Old 07-23-2017, 11:31 PM   #1
TheBRZsKnees
TheBRZsKnees's Avatar
Drives: 2014 BRZ
Unhappy Car wants to boost rather than shifting
Hey all. I have a 2014 AT BRZ. I've had a ton of problems since I installed my FBM turbo.
The problems started when a downpipe fitment issue melted the wire to my passenger-side cam sensor. This caused a fuse to blow and prevented a start every time I tried to start the car.
I fixed the wire, but a few days later the car started to run very rough on the freeway. I pulled off at the first exit before it stalled. I took it to a shop, and they found that the DI ECU had failed. They replaced the ECU, and the car was fine for a couple weeks.
I took it to my tuner on his recommendation last week. He said the tune was a mess and reflashed it. He noted that I'm getting a lot more blow-by considering a bit of smoke from my vented catch can. He said he thought the car had been running very lean after the ECU failed, and sounded grim about what this could mean.
Over the past few days, I noticed a clicking/tapping sound from the passenger side of my engine. At first I only noticed it around 1500 RPM, but I feel like it's louder and more frequent now. On the way home today I noticed that the car seemed to lack power.
At the top of second gear, it seems to go into boost rather than shifting up, even when applying the gas gently. I avoided going over 1 or 2 PSI for fear of damaging something. My gauge reads -19 or -20 when not applying gas. One of my friends suggested a boost leak. I'll take it to a shop as soon as I can, but I'm wondering if anyone else has ideas what the problem could be.
TheBRZsKnees is offline   Reply With Quote
Old 07-23-2017, 11:46 PM   #2
OND
OND's Avatar
Drives: 2023 BRZ
Damn I thought this was ft86club.com, not zilvia.net..
OND is offline   Reply With Quote
Old 07-24-2017, 12:56 AM   #3
Originally Posted by ph4zon View Post
Hey all. I have a 2014 AT BRZ. I've had a ton of problems since I installed my FBM turbo................
What did you expect ......??
The more you mess with the car ..... the more it will mess with you .....
Sorry, I can't help you ...... I dropped my meds on the floor this morning ..... I don't think I found them all .....
chaoskaze (07-25-2017), spike021 (07-25-2017)
Old 07-25-2017, 11:16 AM   #4
TheBRZsKnees
Drives: 2014 BRZ
True. Mo boost, mo problems. Still, I figured I could go more than 2k miles before those problems started
Old 07-25-2017, 11:31 AM   #5
The first 2,000 miles is the worst ........
Old 07-25-2017, 01:04 PM   #6
are*
Old 07-25-2017, 01:50 PM   #7
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
OP check the FI tech forum, maybe the guys there can help you more?
or just take it to a real shop & figure things out
Old 07-25-2017, 01:59 PM   #8
are*
Hey .......I'll be ah watchen youens posts ......
Old 07-25-2017, 02:15 PM   #9
Well Ultra is slacking at his Grammar Police duties so somebody has to keep an eye out.
Old 07-25-2017, 03:15 PM   #10
See what you caused @ph4zon just because you put a turbocharger on your car ......
Old 07-25-2017, 06:06 PM   #11
Silver Supra
Hombre
Silver Supra's Avatar
Drives: 1994 Supra Turbo
are*
is*
not referring to every mile but a distance.
try substituting the word distance for "2000 miles"
A Toyota Racecar A Toyota......................Because.
Anyway, should not palindrome be spelled palinilap?
Silver Supra is offline   Reply With Quote
Old 07-25-2017, 06:07 PM   #12
Silver Supra
Hombre
Nothing inherently wrong with FI or specifically a turbo if they are done right.
Are you taking it to the shop that installed it?
If so, try another.
GL
Old 07-25-2017, 06:16 PM   #13
TheBRZsKnees
Drives: 2014 BRZ
Yeah, it goes to a shop tomorrow. I'm just trying to anticipate how hard it's going to hit my wallet. RIP my mod plans for the rest of the year.
If so, try another.
GL
I did the install with a more experienced friend. I learned a lot, but the aftermath has shown me that it really wasn't worth it. Still, I haven't been able to clearly trace which of the problems were due to mistakes we made, and which are just bad luck.
Old 07-25-2017, 08:14 PM   #14
is*
Well, now, there you have it @Tcoat ....... .....that's fer making me feel bad, when I wasn't wrong.
Thanks, there, Silver Supra, I reckon some of you Miss Sippy-ians are OK ....
boost, no power, turbo
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 01:27 PM
BRZedit and boost. (also wondering BRZedit vs ECUtek with boost) NickFRS Software Tuning 43 03-10-2014 04:10 AM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 05:09 PM
