#1191 |
Resident Gear Head
could also be colder dense air in the morning vs humid warm in in the afternoon
considering PA had about a 20 degree shift in temps between 8AM to noon today
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
| The Following User Says Thank You to celek For This Useful Post: | Ultramaroon (06-08-2017) |
#1192 |
Drives: Subaru BRZ
https://www.instagram.com/p/BU6Ra66lgAp/
If you want some audio of an CS400 paired with a JDL uqfp and Perrin 2.5 resonated system. Sent from my Pixel XL using Tapatalk
| The Following 2 Users Say Thank You to ohmai18 For This Useful Post: | AceHeader-MT (06-18-2017), Lynxis (07-28-2017) |
#1193 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Is it possible to get the CS400 ceramic coated? I'm probably going to pull the trigger at at the end of the year.
#1195 |
#1196 |
That was the plan! Just didn't see the option on their site.
#1197 |
Drives: 2015 FRS
#1198 |
Drives: 2015 FRS
| The Following User Says Thank You to Reamer For This Useful Post: | Ultramaroon (07-21-2017) |
#1199 |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Reamer (07-21-2017) |
#1200 |
Drives: 2014 Lightning Red Subaru BRZ
So got the CS/400 installed and tuned on 91 pump gas. Definitely a better daily driver and power starts building much earlier.
Maybe I was expecting too much from what I read from other CS/400 owners on the forums but 2000-3000RPM seems unchanged in a way. I had the feeling that it would have much improved low end torque, I guess I assumed wrong? Maybe it should have more torque in that range and it's just the gas I'm using? I'm just wondering if there is anything I can do to improve that RPM range without needing to go with a supercharger. |
#1201 | |
#1202 | |
#1203 | |
Drives: Subaru BRZ / Toyota 86 Experts
| The Following User Says Thank You to CounterSpace Garage For This Useful Post: | Moue (07-28-2017) |
#1204 | |
Drives: '14 981CS, '99 NB1
A 4-cylinder should be driven gently at that low of RPM. Trying to accelerate briskly in that RPM range puts a lot of heat into the bearings on a small engine. It's a great way to throw a rod if you're boosted. |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
| Wanted: UEL header with Perrin header back and tune. | skye67 | Engine, Exhaust, Transmission | 7 | 12-21-2013 10:34 PM |
