Drives: FR-S 10 Series #2127
1st & 2nd gear stuck?
Hey guys I'm not sure if anyone has experienced this issue, I'm fairly new and haven't been able to find anything about it.
So basically as I was driving today just like any other day, I am at a stop light and i go to shift to 1st, but couldn't, kept going into 3rd, so i try 2nd, that takes me right into 4th. After a little bit of playing around trying to get going at this stop light lol I find that if I lift the little thing to put it into reverse and go about halfway to reverse it'll allow me to go up into 1st or even 2nd. Anyone know of what could fix this? everything was fine until earlier today. I mean it seems to engage fine once I'm able to find the gear. |
#2 | |
![]() Bummer your car isn't shifting proper...... ![]() Sounds to me like something in the shifting linkage has come unglued. If your car is under warranty, I would suggest you take it into the dealer ASAP. There are several threads that discuss this type of issue you may wish to review. Calling @Tcoat to list them ...... ![]() humfrz |
#3 |
I'll take a wild guess that you failed to mention you have a TRD short shifter kit installed.
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#4 |
#5 | |
Personally, I suggest removing it and chucking it in the trash.
#6 |
Thanks for the information man. I'll probably take it down to the dealership because it was factory installed and might still be under warranty, but ill for sure look at other shifters, Really appreciate it!
#7 | |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (09-07-2016) |
#8 | |
For goodness sake, if you have any more problems ...... please tell us the whole story up front ...... ![]() humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | Ultramaroon (09-07-2016), YoungChow (09-07-2016) |
#9 | |
![]() BTW, what is with the attraction of "short shifters" ...... ?? Why isn't the OEM shifter short enough .. ?? Is it because the young-ens want something like that was on the controller of their video games .. ?? ![]() humfrz |
#10 | |
It's a money maker because it's cool. IMO, the stock throw is already as short as it can be to get enough leverage against the synchros. It's already pretty slow to match at 6500 RPM. Can't rush this gearbox. I've tried. (You and Tcoat know what I mean.)
#11 |
Drives: 2015 Ultramarine Scion FR-S (MT)
Don’t mean to revive an old thread, but what if the bolt and the pin is all tight, using red loctite, but the shifter is still loose? As in a shit show of wiggle room while in neutral, in gears, and having a difficult time trying to get in to reverse?
2015 Ultramarine FRS - OFT Stage 2 E85 - TRD Intake - TRD Strut Bar - Tein Street Flex - Avid.1 AV-20 18x8.5/9.5 Staggered - Muteki Burnt Blue lugs - Toyo T1 Sports F:225/40/18, R: 245/40/18 - TOMEI UEL - TOMEI OP - BERK Straight Pipe - Tomei 80R - Valenti v2 Sequential Clear/Red Tail lights/4th Brake Light - TRD Japan Short Shift - LIKEWISE Deathgrip shift knob - LIKEWISE The Love Button drift knob
#12 |
If you can rotate the shift lever at all it's a definite sign that the adapter came loose. Let's start there.
| Stuck Between Gruppe-S or JDL | Cojonudo | Engine, Exhaust, Transmission | 14 | 06-14-2016 08:33 PM |
| Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl | jakebrz | Issues | Warranty | Recalls / TSB | 14 | 06-06-2016 07:28 PM |
| stuck between | brz23 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 03-06-2015 12:01 AM |
| key keeps getting stuck | Covo_86 | Issues | Warranty | Recalls / TSB | 14 | 04-21-2014 09:55 AM |
