eddieEndo
Old 07-11-2017, 05:30 AM   #211
Fainten
Fainten's Avatar
Drives: white brz
Originally Posted by BAD ROD View Post
I’m sticking with stock height for now. Living in the mountains, I’ve about tore the front bumper off a few times.
My setup: Work Wheels T7R 18x9.5 +38, 245/35/18
The TRD fender extensions drop about ½ inch closing the wheel gap.
I have 18X9.5 +35 wheels, are your wheels rubbing on your stock suspension? or rubbing/scrapping at all.I want to run the same tire size as well but i want to know if i can run that width on stock suspension
Fainten is offline   Reply With Quote
Old 07-16-2017, 08:27 PM   #212
joeyf1986
Drives: 2017 BRZ
RPF1 17x9 +35 wrapped up in 245/45
joeyf1986 is offline   Reply With Quote
The Following 2 Users Say Thank You to joeyf1986 For This Useful Post:
rookietopro_frs (07-31-2017), sniffpetrol (02-18-2018)
Old 07-30-2017, 12:35 AM   #213
Waffle86
Waffle86's Avatar
Drives: 2013 SWP BRZ Limited
Setup:
Avid1 AV20 18x9.5 +38
Continental DWS 06 235/40/18
Name:  driver side_small.jpg
3.5 finger wheel gap, only have about 2mm clearance to the spring perch - no rubbing as of yet. Was hoping to get some eibach sportline springs soon but at this point I'm almost certain I'll rub just due to natural camber from the drop. Likely I'll have coils coming soon to give me peace of mind...
Waffle86 is offline   Reply With Quote
The Following User Says Thank You to Waffle86 For This Useful Post:
Teseo (09-04-2017)
Old 07-30-2017, 12:45 AM   #214
Waffle86
Waffle86's Avatar
Every car is a little different so it's a bit of a gamble...
I'm running 18x9.5 +38 235/40 and I BARELY clear the spring perch, maybe 1-2mm (less than a finger). I did a lot of research before committing to my setup and anticipated more like 5mm based off other's build on here (hence the gamble). In short, I went 235/40 as I knew it'd be a tight fit.
+35 will give you an extra 3mm to work with, so in theory you should be fine running 245/35, but again it's hard to know for sure until you test fit. Buy the wheels you want, test fit, and then order tires once you know what you have to work with.
The Following 2 Users Say Thank You to Waffle86 For This Useful Post:
Leonardo (09-04-2017), SStratos (09-28-2017)
Old 07-30-2017, 09:24 PM   #215
Cordelia
Cordelia's Avatar
Drives: 2017 86 Steel
Originally Posted by Waffle86 View Post
Setup:
Attachment 156463
Attachment 156464
Super sweet.. would love the machined version of those wheels on my steel 86
Cordelia is offline   Reply With Quote
The Following User Says Thank You to Cordelia For This Useful Post:
Waffle86 (08-01-2017)
Old 07-31-2017, 04:24 AM   #216
rookietopro_frs
rookietopro_frs's Avatar
Drives: 2013 Scion FRS
I'm trying to pick something other than RPF1s but they look so good + excellent weight.
rookietopro_frs is offline   Reply With Quote
Old 09-01-2017, 10:11 PM   #217
FRS13_
FRS13_'s Avatar
Drives: 2013 Scion FRS 6-speed
2013 FRS
17x9 +38 square set up.
245/40-17
Stock suspension.
Have had over a year, no rubbing at all.
Sent from my SAMSUNG-SM-G930A using Tapatalk
FRS13_ is offline   Reply With Quote
The Following 2 Users Say Thank You to FRS13_ For This Useful Post:
86geek (09-02-2017), SStratos (09-28-2017)
Old 09-04-2017, 01:09 PM   #218
BAD ROD
Drives: 2014 BRZ
No rubbing whatsoever.
BAD ROD is offline   Reply With Quote
Old 09-11-2017, 01:08 AM   #219
dejahboi
dejahboi's Avatar
Drives: 13 FRS - Boosted
here's couple pictures of 57CR 18x9.5 +38 when I was on stock suspension
Sent from my SAMSUNG-SM-G935A using Tapatalk
dejahboi is offline   Reply With Quote
The Following User Says Thank You to dejahboi For This Useful Post:
rookietopro_frs (09-20-2017)
Old 09-12-2017, 11:25 PM   #220
BAD ROD
Drives: 2014 BRZ
What size tires?
Old 09-16-2017, 01:48 PM   #221
86Ryan
86Ryan's Avatar
Drives: 2013 ULTRAMARINE FRS
Stock height + Aftermarket wheels compilation!!!!
Stock height with some WRX wheels
Instagram: Roger_Dabbit
86Ryan is offline   Reply With Quote
The Following User Says Thank You to 86Ryan For This Useful Post:
Old 09-20-2017, 05:37 AM   #222
rookietopro_frs
What size tires?
I want to know too, cause that looks clean !
Old 09-20-2017, 12:47 PM   #223
dejahboi
dejahboi's Avatar
245/35R18
BAD ROD (09-20-2017)
Old 09-22-2017, 01:53 AM   #224
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
Oh man! This is exactly the look I'm going for. What specs for the tires? Those are TS6's? I have my cart at tirerack with T6S 18x8.5 +45, HTR Z III 255/35ZR18 for about $1300. But I don't really know what I'm doing. (am noob). Need a little guidance!
Originally Posted by eddieEndo View Post
Lakitu is offline   Reply With Quote
Aftermarket lug nuts on stock wheels: confirm? empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 09-19-2018 07:38 PM
Aftermarket wheels with stock suspension Thongpocket Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-24-2013 05:08 PM
Stock TPMS's with aftermarket valves/wheels? Phaedrus29 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2012 01:18 PM
Need help with Stock height measurement D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-03-2012 03:30 AM
Aftermarket wheels on stock BRZ/86s yajin BRZ Photos, Videos, Wallpapers, Gallery Forum 2 05-01-2012 02:52 AM
