Old 07-27-2017, 10:46 AM   #29
Helios
Helios's Avatar
Drives: 2014 Red Subaru BRZ
Originally Posted by venturaII View Post
Drop to 32 all around and redrive the same stretch of road that you noticed the behavior and see if it improves.
EDIT: just googled 'Riken Raptor HR' as I wasn't familiar with them...these seem to be a big step down from the OEM tires. You might just be finding out why they're only charging 65 bucks per tire...
Dude, could have gotten the Kuhmo Ecsta PS31 for not much more. Of course they are "ultra high performance summer" tires and I'm sure they wouldn't be very good in NJ winter. Also, I just upgraded to wider wheels and bigger tires. I have a full set of good condition OEM wheels/ tires that I'll eventually put up for sale. Lots of tread life left. I don't even want much for them as much as I just want them out of my garage taking up space.
Helios is offline   Reply With Quote
Old 07-27-2017, 11:05 AM   #30
OND
OND's Avatar
Drives: 2023 BRZ
Yeah, I just got a set of Kumho Ecsta LE Sports for $205.
OND is offline   Reply With Quote
Old 07-27-2017, 11:14 AM   #31
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Has millionaire in username, buys super cheap junk tires for a sports car.
Originally Posted by humfrz
I'm old and lazy
OND (07-27-2017)
Old 07-27-2017, 11:57 AM   #32
Slammillionaire
Slammillionaire's Avatar
Drives: 2013 Hot Lava FRS
Very helpful. Not going to bother explaining the name beyond it's a parody and old inside joke that stuck. Had a hard budget of $300 to my door. Shitty tires or not, I needed something fast to replace my bald stock tires. These won't be on the car for more than a few months so they will serve their purpose as long as I can figure out this issue.
Slammillionaire is offline   Reply With Quote
The Following 2 Users Say Thank You to Slammillionaire For This Useful Post:
bhmax (07-27-2017), stevesnj (07-27-2017)
Old 07-27-2017, 10:32 PM   #33
stevesnj
stevesnj's Avatar
I'd take it easy on them and just wait the few months. Drive more cautiously. Be patient .
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
Slammillionaire (07-28-2017)
Old 07-28-2017, 08:13 AM   #34
ZDan
ZDan's Avatar
Drives: '23 BRZ
You should not "be patient" if the tires are causing a pull to one side on acceleration and to the other side off-throttle. Swap rear tires left/right to confirm bad tire, and return them all and get something decent.
Helios (07-28-2017)
Old 07-28-2017, 06:44 PM   #35
stevesnj
stevesnj's Avatar
He apparently doesn't have the funds to do otherwise, they will be fine if he doesn't over do it. For a few months it's easy to wait.
Old 07-29-2017, 08:01 AM   #36
ZDan
ZDan's Avatar
Drives: '23 BRZ
If tires are new, he should be able return them for a refund or credit toward another set of tires. From evidence presented it seems to me that at least one tire is DEFECTIVE. No reason to drive on a defective tire or tires for months in unreasonable hopes that it will "fix itself". And at that point you'd likely only be able to get prorated refund on the one defective tire. Or nothing...
Old 07-29-2017, 11:12 AM   #37
stevesnj
stevesnj's Avatar
I agree, I'm just going by what he's stating.
Old 07-29-2017, 05:28 PM   #38
Silver Supra
Hombre
Silver Supra's Avatar
Drives: 1994 Supra Turbo
I doubt many tire dealers will give anything like a full refund for a set of tires that have been used at all. They can't resell them as new.
However, it is worth a try, and at least get them to replace a tire if one or more are defective. I think they can send those back.
A Toyota Racecar A Toyota......................Because.
Anyway, should not palindrome be spelled palinilap?
Silver Supra is offline   Reply With Quote
Old 12-11-2017, 01:38 PM   #39
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Semi-old thread, and not season-appropriate in my neck of the woods, but I thought I'd try and save some bread by shopping for badly-needed summer tires while the snow tires were on the FR-S. Came across ridiculously cheap Riken Raptor ZR tires which I'd never heard of but understand they're made by Michelin ..
https://www.tirerack.com/tires/tires...um=145WR7RZRXL
Searched this forum and found this thread which was about the more sedate HR tire, but couldn't anything else about the ZR other than one thread that was about "fitment," looks, and other stuff I don't care about.
I don't track, I do drive a lot, and enjoy driving the car; I'm not a speeder and on the highway, I get passed way more than I pass, but on back roads and twisties I drive.. ahem.. "spiritedly" I guess.. and I usually catch up to folks with cars that don't handle as well. That's my driving habits... and I average about 15K miles a year.
Looking for a tire that is a good mix of performance on wet and dry roads, longevity, and value. Very rainy here in the summer, so wet grip matters. Any experience with the ZR? Sure would love to find something that cheap that is still a good tire..
Thanks..
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
Old 12-11-2017, 01:49 PM   #40
Slammillionaire
Thanks..
So after letting these tires wear in a little, they aren't anywhere near as bad as they were but honestly I don't think i could recommend this brand on our cars and not feel guilty. Save up some more and get something a bit better and thank me later.
Old 12-11-2017, 02:08 PM   #41
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Skimmed this thread. A few things that I didn't see clearly mentioned:
1. Going from bald tires to new tires will ALWAYS result in more "swaying," as you called it. Nearly bald tires have no tread. This is bad for many things, but good for "responsiveness." When you replace them, you now have a tire with a lot of tread. That tread can deform and squirm. New tires will always, therefore, feel squishier and a bit mushier than your old tires, as they ARE squishier and mushier. That's why some people who buy tires for competition have the tread shaved. They can afford to replace tires more frequently, so they shave off half of the tread so the tire is more responsive.
2. You went from stock size (215/45) to a larger size (225/45). That second number is a PERCENTAGE of the first number, not an outright measurement. That means you bought a tire with a taller sidewall, which means more flex, which means mushier handling (more sway, as you called it.)
Both of those things can, on their own, add up to a significant increase in sway. Couple that with things people here HAVE already mentioned (that you bought shitty tires) and it all adds up. I don't understand why people put shitty tires on ANY cars. It doesn't matter what car you have. At the end of the day, you only have a few square inches of rubber touching the pavement. If that rubber is crap, the car, be it a Toyota Corolla, or a Ferrari 488 GTB, will handle like crap.
Just say no to cheap tires.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 12-11-2017, 02:19 PM   #42
Slammillionaire
Yeah sometimes you gotta learn the hard way, you are absolutely correct in your analysis. My decision was based out of desperation, i needed new tires right then and only had a certain amount I was able to spend. This summer when I put some MPSS's on maybe my car will forgive me
The Following User Says Thank You to Slammillionaire For This Useful Post:
Stang70Fastback (12-11-2017)
TRD Springs and Sways Shark_Bait88 Want-To-Buy Requests 0 10-25-2016 12:03 PM
Need some help...Sways & Springs Lebby83 BRZ First-Gen (2012+) — General Topics 2 06-08-2015 09:42 PM
No sways BadCompany235 Tracking / Autocross / HPDE / Drifting 13 08-20-2013 01:05 PM
Buying sways.. _F-R-S_ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 11-14-2012 10:07 PM
