Old 06-08-2017, 02:18 PM   #1191
celek
Resident Gear Head
celek's Avatar
could also be colder dense air in the morning vs humid warm in in the afternoon
considering PA had about a 20 degree shift in temps between 8AM to noon today
celek is offline   Reply With Quote
The Following User Says Thank You to celek For This Useful Post:
Ultramaroon (06-08-2017)
Old 06-10-2017, 11:47 PM   #1192
ohmai18
ohmai18's Avatar
Drives: Subaru BRZ
https://www.instagram.com/p/BU6Ra66lgAp/
If you want some audio of an CS400 paired with a JDL uqfp and Perrin 2.5 resonated system.
Sent from my Pixel XL using Tapatalk
ohmai18 is offline   Reply With Quote
The Following 2 Users Say Thank You to ohmai18 For This Useful Post:
AceHeader-MT (06-18-2017), Lynxis (07-28-2017)
Old 07-21-2017, 06:56 PM   #1193
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Is it possible to get the CS400 ceramic coated? I'm probably going to pull the trigger at at the end of the year.
MS, CSCS, TSAC-F, CPT
Old 07-21-2017, 07:16 PM   #1194
Reamer
Drives: 2015 FRS
It is if you get it through CSG.
Sent from my Pixel using Tapatalk
Reamer is offline   Reply With Quote
The Following User Says Thank You to Reamer For This Useful Post:
weederr33 (07-21-2017)
Old 07-21-2017, 08:09 PM   #1195
Only on both sides, doe.
Old 07-21-2017, 08:56 PM   #1196
weederr33
weederr33's Avatar
That was the plan! Just didn't see the option on their site.
Old 07-21-2017, 09:22 PM   #1197
Reamer
Drives: 2015 FRS
PM'd
Old 07-21-2017, 09:25 PM   #1198
Reamer
Drives: 2015 FRS
I believe they have an outside only option too now.
Ultramaroon (07-21-2017)
Old 07-21-2017, 10:26 PM   #1199
Wrong side.
Reamer (07-21-2017)
Old 07-28-2017, 09:24 AM   #1200
Moue
Drives: 2014 Lightning Red Subaru BRZ
So got the CS/400 installed and tuned on 91 pump gas. Definitely a better daily driver and power starts building much earlier.
Maybe I was expecting too much from what I read from other CS/400 owners on the forums but 2000-3000RPM seems unchanged in a way. I had the feeling that it would have much improved low end torque, I guess I assumed wrong?
Maybe it should have more torque in that range and it's just the gas I'm using? I'm just wondering if there is anything I can do to improve that RPM range without needing to go with a supercharger.
Moue is offline   Reply With Quote
Old 07-28-2017, 12:14 PM   #1201
CSG David
CSG David's Avatar
ACE Type-A 350 and CS400 smooth out the powerband. Uncertain which tuner supported you to help validate the tuning parameters, but our tuning requirements make the power output and delivery quite smooth so you don't feel a "kick" in power, but rather just note the speedometer numbers rise a little quicker. What you may be feeling is a smoother power delivery. To be fair, this engine is a 2.0L naturally aspirated setup so you can't expect to feel forced induction levels of power delivery.
Old 07-28-2017, 12:32 PM   #1202
Moue
Zach from Delicious Tuning helped out. I guess I just had unrealistic expectations. Other than that the header was worth it.
Old 07-28-2017, 12:41 PM   #1203
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
That's good stuff. Short stroke vs. long stroke motors build torque differently. It's a high revving engine so it's not always recommended to load the engine around 2-3000 RPM.
CounterSpace Garage is offline   Reply With Quote
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
Moue (07-28-2017)
Old 07-28-2017, 02:35 PM   #1204
johan
Drives: '14 981CS, '99 NB1
If you want more power between 2-3k you should get a V8.
A 4-cylinder should be driven gently at that low of RPM. Trying to accelerate briskly in that RPM range puts a lot of heat into the bearings on a small engine. It's a great way to throw a rod if you're boosted.
johan is offline   Reply With Quote
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
