| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#170 |
Drives: 2013 Raven FR-S
I just realized they're +45's which may not be enough inside clearance. Would probably need spacers to prevent rubbing the fender liner under compression. Thanks for the info though.
#171 |
#172 |
Drives: 2017 Subaru BRZ WRB PP
Has anyone tried these wheels on the performance pack brembos? I plan on running RCE springs and camber bolts.
#173 | |
Drives: 17 BRZ
Sent from my SM-G955U using Tapatalk |
#174 |
Got my 17x9 +38's today! Looks like in this size the Gun Blue II's weigh in right at 18lbs. Not bad for 5 spoke cast wheel that's this wide.
| The Following 4 Users Say Thank You to smg1138 For This Useful Post: |
#175 |
Awesome I'll check it out. Do you think the 17x9 +38 would clear the fronts? Or would spacers be needed? 86speed posted a video on instragram it was tight but no worse than the stock wheels on the PP.
#176 |
Drives: Toyota 86 2017
#177 |
IG: @nickwiththefrs
Drives: 2016 Scion FR-S Halo
245 40 18. stock lca
#178 |
#179 |
Just realized the hubcentric rings from my RPF1's won't work on these. Anybody know where I can get some that fit the 17x9 +38? I prefer the aluminum ones.
#180 |
Drives: DGM BRZ
CSG sells aluminum ones. I believe it is 56.1 to 65 that you want but you should double check.
http://counterspacegarage.com/hubcen...56-subaru.html |
| The Following User Says Thank You to jubella2 For This Useful Post: | smg1138 (08-03-2017) |
#181 |
Drives: 10 Series Scion FR-S
I don't use hubcentric rings and have no issues
#182 |
Got my 17x9 +38's Gun Blue 2's installed! Wrapped with Continental ExtremeContact Sports 245/40/17. This is going to be my new street setup. Currently dropped 35mm measured hub to fender. Trying to decide if I want to go just a little lower.
| 2015 New Wheel | Gram Lights 57Transcend | Concave 10-Spoke | Kami Speed | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 07-15-2019 05:47 PM |
| WTB Gram Lights | CRBCelica | Want-To-Buy Requests | 0 | 03-16-2015 07:21 PM |
| Gram Lights 57s-pro on FRS? | MrMarinakos | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 02-27-2014 05:46 PM |
| Gram Lights in the GTA | Skurj | CANADA | 3 | 11-22-2012 09:41 PM |
| gram lights 57s pro | jdmboss86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 08-10-2012 12:58 AM |
