Old 07-31-2017, 08:26 PM   #71
radroach
Drives: car
I mean to say, while the maintenance costs weren't unexpected, I still get sticker shock if I ever have to visit a dealership's shop.
It's been relatively easy maintaining the car, but dropping ~$1300 for maintenance after the first two years of ownership was a bit unexpected from when I first got the car.
This week I'm about to drop another couple hundred to get ARP wheel studs installed, since the oem wheel studs are all breaking on me from just routine work changing brake pads. Not enjoying having to fix parts where subaru skimped on quality.
Old 07-31-2017, 08:29 PM   #72
allowe
allowe's Avatar
Originally Posted by radroach View Post
I've had a throwout bearing change, spark plugs, and now doing a wheel stud replacement all around because they're all breaking.
Wheel studs breaking.... ? Like how? Ur driving and they break?
allowe is offline   Reply With Quote
Old 07-31-2017, 08:41 PM   #73
radroach
Drives: car
@allowe
Old 07-31-2017, 08:42 PM   #74
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Oh, well I have a hunch you'd be getting charged about as much if you bought a base model Impreza and had it serviced at the same dealership.
Like, $1,300 I think is more than all my maintenance combined over 60k miles including spark plugs and coil packs and two transmission/diff fluid flushes...
~$500 for the spark plugs and 60k service
~$70 for the 30k transmission/differential fluid
All regular intervals are $70 including a cabin air filter = $490
ARP studs on all four corners of my car = ~$120
Yeah unless I'm being a dunce I can only come up with ~$1200 worth of regular maintenance costs over 4.5 years of ownership... I mean, I've put a gallon or two of sweat into DIY'ing the maintenance, ~4 sets of tires, 2 sets of brake pads for track/autox, mods and alignment that I'm not counting because we're just talking about the basics here...
Anyway, tl;dr dealerships are expensive as fuck and good luck when you decide to do your own oil and the drain plug is torqued to 200 ft-lbs.
ineedyourdiddly
Old 07-31-2017, 08:45 PM   #75
strat61caster
They can strip when you are taking on/off your wheels, I think the material isn't very hardy and it's very easy to get debris in there which tears the threads up right quick.
http://www.ft86club.com/forums/showthread.php?t=106898
http://www.ft86club.com/forums/showthread.php?t=51038
http://www.ft86club.com/forums/showthread.php?t=99843
They're not snapping off, the threads just wear out a lot faster than some of us expect. There's also people with a lot of abuse on their car/studs without problems.
ineedyourdiddly
Old 07-31-2017, 09:31 PM   #76
LudwigMiles
Drives: '13 BRZ
Hey Strat, if you're a DIY guy, why did you pay $500 to get spark plugs changed?
Is there a reason you didn't do that yourself ?
LudwigMiles is offline   Reply With Quote
Old 07-31-2017, 09:36 PM   #77
LudwigMiles
Drives: '13 BRZ
Originally Posted by Terruko View Post
Ever since I bought my FR-S it's been giving me problems, from crickets to bad TOB, and now grinding at low rpms and probably the synchros going bad. I'm thinking about just trading it in at a loss and getting something better, this car seems to be full of issues
I'm brand new to owning a BRZ, and feel bad you've being attacked for your frustrations.
I don't know the culture here, but maybe these complaints are common, and people are tired of them?
I was hoping for a tight knit forum of FRS/BRZ brothers that stick together and help each other out.
That said, I think you are justified to feel frustrated at having issues on such a new car.
One reason I got my BRZ was that I wanted my DD to be a newer car, not a projec/weekendt car.
I have read that the 2016+ fuel pump may solve the crickets problem.
If it bothers you, you should look into that.
I have not heard any in my car, so I can't judge whether you are overreacting.
It's discouraging to read about someone having clutch and synchro issues on such a new car.
I thought Toyota/Subarus are known to have reliable gearboxes.
I know Outbacks can go 200k on an original gear box.
Have you gotten someone to look at the issue?
I hope you don't give up.
It seems like the FRS is a special car, and all cars need some maintenance.
Hopefully, if you sort out these early issues, you'll have some trouble free miles ahead.
Old 07-31-2017, 09:46 PM   #78
Terruko
Terruko's Avatar
Originally Posted by LudwigMiles View Post
I'm one day into owning a BRZ, and I feel bad you've been attacked for your frustrations. I was hoping for a more tight knit community of FRS/BRZ brothers.
I think you are justified to feel frustrated at having issues. One reason I got my BRZ was that I wanted my DD to be a newer car, not a projec/weekendt car.
I have read that the 2016+ fuel pump may solve the crickets problem. If it bothers you, you should look into that. I have not heard any in my car, so I can't judge whether you are overreacting.
It's discouraging to read about someone having clutch and synchro issues on such a new car. I thought Toyota/Subarus are known to have reliable gearboxes. I know Outbacks can go 200k on an original gear box. Have you gotten someone to look at the issue?
My DD is a Toyota Sequoia 03, bought it with 50k miles on it, 135k miles later and still runs perfectly fine, I haven't done anything major to it other than regular maintenance, amazing car.
My fuel pump was replaced like 2k miles ago and haven't heard crickets ever since, and I took my car to the dealership today and apparently my transmission is bad so they'll replace it, hopefully that fixes the issues I'm having 🙂
Terruko is offline   Reply With Quote
The Following User Says Thank You to Terruko For This Useful Post:
Tcoat (08-01-2017)
Old 07-31-2017, 09:55 PM   #79
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Good luck.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 07-31-2017, 11:36 PM   #80
e_lunatic
Drives: 2015 Scion FR-S
I've snapped one off and had another seize after having the tires rotated at my local dealer...
never. again.
e_lunatic is offline   Reply With Quote
Old 08-01-2017, 02:02 AM   #81
strat61caster
I did. Here's how much I spent on my 60k service.
$80 spark plugs
$175 two coil packs
$70 oil and filter change
$80 transmission and diff fluid
$20 brake fluid
$10 cabin air filter
$15 engine intake filter
So I overestimated a bit and phrased it poorly, $450 and a sweaty summer afternoon.
ineedyourdiddly
Old 08-01-2017, 02:33 AM   #82
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Originally Posted by Th3rdSun View Post
Here,I fixed it for you.
NO you are still WRONG!!!! I drive my other "car", broken, and dump it!!!!!
JK lol.
FR-Sky is offline   Reply With Quote
Old 08-01-2017, 02:50 AM   #83
paulca
Drives: Toyota GT86 Coupe Red (UK)
Would you skip gears on a driving test in the UK?
Block shifting is perfectly acceptable on the way down the gears. Not on the way up, but those are for environmental / fuel saving guidelines rather than mechanical sympathy.
I think the most important thing about manual transmission is "Mechanical Sympathy". "Listen" to the gear box, "feel" the gear box. Don't slam, force, jam or otherwise hurt the gear box. Use the syncros gently, when it's ready it will pop into gear easily, almost pull the gear stick out of your hand into gear.
If you do that and are patient the thing will last forever.
My last GT86 got to 30k before I sold it, it never had an issue with the gear box. I frequently did 1st to 4th, 2nd to 6th, 3rd to 6th. I almost invariably do 6th to 3rd when stopping on a carriageway at lights. 6th is just too high to stop in and you can get into 3rd at pretty much any legal speed.
My car before that was a Renault Clio @ 12 years old with 90k on the clock (2nd clutch though @65k as I abused it), no gear box issues. Before that a 16 yo Clio with 80k on the clock, no gearbox issues.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
The Following User Says Thank You to paulca For This Useful Post:
Ultramaroon (08-01-2017)
Old 08-01-2017, 03:56 PM   #84
Originally Posted by paulca View Post
I think the most important thing about manual transmission is "Mechanical Sympathy"...
We are of exactly the same mindset.
Mechanical sympathy requires mechanical aptitude. I backed away from advocating the practice of "properly" skipping gates when I realized the wide range of understanding we see in members here. That's the one and only reason for the change in my tune.
Just can not do this anymore rskdsk Other Vehicles & General Automotive Discussions 79 02-27-2014 05:13 PM
not for sale anymore whitefrs Engine, Exhaust, Bolt-Ons 44 10-28-2013 02:34 PM
not for sale anymore whitefrs Engine, Exhaust, Bolt-Ons 7 10-23-2013 09:31 PM
I can't take it anymore Terrapin77 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 25 09-02-2013 07:32 PM
Does anybody use their blinker anymore? Shagaliscious Off-Topic Lounge [WARNING: NO POLITICS] 51 11-20-2012 02:14 PM
