Old 11-10-2012, 10:48 AM   #1
_F-R-S_
Drives: 13 whiteout scion frs
Buying sways..
Whiteline sways with adjustable extenders with bc coilovers but heres my question what else will i need o make this a complete package. How to make everything really work together with veveryhing. Also aany suggestions on good control arms with all this
_F-R-S_ is offline   Reply With Quote
Old 11-10-2012, 11:07 AM   #2
Racecomp Engineering
That's all you need. We're running the Whiteline 20mm front and 16mm rear bars on our car right now with protoptype RCE/KW Tarmac 2 coilovers and it is just about perfect.
- Andrew
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
Bluecille (11-11-2012), _F-R-S_ (11-10-2012)
Old 11-10-2012, 11:15 AM   #3
_F-R-S_
Appriciate it thanks alot!!
Old 11-10-2012, 11:18 AM   #4
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
You need rear control arms for camber correction? I have SPC which are inexpensive and do the job, the new Whiteline ones look amazing but i'm sure you will pay for it.
JoeBoxer is offline   Reply With Quote
Old 11-10-2012, 05:19 PM   #5
gmookher
seeking 22/16
gmookher is offline   Reply With Quote
Old 11-10-2012, 06:19 PM   #6
JoeBoxer
JoeBoxer's Avatar
Originally Posted by gmookher View Post
seeking 22/16
Just get the Whiteline 20mm adjustable front and put on the hard setting. 20/16 seems to be fine.
Old 11-10-2012, 08:17 PM   #7
gmookher
Joe, what Tires you on?
same with
- Andrew
what tires, curious?
Old 11-10-2012, 08:58 PM   #8
_F-R-S_
Adjustable is perfect that way change it every track day
Old 11-10-2012, 10:35 PM   #9
JoeBoxer
JoeBoxer's Avatar
Nitto motivo, regretting it too I should have went with something more grippy.
Old 11-10-2012, 10:47 PM   #10
gmookher
as you address higher speeds, higher grip, I think the 22mm set soft may be interesting. some of this is gonna be about car setup dialability; ie, being able to switch to a race compounds. Interesting in trying both 20 and 22 after this thread
Old 11-11-2012, 12:00 AM   #11
JoeBoxer
JoeBoxer's Avatar
I am probably just going to get the fixed 20mm front and the adjustable 16mm rear.
Old 11-11-2012, 09:06 AM   #12
armythug
armythug's Avatar
Drives: Pegasus White 86GTS
Solid bars right?
Pegasus White 6MT got it. :happy0180:
armythug is offline   Reply With Quote
Old 11-11-2012, 09:15 AM   #13
JoeBoxer
JoeBoxer's Avatar
Originally Posted by armythug View Post
Solid bars right?
correct, hotchkis and eibach are 25.4/19 but they are hollow...
Old 11-11-2012, 09:36 AM   #14
ironchef
ironchef's Avatar
Drives: GLI
Noob question.
How important are sway bars for the person who DDs and does maybe 3-4 HPDEs a year?
ironchef is offline   Reply With Quote
If you are buying a BRZ how old are you? blackmist27 BRZ First-Gen (2012+) — General Topics 205 03-07-2013 08:18 PM
Im buying one. Griffdawg Scion FR-S / Toyota 86 GT86 General Forum 10 06-19-2012 01:12 PM
buying BRZ or FRS DIG1992 NY / NJ / CT / PA 10 03-11-2012 11:26 AM
Why I am buying a BRZ BMWDAD BRZ First-Gen (2012+) — General Topics 37 01-01-2012 09:01 PM
