Old 07-20-2017, 08:18 PM   #1
Mehairi
Early Performance
Drives: Bagged, Boosted RocketBunny V2
Air Lift Performance BRZ question!
Hello!
I'm getting an Air lift Performance 3P kit soon for my BRZ, and was wondering how do people slightly camber to tuck the wheels while aired out only to fit under the rocket bunny fenders. Because my front wheels are 18x9.5 +35 and require 25mm spacers to fit and they're slightly out of the fenders.
Mehairi is offline   Reply With Quote
Old 07-31-2017, 03:40 AM   #2
Battlerobot
Drives: '16 Hyperblue BRZ
When you air out and the car is lowered, it naturally adds more camber.
Battlerobot is offline   Reply With Quote
Old 07-31-2017, 04:58 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
Pitty it also changes toe together with camber, one thing i don't like in dynamically height adjustable suspension like air lift ones, making alignment dialed in ideal at just one of height.
Mehairi: cheapest camber adjustment front is with camberbolts. -1 to -1.5 extra camber with ones in lower strut hole (SPC 81305), and upto ~ -2.3 if you add also Whiteline KCA416 in upper hole. If lowered, one can get -2.5. If you need camber adjustment in rear too, you need LCAs. Cheapest are SPC/Whiteline/Eibach clones.
airlift performance, camber, wheel fitment
Air Lift Performance Issues csong30 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 10-27-2016 07:56 AM
Air Lift Question csong30 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-30-2016 10:37 AM
Air lift performance kit with V2 management Kaytuu Brakes, Suspension, Chassis 6 08-16-2016 12:31 PM
Air lift performance air struts w/ Accuair management RavenFR-Sowner Brakes, Suspension, Chassis 8 04-01-2015 12:14 AM
Air Lift Performance Air Suspension In Stock at RallySportDirect.com!! RallySport Direct Brakes, Suspension, Chassis 14 06-03-2014 11:11 AM
