#15 |
I was just going by what the OP posted yesterday ....... which indicated he had checked the voltage the alternator was putting out.
"Hi Tcoat, Yes Engine is fully stock no mod Just check the Alternator still good and charging battery 11.6v Battery measure at 12.6v Compression on all Cylinder is within spec at 135 PSI Check all the relay and Fuses non blown or damage" humfrz |
#16 |
Huge E85 fan!
Drives: 2016 Scion FRS
11.6 is low voltage for an altenator but not low enough that the car would stall. You'd get the check charging system light. But that is only voltage, do you have open phase or bad diodes? How's the ripple?
What is the fuel pressure? the fuel pump working only tells you if the in-tank fuel pump is working, but what about the HPFP? What's the pressure? Insufficient pressure from a working fuel pump will cause the car to stall out. |
#17 |
Drives: 2013 Subaru Brz Limited Automatic
@ Guybo Thank for the lead, I'll get those check out
#18 | |||
#19 | |
So, for funzies I just disconnected the accessory belt and started it to prove it would run on battery alone. Didn't want to assume it would. OP, does the starter crank over the engine like the battery has a full charge? If yes, it's not the alternator because the charging circuit and battery are fine.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (07-28-2017) |
#20 | |
Huge E85 fan!
With the batt voltage being good, it wasn't the alternator that made the car stall. The car would run until the volatge got so low it could not provide spark then die. The low voltage CEL is a red herring. That CEL probably came up after the car died. We really need more info from that CEL on what the car was doing when the CEL came up- but you need a better scan tool than a bluetooth code reader for that. |
| Engine Won't Crank - Battery or Worse - Sanity Check | StrangeLove4791 | Issues | Warranty | Recalls / TSB | 16 | 02-22-2017 11:18 PM |
| Car won't start, won't crank, no ecu communication | redlined600 | Issues | Warranty | Recalls / TSB | 10 | 07-09-2016 12:55 PM |
| Car Won't Start.. No Lights.. Not a battery or fuse issue.. | pleong | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 09-23-2015 04:45 PM |
| No crank no start issue | *KID* | Issues | Warranty | Recalls / TSB | 3 | 09-29-2014 06:22 AM |
| Battery dies, push start car in gear.... push start button | rhythmM | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-27-2014 06:06 PM |
