Old 07-29-2017, 04:14 PM   #1
PulpBrah
Drives: 2014 frs
AC blows hot air at idle, cool air when moving.
My sister is having an issue in her 86 where the car blows hot air at idle and cool air at speed.
A simple Google search has me thinking compressor or radiator fans , but I haven't the slightest clue how AC systems work. Any help is greatly appreciated.
PulpBrah is offline   Reply With Quote
Old 07-29-2017, 04:21 PM   #2
tell her to idle the engine at 1500 steadily. The compressor doesn't keep up when it's idling.
Old 07-29-2017, 04:30 PM   #3
In addition, suggest to her that she punch the recirc button also......
Old 07-29-2017, 05:09 PM   #4
amen. set the director thing all the way to the left so it pulls up from the footwell and blows it all out the top.
Otherwise, you get less cool air in the cabin while, in the footwell, the air gets nice and chilly from recirculating into itself.
Old 07-29-2017, 09:31 PM   #5
stevesnj
stevesnj's Avatar
The AC relies on air moving through the condenser, it's a thin radiator like unit in front of the engine coolant radiator. The condenser releases heat from the hot A/C system refrigerant passing through it, to the atmosphere, no hot air escaping from the condenser no or insufficient cool air inside the car. As said above turn on the Recirculate button to prevent the hot outside air trying to be cooled and force the cabin air to be cooled. It's a typical problem and nothing is broken.
My 2016 Build thread
Old 07-29-2017, 10:51 PM   #6
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
The AC in this car is not great. It's a small engine and I think they engineered the AC system to be marginal to save a little engine power.
guybo is offline   Reply With Quote
Old 07-29-2017, 11:12 PM   #7
steve99
Drives: FT86
When the cars stationary at idle (or below about 60km road speed) electric fans will run when a/c compressor kicks in to remove heat from a/c and engine radiators.
If the A/C worked fine before and now its not working at idle but ok at speed it usually means low gass in a/c. As a/c compressor speeds up with engine rpm it copes a bit better with low gass in a/c. Just take it to dealer if its warrantee or an A/C shop so they can find/repair leak and re-gass
Old 07-29-2017, 11:45 PM   #8
Do you often sit idle or move slowly in hot traffic jams? Serious question because I do, and mine has performed exactly the same way since day one.
I've heard rumor that some may have been undercharged at the factory and, if true, it may explain why mine is marginal when idling. I just figured with a high-revving engine, in order to get it to work in the widest range of rpm, they geared it to the edge at idle.
Old 07-29-2017, 11:59 PM   #9
steve99
Drives: FT86
I don't drive in a lot of stop start traffic , but I have not noticed the a/c doesn't work in traffic and we see 35C plus in summer, my idle is 650 rpm as well
if you hear a lot of hissing and gurgling inside the car its also an indication gass is low
Old 07-30-2017, 12:07 AM   #10
same kind of deal with your fridge, if gass is low the freezer part works kind of ok, but the fridge section is usually warm
Yes, I know that, but an automotive AC system is VERY different from a refrigerator. There are other factors at play.
If I start out driving normally, it works perfectly. My afternoon daily commute involves stop & go immediately. It takes much longer to work if I don't high-idle it for the first 5-10 minutes. It tends to drop off when I'm at a complete standstill.
Old 07-30-2017, 12:12 AM   #11
Hmmm... I do. Not a gurgle but I hear it hiss a little when it cycles to keep from frosting over the evaporator. I hear the same thing in most vehicles, though.
Engine blows out SquadRogue Scion FR-S / Toyota 86 GT86 General Forum 75 06-10-2018 04:58 PM
Auto launch blows! feldy Engine, Exhaust, Transmission 83 04-14-2017 10:42 AM
Dr. Destructo blows a rocker apart Element Tuning Engine, Exhaust, Transmission 82 12-04-2015 03:00 PM
Random Chirp while moving. NOT idle chirp. Stephens Issues | Warranty | Recalls / TSB 18 08-14-2013 12:02 PM
This blows... finch1750 Electronics | Audio | NAV | Infotainment 19 06-21-2012 12:03 PM
