Old 07-20-2017, 11:25 AM   #169
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
Originally Posted by smg1138 View Post
Anybody know where to find the 18x8.5's in stock? That seems like the perfect size to me.
we can order them for you but distribution is out of stock, the 18x9.5 is the popular size and what is stocked, so your best bet would be to pre-order
Kami Speed is offline   Reply With Quote
The Following User Says Thank You to Kami Speed For This Useful Post:
smg1138 (07-20-2017)
Old 07-20-2017, 08:20 PM   #170
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I just realized they're +45's which may not be enough inside clearance. Would probably need spacers to prevent rubbing the fender liner under compression. Thanks for the info though.
smg1138 is offline   Reply With Quote
Old 07-21-2017, 10:56 AM   #171
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
you're worried about 18x8.5 +45 hitting on the inside?
Old 07-28-2017, 07:01 PM   #172
derekbrz24
derekbrz24's Avatar
Drives: 2017 Subaru BRZ WRB PP
Has anyone tried these wheels on the performance pack brembos? I plan on running RCE springs and camber bolts.
derekbrz24 is offline   Reply With Quote
Old 07-28-2017, 07:14 PM   #173
Trudat02
Drives: 17 BRZ
Yes I have a set of 18 x 9.5 +38 offset on my 17' PP. I posted some pics of them on some earlier posts if you want to see them.
Sent from my SM-G955U using Tapatalk
Trudat02 is offline   Reply With Quote
Old 07-28-2017, 07:43 PM   #174
smg1138
smg1138's Avatar
Got my 17x9 +38's today! Looks like in this size the Gun Blue II's weigh in right at 18lbs. Not bad for 5 spoke cast wheel that's this wide.
The Following 4 Users Say Thank You to smg1138 For This Useful Post:
Clipdat (07-28-2017), jubella2 (08-03-2017), Kami Speed (08-01-2017), rookietopro_frs (08-07-2017)
Old 07-28-2017, 11:03 PM   #175
derekbrz24
derekbrz24's Avatar
Awesome I'll check it out. Do you think the 17x9 +38 would clear the fronts? Or would spacers be needed? 86speed posted a video on instragram it was tight but no worse than the stock wheels on the PP.
Old 07-29-2017, 08:24 PM   #176
envyme
Drives: Toyota 86 2017
Originally Posted by thecarfilmer View Post
18x9.5 +38 Gun Blue
245/40/18 Hankook Ventus V12 Evo tires
Tein Flex Z coilovers, front max drop, rear lowered about 1 1/2", still room to go lower.
what is your tire specs? are you on LCA and toe arms?
envyme is offline   Reply With Quote
Old 07-30-2017, 01:19 AM   #177
thecarfilmer
IG: @nickwiththefrs
thecarfilmer's Avatar
Drives: 2016 Scion FR-S Halo
245 40 18. stock lca
thecarfilmer is offline   Reply With Quote
Old 08-01-2017, 03:58 PM   #178
envyme
Originally Posted by Conman View Post
"Glass Black" 18x9.5 57CRs
whats the tire specs for these?
Old 08-02-2017, 07:54 PM   #179
smg1138
smg1138's Avatar
Just realized the hubcentric rings from my RPF1's won't work on these. Anybody know where I can get some that fit the 17x9 +38? I prefer the aluminum ones.
Old 08-03-2017, 10:17 AM   #180
jubella2
jubella2's Avatar
Drives: DGM BRZ
CSG sells aluminum ones. I believe it is 56.1 to 65 that you want but you should double check.
http://counterspacegarage.com/hubcen...56-subaru.html
jubella2 is offline   Reply With Quote
The Following User Says Thank You to jubella2 For This Useful Post:
smg1138 (08-03-2017)
Old 08-03-2017, 10:30 AM   #181
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
I don't use hubcentric rings and have no issues
Cartman is offline   Reply With Quote
Old 08-06-2017, 12:37 PM   #182
smg1138
smg1138's Avatar
Got my 17x9 +38's Gun Blue 2's installed! Wrapped with Continental ExtremeContact Sports 245/40/17. This is going to be my new street setup. Currently dropped 35mm measured hub to fender. Trying to decide if I want to go just a little lower.
2015 New Wheel | Gram Lights 57Transcend | Concave 10-Spoke Kami Speed Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 07-15-2019 05:47 PM
WTB Gram Lights CRBCelica Want-To-Buy Requests 0 03-16-2015 07:21 PM
Gram Lights 57s-pro on FRS? MrMarinakos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-27-2014 05:46 PM
Gram Lights in the GTA Skurj CANADA 3 11-22-2012 09:41 PM
gram lights 57s pro jdmboss86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-10-2012 12:58 AM
