Old 07-28-2017, 09:25 AM   #575
NINE
Drives: 2015 BRZ
Wow, very cool build you did!
Daily: 2008 IS250 (Stock)
Toy: 2015 BRZ (KW V3, TE37sl) More to come.
Past: 2008 BMW M3, 1976 Datsun 280z, 1998 240sx, 1990 180sx, 2005 RSX-S, 2003 IS300, 2001 Civic.
NINE is offline   Reply With Quote
Old 07-28-2017, 10:57 AM   #576
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Originally Posted by DSOmegaX View Post
Out goes the spare, in goes the shelf. Yes controversial choice but I don't really drive the car far anyway and when I do, I can put the spare back in. Either way have AAA to cover if anything does happen.
where did you get the shelf/tray from?
shiumai is offline   Reply With Quote
Old 07-28-2017, 04:58 PM   #577
DSOmegaX
DSOmegaX's Avatar
Usual source from Japanparts. Link is HERE. I don't remember what the part number is but the Toyota item code is 64429F.
@dsomegax.cars
The Following User Says Thank You to DSOmegaX For This Useful Post:
shiumai (07-28-2017)
Old 07-29-2017, 12:22 PM   #578
Pho20
Drives: 2013 Subaru BRZ
Do you think now that the ts is coming to the USA parts will be available through us dealers? I'm wanting that rear subframe but $500 in shipping is brutal
Pho20 is offline   Reply With Quote
Old 07-29-2017, 01:32 PM   #579
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Why do you want the rear subframe? Keep in mind that some of the parts are just the same. They just have different bushings. I don't remember anyone identifying any difference in the subframe apart from the bushings. Same holds for the rear lateral and trailing links. Same part, with just changed bushes to pillow ball bushings.
The Following User Says Thank You to nikitopo For This Useful Post:
Ravenna (07-29-2017)
Old 07-29-2017, 03:05 PM   #580
Pho20
I think(in this build or it could be someone else) it was mentioned it was the path of least resistance to just buy the subframe with all the bushings installed vs buying all the bushings and paying for someone to press them in
Old 07-29-2017, 03:50 PM   #581
DSOmegaX
DSOmegaX's Avatar
Unless those parts are on the US version of the tS (which I doubt), don't expect them to be. JSM parts will still only be distributed to their intended market.
@dsomegax.cars
Old 07-29-2017, 06:42 PM   #582
matchamochi
matchamochi's Avatar
Drives: swp brz
Thoughts on the transmission mount? I tried to search back, but couldn't find it.
matchamochi is offline   Reply With Quote
Old 07-31-2017, 03:16 PM   #583
DSOmegaX
DSOmegaX's Avatar
It's actually hard for me to provide details on the transmission mount alone as I did all the mounts and bushings at the same time. There's definitely more feedback but also more vibration in the shifter, especially at idle. It's definitely less so than a lot of other mounts as STi uses hardened rubber rather than polyurethane.
@dsomegax.cars
matchamochi (08-02-2017)
Old 07-31-2017, 03:17 PM   #584
DSOmegaX
DSOmegaX's Avatar
DSOmegaX STi BRZ tS Completed Build
There's a new mod here haha. Subtlety is key.
@dsomegax.cars
Dan37BRZ (08-03-2017)
Old 08-03-2017, 03:01 AM   #585
Dan37BRZ
Senior Citizen
Drives: 2015 WRB BRZ
Sweet!
I was thinking about getting the same TRD Fender Extensions painted WRB. Do you have a shot further away with both and rear?
Dan37BRZ is offline   Reply With Quote
Old 08-03-2017, 03:10 PM   #586
DSOmegaX
DSOmegaX's Avatar
Originally Posted by Dan37BRZ View Post
Sweet!
Unfornunately I don't have the rear on yet as there was a minor issue with paint. It's currently back at the shop to be refinished.
@dsomegax.cars
The Following 2 Users Say Thank You to DSOmegaX For This Useful Post:
Dan37BRZ (08-05-2017), Mr.Impreza (08-03-2017)
Old 08-05-2017, 02:03 PM   #587
Dan37BRZ
Senior Citizen
That looks GREAT, very subtle and clean addition.
Please post pics once you get the rears on, this mod was something I've been contemplating adding for a while now but there are only a few pics online and not in WRB.
Old 08-12-2017, 12:20 PM   #588
DSOmegaX
DSOmegaX's Avatar
@dsomegax.cars
Dan37BRZ (08-15-2017), Mr.Impreza (08-12-2017)
Completed build JK21 Member's Car Journals 46 12-11-2014 09:48 AM
Completed!! FBM 700+HP Build Dyno graph & Vid inside FullBlown Forced Induction 214 03-31-2014 01:56 PM
Vinyl wrap completed!! laley81 Southern California 14 08-30-2013 11:10 PM
Nearly Completed my Firstorm Build - Lots of Pics msile Member's Car Journals 52 03-10-2013 10:25 AM
Turbo FRS completed! Philly CANADA 24 09-03-2012 09:18 AM
