the syncros gently, when it's ready it will pop into gear easily, almost pull the gear stick out of your hand into gear. If you do that and are patient the thing will last forever. My last GT86 got to 30k before I sold it, it never had an issue with the gear box. I frequently did 1st to 4th, 2nd to 6th, 3rd to 6th. I almost invariably do 6th to 3rd when stopping on a carriageway at lights. 6th is just too high to stop in and you can get into 3rd at pretty much any legal speed. My car before that was a Renault Clio @ 12 years old with 90k on the clock (2nd clutch though @65k as I abused it), no gear box issues. Before that a 16 yo Clio with 80k on the clock, no gearbox issues.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
| The Following User Says Thank You to paulca For This Useful Post: | Ultramaroon (08-01-2017) |
#84 | |
![]() Mechanical sympathy requires mechanical aptitude. I backed away from advocating the practice of "properly" skipping gates when I realized the wide range of understanding we see in members here. That's the one and only reason for the change in my tune.
| Just can not do this anymore | rskdsk | Other Vehicles & General Automotive Discussions | 79 | 02-27-2014 05:13 PM |
| not for sale anymore | whitefrs | Engine, Exhaust, Bolt-Ons | 44 | 10-28-2013 02:34 PM |
| not for sale anymore | whitefrs | Engine, Exhaust, Bolt-Ons | 7 | 10-23-2013 09:31 PM |
| I can't take it anymore | Terrapin77 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 25 | 09-02-2013 07:32 PM |
| Does anybody use their blinker anymore? | Shagaliscious | Off-Topic Lounge [WARNING: NO POLITICS] | 51 | 11-20-2012 02:14 PM |
